[OSGeoJapan-discuss] Integration of Japanese GIS formats into mainline GDAL ?
Hiroo Imaki hiroo @ angeli.org
2015年 8月 18日 (火) 17:58:16 PDT
Hi Even, Akagi-san, and Ko-san
Ko-san, I am sorry I missed your message you set to the list last month. I
was on vacation and did not check email for a while.
I stepped in this conversation last May and has been talking to those
people who worked on GDAL and OGR drivers for the Japanese data. But I
realized that I am not that useful on this topic (sorry!).
Here is what I found so far. For the old drivers (JPGIS driver for vector
data and DEM raster data driver), owners of those agreed on releasing them
with the MIT license. For the JPGIS (GML) vector driver, there is one more
step to release it but it hasn't reached the point to release it.
Anyway,I totally agree on Akagi-san's comment and people who worked on
this should
make efforts for the support of recent format rather than old formats that
are no longer distributed from GSI.
I hope we can release what we already have soon too.
Akagi-san and Ko-san, great job!!
Hiroo
On Tue, Aug 18, 2015 at 4:57 PM, Even Rouault <even.rouault @ spatialys.com>
wrote:
> Hi Minoru,
> > We had an online hackathon about this topic on the same day as QGIS
> > HackFests in Japan (2015-08-01). The purpose was to read FGD (GML)
> > vector data (v4) with the OGR GML driver.
> > I prepared .gfs schema files, then registered them to the GML registry
> > and made a few changes to the GML driver code. Finally, I managed to
> > read FGD (GML) vector data with the driver! See the work branch [1]
> > and the hackpad [2][3] for the details.
> This is cool you managed to use the GML registry mechanism.
> I think however that the changes done in ogrgmldatasource.cpp in this
> branch
> should be amended to restore the previous behaviour when the namespace
> prefix
> is defined in the registry, and the behaviour of the branch when it is not
> defined, so that full control is still available.
> I'd add to the todo list to add a few words to drv_gml.html to mention that
> FGD GML v4 is supported in the "Particular GML application schemas"
> section.
> > I think we should make efforts for the support of recent format rather
> > than old formats that are no longer distributed from GSI.
> That makes sense. Sometimes supporting old formats can be of interest when
> people are interested in historic data that isn't available to more modern
> formats, but this is admitedly a particular use case.
> Best regards,
> Even
> > Any comments?
> > [1] https://github.com/minorua/gdal/commits/fgdgml_vector_1.11
> >     The branch is based on 1.11 (the current GDAL version of OSGeo4W).
> > [2] https://hackpad.com/JPGISGML-HackFest-2015-XgBUI6qfbGP  (In
> Japanese)
> > [3] https://hackpad.com/JPGIS-GML-Hackathon-2015-iI1ButdfjwX  (English
> > summary)
> > Minoru
> > 2015-07-20 23:23 GMT+09:00 Even Rouault <even.rouault @ spatialys.com>:
> > > Ko-san,
> > > Thanks a lot for bringing some light on this.
> > > I've created https://trac.osgeo.org/gdal/ticket/6046 to capture all
> > > findings up to now and trace tasks that I've in mind that should be
> > > completed for integretation into upstream GDAL.
> > > Best regards,
> > > Even
> > >> Hi Even,
> > >> CC: Hiroo-san, Yamate-san, list
> > >> Excuse me for cutting in this topic.
> > >> I am neither the developer nor the player, but I tried mext_gdal
> > >> test version (gdal110_test.zip) at last weekend and probably I
> understood
> > >> some data related part, so I mention some of your question about
> datas.
> > >> (But, if someone find my mistake, please point it out here...)
> > >> 2015-05-01 18:59 GMT+09:00 Even Rouault <even.rouault @ spatialys.com>:
> > >> > I tried the FGD ogr driver on the file
> https://github.com/msherry/PyXB-1.1.4/blob/master/examples/unicode_jp/d
> > >> > at
> > >> > a/shift_jis/FG- GML-13-RailCL25000-20080331-0001.xml
> > >> > (found by googling FG-GML)
> > >> > It is not recognized by the driver. Looking more closely, the driver
> > >> > seems to expect a <GI> element that isn't found in that file. It
> > >> > appears
> > >> > that there are several versions of FGD GML, right ? The above file
> is
> > >> > apparently v3 (since there's a v3 schema next to it). Perhaps the
> > >> > driver
> > >> > is v4 (or a previous version) ? I tried to remove the test for the
> > >> > presence of <GI> but it crashes later during parsing of dates,
> > >> > apparently not liking the <gml:timePosition> element within
> <lfSpanFr>
> > >> There are 2 format types (DLD / GML), 2 recent versions(v3 / v4)
> > >> and 2 (or more) data types (5/10m mesh DEM / General vector data .etc)
> > >> in FGD data,
> > >> and current mext_gdal test version seems to support the following
> pair.
> > >> 1. FGD driver: DLD v3 (5/10m mesh DEM)
> > >> 2. FG-GML driver: GML v3 (5/10m mesh DEM)
> > >> 3. FGD driver: DLD v3 (General vector data)
> > >> Above link which you found use GML v3, but it is not 5/10m mesh DEM,
> > >> so you couldn't convert it.
> > >> > I found this project :
> > >> > http://mizutuu.github.io/jpgisgmlv4togml-converter/  /
> > >> > https://github.com/mizutuu/jpgisgmlv4togml-converter
> > >> > It includes the schema for FG-GML v4 and I can't see any reference
> to
> > >> > the
> > >> > <GI> element in it either.
> > >> > With some trickery related to encoding conversion, I managed to use
> > >> > that
> > >> > project to produce a standard GML file that the OGR GML driver
> handles
> > >> > well :
> > >> > cat FG-GML-13-RailCL25000-20080331-0001.xml | iconv
> > >> > --from-code=shift-jis
> > >> > -- to-code=utf-8 | sed "s/Shift_JIS/UTF-8/" | python
> jpgisgml2gml.py >
> > >> > out.gml
> > >> And above GML v4 is not supported (both of 5/10m mesh DEM and
> > >> General vector data) by current mext_gdal for now.
> > >> > I've also found this site http://nlftp.mlit.go.jp/ksj-e/ and
> downloaded
> > >> > a
> > >> > few datasets. Those I tried are not handled by the OGR FGD driver.
> Some
> > >> > of them look like GML with a particular application schema. They are
> > >> > unfortunately not standard enough for the OGR GML driver to
> understand
> > >> > them out of the box, although I believe it could be tweaked to parse
> > >> > them. Their header look like:
> > >> > <ksj:Dataset gml:id="A09Dataset"
> > >> > xmlns:ksj="http://nlftp.mlit.go.jp/ksj/schemas/ksj-app"
> > >> > xmlns:gml="http://www.opengis.net/gml/3.2"
> > >> > xmlns:xlink="http://www.w3.org/1999/xlink" xm
> > >> > lns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> > >> > xsi:schemaLocation="http://nlftp.mlit.go.jp/ksj/schemas/ksj-app
> > >> > KsjAppSchema- A09-v3_1.xsd">
> > >> > There's a shapefile next to them, with apparently same content.
> > >> And about above MLIT NLNI(National Land Numerical Information) data,
> > >> it is not FGD data...
> > >> > So it appears there's a variety of GML-like formats ;-)
> > >> Yes, sure...
> > >> If you want to use mext_gdal test data, I just uploaded example dummy
> > >> data
> > >> to the following repository. So, please try to use those files.
> > >> https://github.com/sanak/dev-notes/tree/master/datas/fgd
> > >> (The dummy data location is near by Japan Wakayama prefecture,
> > >> but on the pacific ocean.)
> > >> Regards,
> > >> >> Hi Even,
> > >> >> I talk to Yamate-san who has been working on those three drivers.
> He
> > >> >> explained that each driver has little bit different copy right
> > >> >> background he need to resolve before he can merge them to the main.
> > >> >> The first one, FGD driver, which he wrote for a project and he does
> > >> >> not
> > >> >> have control on its copy right. So, he would like to leave it at
> this
> > >> >> moment.
> > >> >> For the second one, FG-GML driver, he wrote it and he owns its copy
> > >> >> right at this moment. But he said he can release with the licence
> you
> > >> >> suggested.
> > >> >> The last one, FGD ogr driver, which he also wrote and it is highly
> > >> >> possible he can release it under the MIT licence. But he need to
> make
> > >> >> sure his client can agree on this. So, he said he will contact to
> his
> > >> >> client.
> > >> >> So, the last two drivers can be merge into the main GDAL driver.
> It is
> > >> >> little bit confusing background but I am sure we can sort these
> out.
> > >> >> I will let you know when he is ready to work with you.
> > >> >> Thanks!
> > >> >> Hiroo
> > >> >> On Thu, Apr 30, 2015 at 2:26 PM, Hiroo Imaki <hiroo @ angeli.org>
> wrote:
> > >> >> > Hi Even,
> > >> >> > I am not the developer but he and I working at a same company.
> If he
> > >> >> > can agree on the license and release his efforts, that would be
> > >> >> > wonderful for all Japanese data uses.
> > >> >> > He hesitates writing his message in English. So, I can be a
> > >> >> > translator
> > >> >> > between you guys. I hope no lost in translation!
> > >> >> > I will get back to you once I hear from him.
> > >> >> > Hiroo
> > >> >> > On Thu, Apr 30, 2015 at 10:45 AM, Even Rouault
> > >> >> > > wrote:
> > >> >> >> Hi,
> > >> >> >> Sorry for writing in English, but I don't unfortunately speak
> > >> >> >> Japanese.
> > >> >> >> I'm one of the GDAL developers.
> > >> >> >> I've noticed that there are "un-official" versions of GDAL
> floating
> > >> >> >> around, with
> > >> >> >> a few drivers for new Japanese-specific formats. I was
> wondering if
> > >> >> >> there was a
> > >> >> >> reason to keep them outside of the official GDAL tree ?
> Integrating
> > >> >> >> them into
> > >> >> >> mainline GDAL would probably make life of Japanese users easier.
> > >> >> >> GDAL
> > >> >> >> has already support for a lof of national specific formats,
> mainly
> > >> >> >> in
> > >> >> >> Europe and
> > >> >> >> North America. Would be cool for Asia to join in ;-)
> > >> >> >> In a recent discussion thread, the following link is mentionned:
> > >> >> >>  https://www.dropbox.com/s/4oyhncknavdk2if/gdal110_test.zip
> > >> >> >> I can see that it contains 2 new GDAL drivers ( FGD: Japanese
> > >> >> >> Fundamental Geographic Data (.xml) & FG-GML :  Japanese
> Fundamental
> > >> >> >> Geographic Data GML(.xml) ) and one OGR driver (FGD).
> > >> >> >> Unfortunatelly there's no author or copyright information in the
> > >> >> >> header of the
> > >> >> >> corresponding source files. Would their author(s) be willing to
> > >> >> >> release them
> > >> >> >> under the X/MIT license and contribute them to the mainline GDAL
> > >> >> >> project ? Perhaps some test files to write minimalistic
> regressions
> > >> >> >> tests would be useful.
> > >> >> >> Let me know if I can be useful for anything. I can also help for
> > >> >> >> writing new
> > >> >> >> drivers if needed.
> > >> >> >> Best regards,
> > >> >> >> Even
> > >> >> >> Spatialys - Geospatial professional services
> > >> >> >> http://www.spatialys.com
> > >> >> >> _______________________________________________
> > >> >> >> OSGeoJapan-discuss mailing list
> > >> >> >> OSGeoJapan-discuss @ lists.osgeo.org
> > >> >> >> http://lists.osgeo.org/mailman/listinfo/osgeojapan-discuss
> > >> >> > Hiroo Imaki
> > >> >> > Pacific Spatial Solutions, LLC
> > >> >> > 1523 Chatham Colony Ct.
> > >> >> > Reston, VA  20190
> > >> >> > hiroo.imaki @ pacificspatial.com
> > >> >> > http://www.pacificspatial.com
> > >> >> > http://www.geopacific.org (GIS info site)
> > >> >> > hiroo @ angeli.org (private)
Hiroo Imaki
Reston, VA  20190
HTML$B$NE:IU%U%!%$%k$rJ]4I$7$^$7$?(B...
URL: <http://lists.osgeo.org/pipermail/osgeojapan-discuss/attachments/20150818/0d86d7ee/attachment-0001.html>
OSGeoJapan-discuss メーリングリストの案内
