[Osgeo4w-trac] [osgeo4w] #734: GISBASE Environment not set
OSGeo4W trac_osgeo4w at osgeo.org
Wed Mar 9 06:30:20 PST 2022
Reporter:  aharfoot  |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  minor     |   Component:  Installer
 Version:            |  Resolution:
Keywords:            |
Description changed by jef:
Old description:
> When I install QGIS LTR 3.22.4 using the package based installer
> (individual packages, not the meta-package) along with GRASS 7.8 and run
> the C:\OSGeo4W\bin\qgis-ltr-bin.exe, the GRASS processing provider is
> broken, and trying to run any GRASS processing tool gives the following
> error:
> ''This algorithm cannot be run :-(
> The specified GRASS 7 folder "C:\OSGeo4W\bin\bin" does not contain a
> valid set of GRASS 7 modules. Please, go to the Processing settings
> dialog, and check that the GRASS 7 folder is correctly configured''
> The same behaviour is not seen with the standalone QGIS installer.
> From #47163 I can see that this message is returned by Grass7Utils.py,
> and after some exploration I discovered that this is because the GISBASE
> environment variable is not set.
> If QGIS is launched via the batch file: C:\OSGeo4W\bin\qgis-ltr.bat, then
> GISBASE is correctly set and the GRASS processing tool function
> correctly.
> The OSGeo4W package based installer creates a Windows shortcut that
> points to the C:\OSGeo4W\bin\qgis-ltr-bin.exe, and therefore when this is
> run, the bug exhibits itself.
> **Steps to reproduce the issue**
> With the OSGeo4W package installer, install QGIS LTR 3.22.4 along with
> GRASS 7.8 (7.8.7-1) on MS Windows. Load QGIS via the Start Menu shortcut.
> In QGIS, open the Processing panel and double click on a tool from the
> GRASS provider.
> Check the status of the GISBASE environment variable through the QGIS
> python console by executing:
> os.environ['GISBASE']
> **Environment:**
> QGIS: 3.22.4
> GRASS: 7.8.7-1
> OS: Windows 10 64bit
New description:
 error:
 The specified GRASS 7 folder "C:\OSGeo4W\bin\bin" does not contain a valid
 set of GRASS 7 modules. Please, go to the Processing settings dialog, and
 From [[https://github.com/qgis/QGIS/pull/47163|#47163]] I can see that
 this message is returned by Grass7Utils.py, and after some exploration I
 discovered that this is because the GISBASE environment variable is not
 set.
 GISBASE is correctly set and the GRASS processing tool function correctly.
 The OSGeo4W package based installer creates a Windows shortcut that points
 to the C:\OSGeo4W\bin\qgis-ltr-bin.exe, and therefore when this is run,
 GRASS provider.
 **Environment:**
 QGIS: 3.22.4
 GRASS: 7.8.7-1
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/734#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
