[Oskari-user] Oskari RPC and requesting feature info
Mäkinen Sami (MML) sami.makinen at maanmittauslaitos.fi
Thu Nov 22 03:46:59 PST 2018
At the moment you can only get click events including the feature info for features you have added with RPC (with listening to ‘MapClickedEvent’ and using getFeatures() or listening to the specific event ‘FeatureEvent’). GFI responses from WMS-layers or similar from WFS-layers aren’t accessible outside the iframe. This has been on the “wishlist” for some time so there’s interest for the feature. Just not enough for someone to actually contribute it :) Sending the data over via RPC wouldn’t be too much work, but there needs to be some way of toggling the popup functionality on and off on the map when you want to handle showing the data yourself.
         Sami
Lähettäjä: Oskari-user [mailto:oskari-user-bounces at lists.osgeo.org] Puolesta Erno Mäkinen
Lähetetty: 22. marraskuuta 2018 12:34
Vastaanottaja: oskari-user at lists.osgeo.org
Aihe: [Oskari-user] Oskari RPC and requesting feature info
If I have published and embedded an Oskari map via iframe that has, for example a WMS layer, and when user clicks on the map I can capture that event via the MapClickedEvent. However, if I would like to get information of the feature that was clicked to my Javascript code, is this possible?
The RPC MapModulePlugin.GetFeatureInfoRequest shows info box on the map for the features and if I have added vector features to the map via the RPC AddFeaturesToMapRequest I can get them via the getFeatures function. However, I would like to get info of the features that have been added via the Oskari UI and, for example, show customized popup with an image and URL link for them by using my Javascript code.
Best regards,
Erno Mäkinen
Gispo Oy
erno at gispo.fi<mailto:erno at gispo.fi> - GSM +358 50 505 7003
www.gispo.fi<http://www.gispo.fi/> - www.facebook.com/GispoFinland/<https://www.facebook.com/GispoFinland/>
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20181122/fa0b04f5/attachment.html>
More information about the Oskari-user mailing list
