[Osgeo4w-trac] [osgeo4w] #804: Could not load qgis_app.dll - QGIS LTR 3.28.11 OSGeo4W Installer
trac_osgeo4w at osgeo.org
Thu Sep 21 01:57:49 PDT 2023
Reporter: ascottwwf | Owner: osgeo4w-
| dev@…
Type: defect | Status: new
Priority: normal | Component: Installer
Version: 1.0 | Resolution:
Keywords: QGIS LTR OSGeo4W scripted installer |
Comment (by ascottwwf):
I have attached both log files to this issue, these are from my machine
that is being upgraded.\\
I will re-run the install on my Windows 10 sandbox (a fresh install) and
get you the logs from there later.
Although I don't know exactly what I'm looking for, there is the following
'Fatal Python error' that occurs in the setup.log.full file
"ModuleNotFoundError: No module named 'encodings'"\\
Here is the snippet (from lines 1707 to 1741 of the setup.log.full file) -
I fully accept this may (or may not) be a reason for the issue:
2023/09/19 10:47:50 Running preremove script for python3-pillow
2023/09/19 10:47:50 running: cmd.exe /c "C:\Program
Files\OSGeo4W_v2\\etc\preremove\python3-pillow.bat"
C:\Program Files\OSGeo4W_v2>python3 -B "\Scripts\preremove-cached.py"
python3-pillow
Python path configuration:
PYTHONHOME = (not set)
PYTHONPATH = (not set)
program name = 'python3'
isolated = 0
environment = 1
user site = 1
import site = 1
sys._base_executable = 'C:\\Program Files\\OSGeo4W_v2\\bin\\python3.exe'
sys.base_prefix = ''
sys.base_exec_prefix = ''
sys.platlibdir = 'lib'
sys.executable = 'C:\\Program Files\\OSGeo4W_v2\\bin\\python3.exe'
sys.prefix = ''
sys.exec_prefix = ''
sys.path = [
'C:\\Program Files\\OSGeo4W_v2\\bin\\python39.zip',
'.\\DLLs',
'.\\lib',
'C:\\Program Files\\OSGeo4W_v2\\bin',
Fatal Python error: init_fs_encoding: failed to get the Python codec of
the filesystem encoding
Python runtime state: core initialized
Current thread 0x00003bb8 (most recent call first):
<no Python frame>
2023/09/19 10:47:50 abnormal exit: exit code=1
2023/09/19 10:47:50 Uninstalling python3-pillow
Reviewing your suggestion, it does look like the
%OSGEO4W_ROOT%\etc\postinstall\qgis-ltr.bat probably ran correctly as
there is a copy of qgis-ltr.bat.done in the postinstall folder, (the
modified date of the file is 15th Sept 2023 15:50 - I assume(?) this is
the correct modified time I should expect to see for the file (I installed
this on the 19th September so the modified time pre-dates the install date
/ time I would expect).\\
The .env file(s) do not exist.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/804#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
