[Oskari-user] Oskari versions & GFI
Sanna Jokela sanna at gispo.fi
Wed Jan 17 04:28:23 PST 2018
Hi all!
Can you enlighten us if there are some big changes with previous Oskari
versions vs. 1.44 version regarding GFI pop-ups?
One of our client has older version of Oskari and you can add GFI using
XSLT and utilize GeoServer templates in the GFI pop-ups. If they update
Oskari to the newer version, should they expect some changes in the admin
section when adding new interfaces?
And another question.Our client is experiencing some problems with adding
WMS-datasets from GeoServer and MapServer and we would like to know if
there is/has been some difference in Oskari how it handles different
interface facilitators or are the problems always in the interface? We are
tracking down the problems, but some seem to be related to the server side
software they are using. So just in case, if there has been issues with
Oskari in the past with handling interfaces - it would be good to know :)
Also the 1.44. release note says that it will not take the interface GFI
templates into account anymore (due to messing up with the UI).
*"Querying map features has been improved, since the infoBox style is no
longer dependent on service providers definitions (in practice all possible
style definitions in the GetFeatureInfo derived from the called WMS
interface are removed) ".*
Is it now so that it does not matter what kind of GFI templates you are
assembling when creating the interface, if you only want them to be seen
through Oskari? Or have I understood something wrong.
Thanks for the answers!
Sanna Jokela
paikkatietoasiantuntija
Gispo Oy
0407664607
www.gispo.fi
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180117/fa7285f6/attachment.html>
More information about the Oskari-user mailing list
