[Osgeo4w-trac] [osgeo4w] #796: qgis-common.bat exit code -1073741511
OSGeo4W trac_osgeo4w at osgeo.org
Fri Jun 23 09:08:25 PDT 2023
Reporter:  Antonio3Brandao          |       Owner:  osgeo4w-dev@…
    Type:  defect                   |      Status:  new
Priority:  normal                   |   Component:  Package
 Version:                           |  Resolution:
Keywords:  1073741511;gdal307.dll;  |
Description changed by Antonio3Brandao:
Old description:
> Hello,
> System:Windows 10 64bit and QGIS3 using
> https://download.osgeo.org/osgeo4w/v2/osgeo4w-setup.exe
> Previous I had 3.18 installed and I installed QGIS version 3.30 along
> with the previous one and after the problem apear. After I remove the
> 3.18 version.
> Error after uninstalling and installing again:
> Package: Unknown package
> [[Image(https://i.imgur.com/FhhhtuT.png)]]
> With Dialogue box with error:
> crssync.exe - Entry Point Not Found The procedure entry point
> opj_encoder_set_extra_options could not be located in the dynamic link
> library C:\OSGe04W\bin\gdal307.dll.
> [[Image(https://i.imgur.com/U5OlaE5.png)]]
> As search the problem could be because of missing the libcurl.dll, and I
> have in System32 folder and SysWOW64 only the libcurl769.dll that seems
> to be another version, and I copy libcurl.dll from QGIS3 into both system
> folder and problem is the same.
> I also have in "C:\OSGeo4W\var\log\Setup.log.full" the next message:
> Could Not Find C:\OSGeo4W\apps\qgis\grass\*.pyc
> Any help would be appreciated.
New description:
 Hello,
 Previous I had 3.18 installed and I installed QGIS version 3.30 along with
 the previous one and after the problem apear. After I remove the 3.18
 version.
 [[Image(https://i.imgur.com/ZCG6erQ.png)]]
 [[Image(https://i.imgur.com/8Mh3uBg.png)]]
 have in System32 folder and SysWOW64 only the libcurl769.dll that seems to
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/796#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
