[Osgeo4w-trac] [osgeo4w] #757: Qt Designer: Code generation failed
OSGeo4W trac_osgeo4w at osgeo.org
Thu Jul 21 03:12:43 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  minor        |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by jef):
 Replying to [comment:5 Andreas Müller]:
 > Shouldn't qt5-libs then be in setup.ini, in requires for qt5-tools or
 qt5-libs?
 You mean qt5-devel?  Depends. It's a quite heavy dependency (along with
 qt5-libs-debug).
 If you're developing C++ you will probably already have qt5-devel anyway.
 If you're developing python with osgeo4w you will probably dispense with
 the PySide2 code designer would show if it had uic.
 And if you're just doing forms for QGIS - which is why there is a separate
 qt5-tools package to start with - you won't need either code preview.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/757#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
