[Osgeo4w-trac] [osgeo4w] #796: qgis-common.bat exit code -1073741511
OSGeo4W trac_osgeo4w at osgeo.org
Sat Jun 24 17:38:15 PDT 2023
Reporter:  Antonio3Brandao          |       Owner:  osgeo4w-dev@…
    Type:  defect                   |      Status:  new
Priority:  normal                   |   Component:  Package
 Version:                           |  Resolution:
Keywords:  1073741511;gdal307.dll;  |
Comment (by andreaerdna):
 Replying to [comment:9 Antonio3Brandao]:
 As previously stated, the issue is due to a missing openjp2.dll (openjpeg
 package) in the PATH (it should be in C:\OSGeo4W\bin\) or to having an
 openjp2.dll (openjpeg package) version lower than 2.4.0 in the PATH.
 It seems to me the provided attached log are incorrectly created, as it is
 evident that the PATH is not correctly set, so crssync.exe cannot find
 neither QGIS_CORE.DLL nor GDAL307.DLL, so the logs are not useful.
 Have you tried doing a clean install after completely deleting the
 C:\OSGeo4W folder or just do a clean install in a new folder different
 from the C:\OSGeo4W one?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/796#comment:10>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
