[Oskari-user] Filter wms features
Mäkinen Sami (MML) sami.makinen at maanmittauslaitos.fi
Mon Oct 22 01:43:35 PDT 2018
This is not possible at the moment if you just have access to the embedded map. With an Oskari instance you control you could add parameters for layers that are always included in the calls to the service for all users (the params column on oskari_maplayers table in database). Note that it's possible to register a layer several times on an Oskari instance so you could add a layer that has the params that you need for some use as a "new layer" that is only visible to an admin user or be "creative" in a similar fashion.
          Sami
Lähettäjä: Oskari-user [mailto:oskari-user-bounces at lists.osgeo.org] Puolesta Keijo Kangas
Lähetetty: 18. lokakuuta 2018 8:39
Vastaanottaja: Oskari-user at lists.osgeo.org
Aihe: [Oskari-user] Filter wms features
Hello,
I am embedding Oskari web map to external web application and now I am interested to know is it possible to filter Geoserver wms features to Oskari web map using iframe? If I want to filter points, lines and polygons only in specific area or filter features with values between specific range?
Keijo Kangas
+358 40 480 9035
Sovelluskehittäjä
www.kuntotekniikka.fi<http://www.kuntotekniikka.fi/>
www.facebook.com/kuntotekniikka<http://www.facebook.com/kuntotekniikka>
[kt]
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20181022/d66c6ea3/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20181022/d66c6ea3/attachment.png>
More information about the Oskari-user mailing list
