[Osgeo4w-trac] [osgeo4w] #775: Dependency issue
trac_osgeo4w at osgeo.org
Sat Feb 11 11:18:32 PST 2023
Reporter: gpsaliola | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: major | Component: Installer
Version: | Resolution: invalid
Keywords: osgeo4w setup EPSG |
Changes (by jef):
* status: new => closed
* resolution: => invalid
Comment:
-L implies that you downloaded all dependencies into you local package
directory. gdal depends on gdal306-runtime, which depends on
proj91-runtime, which (like the outdated proj82-runtime you installed)
depends on proj-data, which has the actual proj datafiles. Your local
package directory apparently didn't have proj-data, but proj91-runtime -
otherwise gdalinfo wouldn't even have started.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/775#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
