[Osgeo4w-trac] [osgeo4w] #766: starting qgis from OSGeo4W shell: Couldn't load plugin 'processing'
OSGeo4W trac_osgeo4w at osgeo.org
Wed Nov 16 05:56:21 PST 2022
Reporter:  jakimowb  |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  closed
Priority:  major     |   Component:  Package
 Version:            |  Resolution:  worksforme
Keywords:            |
Comment (by jakimowb):
 Thanks for your reply. Yes indeed, calling `qgis.exe` or `qgis-dev.exe`
 directly, e.g. from windows explorer, avoids the error (similar to
 restaring the OSGeo4W entire shell). So the entire issue may have a low
 priority only.
 Otherwise, I'd expect that each bat/exe that is listed by `o-help` can be
 run in the OSGeo4W shell no matter which other bat/exe was executed
 before. At least in the OSGeo4W environment that I installed a couple of
 minutes ago (folder `F:\OSGeo4W-2`) neither `qgis.exe` nor `qgis-dev.exe`
 is available (but the *.bat listed by `o-help`).
 F:\OSGeo4W-2>o-help
                    -={ OSGeo4W Shell Commands }=-
   applygeo                                bgspawn
   brotli                                  curl
   dllupdate                               gdaladdo
   gdalbuildvrt                            gdaldem
   gdalenhance                             gdalinfo
   gdallocationinfo                        gdalmanage
   gdalmdiminfo                            gdalmdimtranslate
   gdalsrsinfo                             gdaltindex
   gdaltransform                           gdalwarp
   gdal_contour                            gdal_create
   gdal_grid                               gdal_rasterize
   gdal_translate                          gdal_viewshed
   geotifcp                                getspecialfolder
   gnmanalyse                              gnmmanage
   iconv                                   listgeo
   makegeo                                 nearblack
   ogr2ogr                                 ogrinfo
   ogrlineref                              ogrtindex
   osgeo4w-setup                           pdal
   pg_dump                                 pg_dumpall
   pg_restore                              psql
   python                                  python3
   pythonw                                 pythonw3
   qgis-bin                                qgis-dev-bin
   sqlite3                                 textreplace
   xmlcatalog                              xmllint
   xxmklink                                gdal-dev-env
   gdal-dev-py-env                         o-help
   o4w_env                                 python-qgis-dev
   python-qgis                             qgis-designer
   qgis-dev-designer                       qgis-dev
   qgis                                    qgis_process-qgis-dev
   qgis_process-qgis                       setup
 GDAL 3.6.0, released 2022/11/06
 F:\OSGeo4W-2>where qgis
 F:\OSGeo4W-2\bin\qgis.bat
 F:\OSGeo4W-2>where qgis-dev
 F:\OSGeo4W-2\bin\qgis-dev.bat
 F:\OSGeo4W-2>where qgis.exe
 INFO: Could not find files for the given pattern(s).
 F:\OSGeo4W-2>where qgis-dev.exe
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/766#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
