[Osgeo4w-trac] [osgeo4w] #804: Could not load qgis_app.dll - QGIS LTR 3.28.11 OSGeo4W Installer
OSGeo4W trac_osgeo4w at osgeo.org
Wed Sep 20 09:17:44 PDT 2023
Reporter:  ascottwwf                            |       Owner:  osgeo4w-
                                                |  dev@…
    Type:  defect                               |      Status:  new
Priority:  normal                               |   Component:  Installer
 Version:  1.0                                  |  Resolution:
Keywords:  QGIS LTR OSGeo4W scripted installer  |
Description changed by ascottwwf:
Old description:
> I tried raising this issue with QGIS but I was pointed in your direction
> **What is the bug or the crash?**
> After either a fresh install (or an upgrade install) of QGIS LTR using
> the OSGeo4W installer, the QGIS application will not start as it errors
> with:
> [[Image(ticket:1:picture.gif)]]
> **Steps to reproduce the issue**
> We deploy QGIS LTR to a small number of users using Intune as our
> Application deployment method, this is deployed using a PowerShell script
> (originally sourced from:
> https://gist.github.com/Guts/6303dc5eb941eb24be3e27609cd46985), my
> slightly modified script is as follows:
> "Begin: $ENV:PROCESSOR_ARCHITECTURE" >> "C:\Windows\Temp\Test.txt"
> If ($ENV:PROCESSOR_ARCHITEW6432 -eq "AMD64") {
>      Try {
>          &"$ENV:WINDIR\SysNative\WindowsPowershell\v1.0\PowerShell.exe"
> -File $PSCOMMANDPATH
>      Catch {
>          Throw "Failed to start $PSCOMMANDPATH"
>      Exit
> "End: $ENV:PROCESSOR_ARCHITECTURE" >> "C:\Windows\Temp\Test.txt"
> #Requires -RunAsAdministrator
> Install-OSGeo4W_QGIS-LTR.ps1
> .Synopsis
>    Download the OSGeo4W installer then download and install QGIS LTR
> (through the 'full' meta-package).
> .DESCRIPTION
>    This script will:
>       1. change the current directory to the user downloads folder
>       2. download the OSGeo4W installer
>       3. launch it passing command-line parameters to INSTALL QGIS LTR
>     Documentation reference:
> https://trac.osgeo.org/osgeo4w/wiki/CommandLine
> Adrian Scott
> 7th December 2022
> Original file sourced from:
> Write-Host "=== Start installing / upgrading QGIS LTR..."
> -ForegroundColor Green
> # Save current working directory
> $starter_path = Get-Location
> # Move into the user download directory
> Set-Location -Path "$($env:USERPROFILE)\Downloads"
> # Set saved name of File to be downloaded
> $OutFile = "osgeo4w-setup.exe"
> # Download installer
> Write-Host " = Start downloading the OSGeo4W installer..."
> -ForegroundColor Yellow
> Invoke-WebRequest -Uri "https://download.osgeo.org/osgeo4w/v2/osgeo4w-
> setup.exe" -OutFile $OutFile
> # Download and install (same command to upgrade with clean up)
> Write-Host " = Start installing / upgrading QGIS LTR..." -ForegroundColor
> Yellow
> & .\$($OutFile) `
>     --quiet-mode `
>     --advanced `
>     --arch x86_64 `
>     --autoaccept `
>     --delete-orphans `
>     --local-package-dir "$($env:APPDATA)\OSGeo4W_v2-Packages" `
>     --menu-name "QGIS LTR" `
>     --no-desktop `
>     --packages qgis-ltr-full `
>     --root "$($env:ProgramFiles)\OSGeo4W_v2" `
>     --site "https://www.norbit.de/osgeo4w/v2" `
>     --site "https://download.osgeo.org/osgeo4w/v2" `
>     --site "https://ftp.osuosl.org/pub/osgeo/download/osgeo4w/v2" `
>     --upgrade-also `
>  | out-null
> # Return to the initial directory
> Set-Location -Path $starter_path
> Write-Host "==== Work is done!" -ForegroundColor Green
> So, up until the release of QGIS LTR version 3.28.9 (or 3.28.8), this
> script had worked fine, but since then we have been seeing this issue
> This issue occurs on both fresh installs and upgrade installs (this is
> similar to the earlier reported QGIS issue #49148
> (https://github.com/qgis/QGIS/issues/49148).
> We use the OSGeo4W installer to install (and/or upgrade) QGIS LTR
> From my basic understanding it appears that during the install, the path
> environment does not get updated (as it had previously), so when running
> the QGIS application the qgis_app.dll can not be found, hence the error
> message.
> I also note that on a new and upgraded install that the qgis-ltr-bin.env
> file does not exist so it is not possible to Check this file for correct
> environment paths.
> I have re-visited the command line syntax for the OSGeo4W installer
> (https://trac.osgeo.org/osgeo4w/wiki/CommandLine), to double check there
> is no changes to the syntax (or mistakes in my command), but all seems as
> it always has.
> FYI: All our devices run Windows 10 Enterprise (x64) version 22H2 with
> latest September (or August) 2023 Windows updates installed i.e. Build
> 10.0.19045.3348
> I suspect the installer is failing to complete at some point and not
> running the procedure that amends the environment path
New description:
 After either a fresh install (or an upgrade install) of QGIS LTR using the
 OSGeo4W installer, the QGIS application will not start as it errors with:
 [[Image(ticket:804:QGIS Install Error.png)]]
      Try {
      Catch {
      Exit
 .Synopsis
 .DESCRIPTION
    This script will:
 Adrian Scott
 7th December 2022
 Write-Host "=== Start installing / upgrading QGIS LTR..." -ForegroundColor
 Green
 Yellow
 & .\$($OutFile) `
     --quiet-mode `
     --advanced `
     --arch x86_64 `
     --autoaccept `
     --delete-orphans `
     --no-desktop `
     --upgrade-also `
  | out-null
 message.
 environment paths.
 it always has.
 10.0.19045.3348
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/804#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
