[Oskari-user] Need Help
SACHIN GUPTA
sachingupta2206 at gmail.com
Mon Apr 8 01:33:53 PDT 2019
Thanks for your reply and time.
Is there any chance to get Oskari instance ( Embedded Map) without setup
the Oskari? I just want a map screen where user can draw diagram and
save/load I don't want to setup all the things on my server.
On Mon, 8 Apr 2019 at 13:45, Aarnio Timo (MML) <
timo.aarnio at maanmittauslaitos.fi> wrote:
> Hi!
> You do need to set up Oskari first unless you have an instance you can use
> to create an embedded map. If you have an existing instance that you can
> use you can just create the embedded map there and then start using the RPC
> API as instructed in the documentation.
> Guessing from your use case you might want to check the drawing request,
> handling the map state (save/load) and feature-related
> functions/requests/events. Since you want to save/load the users’ input you
> need to develop those separately and then pass data you get from the RPC
> API back and forth.
> Cheers,
> Timo
> *From:* SACHIN GUPTA <sachingupta2206 at gmail.com>
> *Sent:* torstai 4. huhtikuuta 2019 14.19
> *To:* Aarnio Timo (MML) <timo.aarnio at maanmittauslaitos.fi>
> *Subject:* Re: [Oskari-user] Need Help
> Hi Aarnio,
> Thanks for your reply and time. It will relay help me to understand the
> things.
> Add 1) According to your reply can I assume I need to use only RPC
> library, No Oskari Backend setup, No Oskari frontend setup and no Oskari
> server setup?
> Add 2) You could draw the features on the map utilizing the RPC API : Is
> there any function available to set map data? like init function where we
> can set initial state for map.
> Let me explain my requirement with a simple use case:
> In my website a logedin user can see the Map screen, he can draw a polygon
> and saved the map. After some time he can view the previously saved Map
> with the polygon. He can edit the map and polygon.
> Thanks,
> Sachin
> On Thu, 4 Apr 2019 at 16:10, Aarnio Timo (MML) <
> Hello and thank you for your interest in Oskari!
> Regarding your questions I’m afraid I cannot give you a definite answer,
> as it depends on many things. Anyway:
> 1. If you want to achieve this using an embedded map you just develop
> the functionality/service utilizing Oskari RPC API, the RPC Example page
> will help you get started:
> http://oskari.org/examples/rpc-api/rpc_example.html - see e.g.
> “Drawing requests” for learning how to be able to draw polygons and how to
> get the polygon coordinates so that they can be saved in the DB.
> 2. Not sure what you mean by saved map, but if you refer to the
> polygons saved in the first question this is something that can be achieved
> in many ways. You could set up a WMS / WFS interface that serves the saved
> data and configure that as a map layer in your Oskari instance or you could
> draw the features on the map utilizing the RPC API.
> Hope this helps you get started!
> Kind regards,
> Timo Aarnio
> *From:* Oskari-user <oskari-user-bounces at lists.osgeo.org> *On Behalf Of *SACHIN
> GUPTA
> *Sent:* torstai 4. huhtikuuta 2019 11.38
> *To:* Oskari-user at lists.osgeo.org
> *Subject:* [Oskari-user] Need Help
> Hello,
> I want to integrate your Map service with our Angular project. I have gone
> trough the API document already. I have some quires regarding API
> implementation:
> (1) I want to display Map screen on our website in which user can draw
> some polygon and save it to our on DB. How can I do this? Is it possible to
> use only RPC client library for this purpose?
> (2) How can I display saved map? basically where I need to set let,log and
> polygon information to display previously saved map?
> Thanks,
> *Sachin Gupta *
> Willing is not enough, We must do....
> *Thanks with kind Regards,*
> *Sachin Gupta *
> Skype: sachingupta2206
> Contact No: +91 9754930813
*Sachin Gupta *
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20190408/ba443dca/attachment.html>
More information about the Oskari-user
