[Osgeo4w-trac] [osgeo4w] #796: qgis-common.bat exit code -1073741511
OSGeo4W trac_osgeo4w at osgeo.org
Tue Jun 27 05:04:29 PDT 2023
Reporter:  Antonio3Brandao          |       Owner:  osgeo4w-dev@…
    Type:  defect                   |      Status:  new
Priority:  normal                   |   Component:  Package
 Version:                           |  Resolution:
Keywords:  1073741511;gdal307.dll;  |
Comment (by Antonio3Brandao):
 Hello, it still gives me the same error on the end of the setup.
 [[Image(https://i.imgur.com/7m52zgL.png)]]
 This time I uninstall, clean all folders even the profile folder,
 uninstall all visual c++ packages, restart PC install all again.
 When I run the qgis.bat with depends inside QGIS. See attach Log.
 Does the problem has something to do about languages? Or data source
 encoding?
 Error when using grass inside QGIS. See attach log.
 [[Image(https://i.imgur.com/snYjpj2.png)]]
 Thanks.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/796#comment:19>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
