[Osgeo4w-trac] [osgeo4w] #803: Can not input CJK characters in qscintilla editor
OSGeo4W trac_osgeo4w at osgeo.org
Mon Sep 11 06:56:58 PDT 2023
Reporter:  liuxspro    |       Owner:  osgeo4w-dev@…
    Type:  defect      |      Status:  closed
Priority:  normal      |   Component:  Package
 Version:              |  Resolution:  fixed
Keywords:  qscintilla  |
Comment (by liuxspro):
 Replying to [comment:3 jef]:
 > QGIS just reports which version is was built against, which is not
 necessarilly the version it is current running with.  For some libraries
 it also reports, which version it is currently using, but not for all
 (some even don't have an API to check that; you can verify using
 `qgis.PyQt.Qsci.QSCINTILLA_VERSION_STR` in the python console).
 > See also https://lists.osgeo.org/pipermail/osgeo4w-
 dev/2023-September/004742.html
 Thank you for your answer.
 I have tried `qgis.PyQt.Qsci.QSCINTILLA_VERSION_STR`,QSCINTILLA has indeed
 been upgraded to version 2.13.4. However, the issue of being unable to
 input CJK characters still persists.
 [[Image(https://i.imgur.com/q7RfagM.png)]].
 I tried the latest version 2.14.1, and this version resolved the issue of
 being unable to input. Maybe QScintilla still need a upgrade.
 [[Image(https://i.imgur.com/pllIcNB.png)]]
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/803#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
