[owslib-devel] owslib fork on github
Tom Kralidis tomkralidis at hotmail.com
Tue Jun 12 04:44:35 PDT 2012
FYI I have granted Kyle svn access.
Kyle: branch is https://owslib.svn.sourceforge.net/svnroot/owslib/branches/kyle-github/, trunk is https://owslib.svn.sourceforge.net/svnroot/owslib/trunk/ (be sure to be current to trunk in the branch).
Once the branch is stabilized, we can more ahead with integration into trunk.
..Tom
> From: KWilcox at asascience.com
> To: jachym.cepicky at gmail.com; Luca.Cinquini at jpl.nasa.gov
> CC: tomkralidis at hotmail.com; owslib-devel at lists.sourceforge.net; SCowan at asascience.com; derrick.snowden at noaa.gov
> Date: Mon, 11 Jun 2012 17:38:26 -0400
> Subject: RE: [owslib-devel] owslib fork on github
> I agree, this is getting out of control quickly.
> Can you grant me commit access to the kyle-github branch and I will get all of the tests passing?  It is at a good place for integration
> > -----Original Message-----
> > From: Jachym Cepicky [mailto:jachym.cepicky at gmail.com]
> > Sent: Monday, June 11, 2012 4:18 PM
> > To: Cinquini, Luca (3880)
> > Cc: Kyle Wilcox; Tom Kralidis; owslib-devel at lists.sourceforge.net; Sean
> > Cowan; derrick.snowden at noaa.gov
> > Subject: Re: [owslib-devel] owslib fork on github
> > Kyle,
> > I'm glad, the tests are working and your work is approaching well, but if you
> > will continue with the development any further, we will never be able to
> > merge your useful changes back to SVN. Even I like GIT as well and see it's
> > advantages over SVN, please accept, that SVN is *the* repository, where
> > changes are made and GIT is only mirrored. If you want your patches to be
> > submitted, please work on the svn-created branch.
> > Once you (we all) consider it "done", we can move the changes between svn
> > branches easy.
> > There was already proposal to move the main source code tree to GIT and I
> > think, once some finished release is out, nobody will be against it.
> > Till than, could you please merge your last changes back to the created svn-
> > branch, so we can evaluate the changes and put them to trunk?
> > Thanks a lot for your work!
> > Jachym
> > P.S. There might be different way, how to track changes between two version
> > systems (svn and git in this case). But I do not know any other, beside of
> > making diffs manually in one (assuming, it is synchronized regular with the
> > trunk branch (or master)) and applying them - again manually to the other
> > system. This really takes all the advantage of distributed source code
> > management out. Not speaking about fun. So if anybody is aware about some
> > automatic way how to track those changes, please speak.
> > Dne 11.6.2012 22:09, Cinquini, Luca (3880) napsal(a):
> > > Hi Kyle,
> > > On Jun 11, 2012, at 2:00 PM, Kyle Wilcox wrote:
> > >> Thanks Jachym
> > >> I just updated my 'trunk' branch on GitHub to be based on the most
> > >> recent SVN trunk (r1882)
> > >> Some of the commits to trunk in the past few days caused testing
> > >> errors so changes (additional commits) were needed
> > >> I also updated the WPS tests to go along with Tom's change to avoid parsing
> > a WPS's GetCaps on init.
> > > I actually had already updated the WPS tests in SVN trunk for the same
> > reason - it is likely to give you conflicts when merging, juts be aware...
> > > thanks, Luca
> > >> https://github.com/kwilcox/owslib/tree/trunk
> > >> 66/66 tests passing,  /me is cheering
> > >>> Sent: Sunday, June 10, 2012 3:45 PM
> > >>> To: Tom Kralidis
> > >>> Cc: Kyle Wilcox; dominic.lowe at stfc.ac.uk; owslib-
> > >>> devel at lists.sourceforge.net; derrick.snowden at noaa.gov; Sean Cowan
> > >>> Hi Tom and Kyle,
> > >>> one more commit, more stuff should be there, please check r1881
> > >>> Hope, it looks well now
> > >>> Jachym
> > >>> Dne 8.6.2012 22:34, Tom Kralidis napsal(a):
> > >>>> Kyle: Jachym applied this patch in an svn branch
> > >>> (https://owslib.svn.sourceforge.net/svnroot/owslib/branches/kyle-git
> > >>> hub/), but it appears that some files did not get through/got
> > >>> deleted/got added.
> > >>>> Anyone know of other ways to successfully apply a git patch from
> > >>>> github to
> > >>> svn?
> > >>>> Kyle's fork provides some much needed test fixes and SensorML/SOS
> > >>> additions, and overall cleanup, so any advice here would be appreciated.
> > >>>> Thanks
> > >>>> ..Tom
> > >>>> To: tomkralidis at hotmail.com; jachym.cepicky at gmail.com
> > >>>> CC: dominic.lowe at stfc.ac.uk; owslib-devel at lists.sourceforge.net;
> > >>>> derrick.snowden at noaa.gov; SCowan at asascience.com
> > >>>> Date: Wed, 6 Jun 2012 17:53:42 -0400
> > >>>> I’ve branched my code from master so it might be easier to
> > >>>> integrate into SVN.  Here are the
> > >>>> commits:https://github.com/kwilcox/owslib/commits/trunk And the
> > >>>> diff from the current SVN trunk (r1873) is here:
> > >>>> https://github.com/downloads/kwilcox/owslib/diff  From: Tom
> > >>>> Kralidis [mailto:tomkralidis at hotmail.com]
> > >>>> Sent: Wednesday, June 06, 2012 8:02 AM
> > >>>> owslib-devel at lists.sourceforge.net; derrick.snowden at noaa.gov; Sean
> > >>>> Cowan
> > >>>> Jachym: agreed, although I've had my share of issues with git diffs in svn.
> > >>>> Kyle: can you provide a diff based on current git master?
> > >>>> Thanks
> > >>>> ..Tom
> > >>>>> Date: Tue, 5 Jun 2012 20:32:37 +0200
> > >>>>> From: jachym.cepicky at gmail.com
> > >>>>> CC: kwilcox at asascience.com; dominic.lowe at stfc.ac.uk;
> > >>>>> scowan at asascience.com
> > >>>>> diff ?
> > >>>>> J
> > >>>>> Dne 5.6.2012 18:07, Tom Kralidis napsal(a):
> > >>>>>> Kyle: thanks for this valuable contribution.
> > >>>>>> Since the root codebase is on SVN, does anyone know how we can
> > >>>>>> make
> > >>> this into an SVN patch against which to review?
> > >>>>>> ..Tom
> > >>>>>>> To: dominic.lowe at stfc.ac.uk
> > >>>>>>> Date: Tue, 22 May 2012 11:23:39 -0400
> > >>>>>>> CC: owslib-devel at lists.sourceforge.net;
> > >>>>>>> Derrick.Snowden at noaa.gov; SCowan at asascience.com
> > >>>>>>> Tom pointed us at the two SOS branches in SVN and we reused what
> > >>> code was relevant. The SOS support follows the same design pattern
> > >>> as the other OWS services and should look familiar to the developers.
> > >>>>>>>> From: Dominic Lowe [mailto:dominic.lowe at stfc.ac.uk]
> > >>>>>>>> Sent: Tuesday, May 22, 2012 10:16 AM
> > >>>>>>>> To: Kyle Wilcox
> > >>>>>>>> Cc: owslib-devel at lists.sourceforge.net;
> > >>>>>>>> Derrick.Snowden at noaa.gov; Sean Cowan
> > >>>>>>>> Hi,
> > >>>>>>>> This is great, it would be good to get this merged into the trunk.
> > >>>>>>>> Tom, didn't you start work on SOS support a while back?
> > >>>>>>>> Is this a completely new implementation or does it use some of
> > >>>>>>>> the old SOS code (which was in a branch).
> > >>>>>>>> Either way, I think it would be great to add SOS support to
> > >>>>>>>> OWSLib. And cleaning up the tests is a big favour...
> > >>>>>>>> Cheers,
> > >>>>>>>> Dom
> > >>>>>>>> On 18/05/12 16:42, KWilcox at asascience.com wrote:
> > >>>>>>>>> Hello all -
> > >>>>>>>>> Thanks to funding from the NOAA IOOS Program we have been
> > able
> > >>> to
> > >>>>>>>>> do some work on owslib here: https://github.com/kwilcox/owslib
> > >>>>>>>>> Some things that are on the fork:
> > >>>>>>>>> 1.) Cleaned up the tests and made sure they are all passing
> > >>>>>>>>> 2.) Using py.test for the test runner
> > >>>>>>>>> 3.) Organized the tests and testing resources
> > >>>>>>>>> 4.) Support for SOS 1.0
> > >>>>>>>>> GetCapabilities/DescribeSensor/GetObservation
> > >>>>>>>>> Some things that are planned in the next few weeks:
> > >>>>>>>>> 5.) Support for SOS 2.0
> > >>>>>>>>> 6.) Normalize the namespace lookup library wide
> > >>>>>>>>> 7.) Abstract all of the GetCapabilitiesReader classes into a
> > >>>>>>>>> parent class (WMSCapabilitiesReader, WFSCapabilitiesReader x
> > >>>>>>>>> 3, WCSCapabilitiesReader, SosCapabilitiesReader)
> > >>>>>>>>> We would like to eventually get this merged into trunk for
> > >>>>>>>>> everyone to
> > >>>>>>>> enjoy, comments or suggestions are welcome, thanks!
> > >>>>>>>>> Live Security Virtual Conference Exclusive live event will
> > >>>>>>>>> cover all the ways today's security and threat landscape has
> > >>>>>>>>> changed and how IT managers can respond.
> > >>>>>>>>> Discussions will include endpoint security, mobile security
> > >>>>>>>>> and the latest in malware threats.
> > http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
> > >>>>>>>>> _______________________________________________
> > >>>>>>>>> owslib-devel mailing list
> > >>>>>>>>> https://lists.sourceforge.net/lists/listinfo/owslib-devel
> > >>>>>>>> Scanned by iCritical.
> > >>>>>>> Live Security Virtual Conference Exclusive live event will cover
> > >>>>>>> all the ways today's security and threat landscape has changed
> > >>>>>>> Discussions will include endpoint security, mobile security and
> > >>>>>> Exclusive live event will cover all the ways today's security and
> > >>>>>> threat landscape has changed and how IT managers can respond.
> > >>>>> Jachym Cepicky
> > >>>>> Help Service - Remote Sensing s.r.o.
> > >>>>> jachym.cepicky at gmail.com | jachym at hsrs.cz http://les-ejk.cz |
> > >>>>> http://bnhelp.cz
> > >>> Jachym Cepicky
> > >>> http://bnhelp.cz
> > >> Discussions will include endpoint security, mobile security and the
> > Jachym Cepicky
> > http://bnhelp.cz
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20120612/52eca276/attachment.html>
More information about the OWSLib-devel mailing list
