[Osgeo4w-trac] [osgeo4w] #690: GRASS GIS 8 in OSGeo4W NG
trac_osgeo4w at osgeo.org
Fri Sep 17 05:14:14 PDT 2021
Reporter: sbl | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: grass |
Comment (by jef):
Replying to [comment:2 sbl]:
> Thanks for your reply.
> For starters I tried (in a Github action), to:
> 1. Download dependencies from OSGeo4W (so they live in ''/c/OSGeo4W/'',
That's not necessary. Each package installs it's own copy of OSGeo4W
dependencies in `src/$P/osgeo4w/osgeo4W`.
> 2. Setting the current working directory to where the ''package.sh''
lives (''src/grass/osgeo4w'') and run it with ''bash''.
But `src/grass/osgeo4w/package.sh` already exists!?
> However, although the relative path should be correct, ''build_helpers''
was not found, and after hardcoding the path to ''build_helpers'',
''build_helpers'' was sourced, but then ''genini'' fails:
> /d/a/OSGeo4W/OSGeo4W/scripts/genini: can't open x86_64/setup.ini.tmp -
No such file or directory
> mv: cannot stat 'x86_64/setup.ini.tmp': No such file or directory
> /d/a/OSGeo4W/OSGeo4W/scripts/build-helpers: line 206:
x86_64/setup.ini.bz2: No such file or directory
Ok, `x86_64/release` was apparently not created automatically. IIRC this
wasn't ever run on github, because QGIS isn't buildable anyway - after
hours it would run out of space…
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/690#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
