chamelon-GRASS application site with URL
Massimiliano Cannata massimiliano.cannata at supsi.ch
Fri Sep 1 09:41:13 EDT 2006
Hi all,
I would like to inform you that a demo site is now on-line to see how
GRASS is run trough Chameleon.
For instruction on how to use it, you can click the Help button.
The URL is: http://195.176.186.207:8002/chameleon/envca/
Could you try to check if everything is working and eventually give me a
feedback?
(It could result not too fast in map loading due to the low hardware
configuration of the server)
As soon as possible I will add a page with more technical details on how
to set up such a link.
Thanks,
and hope to see you in Lausanne.
Massimiliano
Dr. Eng. Massimiliano Cannata
Responsabile Area Geomatica
Istituto Scienze della Terra
Scuola Universitaria Professionale della Svizzera Italiana
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
More information about the Ottawa_users mailing list
