[Oskari-user] Installing Oskari Map Application using EPSG:3067 as a default coordinate system
Mäkinen Sami (MML) sami.makinen at maanmittauslaitos.fi
Mon Aug 6 00:54:08 PDT 2018
If you have the GeoServer address and credentials setup in oskari-ext.properties you can delete the contents of the geoserver_data folder under Jetty to get rid of the pre-populated configuration. Then after starting Jetty go to http://localhost:8080/setup. You will see one text field and a button. Type in EPSG:3067 and click the button. This will configure GeoServer with everything Oskari needs and set the native projection. It will also advice you if you need to change something in oskari-ext.properties regarding myplaces, analysis or userlayers.
Note that after you have done this you will want to move the setup.war from under Jetty webapps so users won't be able to access it. The setup webapp is a bit experimental and not very pretty but it's the simplest way to configure GeoServer for Oskari and it's included in the download from oskari.org. Also note that it uses the GeoServer REST API for configuration and probably won't work with other GeoServer versions than the bundled one as the GS API has changed since.
Would be nice if someone developed the setup further for other aspects of Oskari as well :)
BR,
       Sami
Lähettäjä: Sanna Jokela <sanna at gispo.fi>
Lähetetty: 6. elokuuta 2018 7:55
Vastaanottaja: Keijo Kangas; Mäkinen Sami (MML)
Kopio: Oskari-user at lists.osgeo.org
Aihe: Re: [Oskari-user] Installing Oskari Map Application using EPSG:3067 as a default coordinate system
Good morning!
Has Sami some ideas on this? I have been on on vacation, so sorry for the delay in answering. I have also heard some similar problems with projections in another case, so it would be great to document this better.
Br,
Sanna
On 2 August 2018 at 11:23, Keijo Kangas <keijo.kangas at kuntotekniikka.fi<mailto:keijo.kangas at kuntotekniikka.fi>> wrote:
Hello,
I am installing Oskari Map Application using pre-installed environment with these instructions: http://oskari.org/documentation/backend/setup-jetty
However, I want to set default coordinate system to EPSG:3067 and set it to oskari-ext.properties before starting the start.jar (java -jar start.jar) but when I log in to pre-installed Geoserver I can see that the Native SRS is EPSG:4326. How can I set the default coordinate system to EPSG:3067 so that Oskari Map installation process creates oskaridb database tables and geoserver Layers compatible to EPSG:3067 coordinate system? Thank you for your help!
Keijo Kangas
+358 40 480 9035
Software developer
www.kuntotekniikka.fi<http://www.kuntotekniikka.fi/>
www.facebook.com/kuntotekniikka<http://www.facebook.com/kuntotekniikka>
Oskari-user mailing list
Oskari-user at lists.osgeo.org<mailto:Oskari-user at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/oskari-user
Sanna Jokela
paikkatietoasiantuntija
Gispo Oy
0407664607
www.gispo.fi<http://www.gispo.fi>
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180806/d0e7b8c1/attachment-0001.html>
More information about the Oskari-user mailing list
