[Oskari-user] Fwd: Need Help
SACHIN GUPTA sachingupta2206 at gmail.com
Thu Apr 4 20:59:11 PDT 2019
---------- Forwarded message ---------
Date: Thu, 4 Apr 2019 at 16:48
Subject: Re: [Oskari-user] Need Help
To: Aarnio Timo (MML) <timo.aarnio at maanmittauslaitos.fi>
Hi Aarnio,
Thanks for your reply and time. It will relay help me to understand the
things.
Add 1) According to your reply can I assume I need to use only RPC library,
No Oskari Backend setup, No Oskari frontend setup and no Oskari server
setup?
Add 2) You could draw the features on the map utilizing the RPC API : Is
there any function available to set map data? like init function where we
can set initial state for map.
Let me explain my requirement with a simple use case:
In my website a logedin user can see the Map screen, he can draw a polygon
and saved the map. After some time he can view the previously saved Map
with the polygon. He can edit the map and polygon.
Thanks,
Sachin
On Thu, 4 Apr 2019 at 16:10, Aarnio Timo (MML) <
timo.aarnio at maanmittauslaitos.fi> wrote:
> Hello and thank you for your interest in Oskari!
> Regarding your questions I’m afraid I cannot give you a definite answer,
> as it depends on many things. Anyway:
>    1. If you want to achieve this using an embedded map you just develop
>    the functionality/service utilizing Oskari RPC API, the RPC Example page
>    will help you get started:
>    http://oskari.org/examples/rpc-api/rpc_example.html - see e.g.
>    “Drawing requests” for learning how to be able to draw polygons and how to
>    get the polygon coordinates so that they can be saved in the DB.
>    2. Not sure what you mean by saved map, but if you refer to the
>    polygons saved in the first question this is something that can be achieved
>    in many ways. You could set up a WMS / WFS interface that serves the saved
>    data and configure that as a map layer in your Oskari instance or you could
>    draw the features on the map utilizing the RPC API.
> Hope this helps you get started!
> Kind regards,
> Timo Aarnio
> *From:* Oskari-user <oskari-user-bounces at lists.osgeo.org> *On Behalf Of *SACHIN
> GUPTA
> *Sent:* torstai 4. huhtikuuta 2019 11.38
> *To:* Oskari-user at lists.osgeo.org
> *Subject:* [Oskari-user] Need Help
> Hello,
> I want to integrate your Map service with our Angular project. I have gone
> trough the API document already. I have some quires regarding API
> implementation:
> (1) I want to display Map screen on our website in which user can draw
> some polygon and save it to our on DB. How can I do this? Is it possible to
> use only RPC client library for this purpose?
> (2) How can I display saved map? basically where I need to set let,log and
> polygon information to display previously saved map?
> Thanks,
> *Sachin Gupta *
> Willing is not enough, We must do....
*Thanks with kind Regards,*
*Sachin Gupta *
Skype: sachingupta2206
Contact No: +91 9754930813
*Sachin Gupta *
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20190405/d22e2dfc/attachment-0001.html>
More information about the Oskari-user mailing list
