[owslib-devel] WPS branch
Kyle Wilcox KWilcox at asascience.com
Tue Jun 5 08:01:33 PDT 2012
Many of tests in the owslib trunk were failing as of a few weeks ago, mostly due to deactivated OWS services that were still being referenced.
I cleaned up the tests on this fork:  https://github.com/kwilcox/owslib
The fork also adds SOS 1.0 support, basic SensorML support, and abstracts the namespace lookups to the library level.
From: Cinquini, Luca (3880) [mailto:Luca.Cinquini at jpl.nasa.gov]
Sent: Tuesday, June 05, 2012 10:56 AM
To: Tom Kralidis
Cc: <owslib-devel at lists.sourceforge.net>; <pywps-devel at wald.intevation.org>
Subject: Re: [owslib-devel] WPS branch
Hi Tom,
On Jun 3, 2012, at 3:58 PM, Tom Kralidis wrote:
Luca: great work -- thanks very much for this!  Some comments:
- can you put what you can from README_WPS.txt in owslib/wps.py (i.e. as docstring comments, etc.), or even better add these as documentation to docs/en/index.rst?
Done - I have updated index.rst with the same usage examples as some of the other modules, and transferred the whole content of README_WPS.txt at the beginning of the wps.py module
- can you merge owslib/wps_utils.py into owslib/util.py, assuming you can't use what's already in owslib/util.py (e.g. util.testXMLValue might do the same thing as wps_utils.parseText)?
Done - I was indeed able to reuse util.testXMLValue but no other function.
Having said this, we should get this into trunk sooner than later, so I'm okay with Luca committing this to trunk given the above is considered.
Great - I could merge the branch into trunk, or leave it up to someone else - let me know.
One question I have is wether the doctests currently in trunk are supposed to work - I get a whole lot of errors when I run tests/runalldoctests.py from trunk.... But maybe I am doing something wrong.
thanks, Luca
Thanks
..Tom
> From: Luca.Cinquini at jpl.nasa.gov<mailto:Luca.Cinquini at jpl.nasa.gov>
> To: jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>
> Date: Sun, 3 Jun 2012 19:38:25 +0000
> CC: owslib-devel at lists.sourceforge.net<mailto:owslib-devel at lists.sourceforge.net>; pywps-devel at wald.intevation.org<mailto:pywps-devel at wald.intevation.org>
> Hi Jachym,
> thanks, I appreciate the extra work on a Sunday...
> best regards,
> Luca
> On Jun 3, 2012, at 12:22 PM, Jachym Cepicky wrote:
> > hi,
> > thanks for submitting
> > I've tested it (up to describe-process phase ;-) ) on one of our PyWPS
> > deployments (http://apps.esdi-humboldt.cz/pywps/), it worked perfectly.
> > I like the way, the client is implemented - nice work, thanks!
> > Jachym
> > Dne 3.6.2012 13:14, Cinquini, Luca (3880) napsal(a):
> >> Hi all,
> >> I believe the WPS branch is ready for some independent testing...
> >> I merged the latest trunk into the branch. The code seems to be working well with invocations to the USGS and PML WPS services, at least the examples I tried.
> >> Good starting points for trying out the code are:
> >> o The README_WPS.txt file
> >> o The wps* examples in the examples/ directory
> >> o The wps*.txt tests in the tests/ directory
> >> o The wps-client.py program in the examples/ directory
> >> All feedback is appreciated,
> >> thanks, Luca
> >> Live Security Virtual Conference
> >> Exclusive live event will cover all the ways today's security and
> >> threat landscape has changed and how IT managers can respond. Discussions
> >> will include endpoint security, mobile security and the latest in malware
> >> threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
> >> _______________________________________________
> >> owslib-devel mailing list
> >> https://lists.sourceforge.net/lists/listinfo/owslib-devel
> > Jachym Cepicky
> > Help Service - Remote Sensing s.r.o.
> > jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com> | jachym at hsrs.cz<mailto:jachym at hsrs.cz>
> > http://les-ejk.cz | http://bnhelp.cz
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20120605/3987d66d/attachment.html>
More information about the OWSLib-devel mailing list
