[Osgeo4w-trac] [osgeo4w] #759: qgis-dev 3.27.0-Master crashes during startup in some circumstances
OSGeo4W trac_osgeo4w at osgeo.org
Wed Aug 3 06:39:06 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  major        |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Description changed by jef:
Old description:
> QGIS 3.27.0-Master (qgis-dev-3.27.0-286-fc5faa84bf-1) crashes on startup
> (during "Setting up the GUI"), when launched from the shortcut link "QGIS
> Desktop 3.27.0 (Nigthly)" in the start menu, if there is a file or a
> folder with the name containing non-ASCII characters (like e.g. è, é, æ,
> ø, å, ...) in the user "Documents" directory.
> Note that the QGIS shortcut links in the start menu contain the user
> "Documents" folder path in the "Start in" property.
> QGIS 3.26.1 and QGIS 3.22.9 in the same OSGeo4W installation don't suffer
> from such issue.
> See https://github.com/qgis/QGIS/issues/49507 (and probably also
> https://github.com/qgis/QGIS/issues/49546).
New description:
 Desktop 3.27.0 (Nightly)" in the start menu, if there is a file or a
 from such issue.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/759#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
