[OWSLib-devel] TMS Implementation
Christian Ledermann christian.ledermann at gmail.com
Mon Jan 28 22:05:34 PST 2013
On Tue, Jan 29, 2013 at 3:53 AM, Tom Kralidis <tomkralidis at hotmail.com> wrote:
> Merged -- thanks very much Christian!
> I notice some additions to setup.py for tests.
I used his setup for fastkml and pygeoif. I think this is the
easiest way from an end users point of view. Just run
# python setup.py test
> The codebase is in desperate
> need of some testing setup, like getting this hooked up to travis-ci, etc.
with the setup.py test approach most test fail currently (tms.txt passes :p ):
Ran 35 tests in 97.818s
FAILED (failures=31)
some of the failures are because the url changed or the service
is not available,  others because the file could not be found.
> On the todo list, contributions welcome.
>> Date: Mon, 28 Jan 2013 13:40:45 +0300
>> Subject: Re: [OWSLib-devel] TMS Implementation
>> From: christian.ledermann at gmail.com
>> To: tomkralidis at hotmail.com
>> CC: owslib-devel at lists.osgeo.org
>> https://github.com/geopython/OWSLib/pull/50
>> On Fri, Jan 11, 2013 at 4:56 PM, Christian Ledermann
>> <christian.ledermann at gmail.com> wrote:
>> > I want to do some more testing and add some features first
>> > @list: if you have some wishes what features should
>> > be implemented (and how) please add at
>> > https://github.com/geopython/OWSLib/issues/48
>> > On Fri, Jan 11, 2013 at 4:47 PM, Tom Kralidis <tomkralidis at hotmail.com>
>> > wrote:
>> >>> Date: Fri, 11 Jan 2013 08:55:13 +0300
>> >>> On Thu, Jan 10, 2013 at 8:31 PM, Tom Kralidis
>> >>> wrote:
>> >>> > Christian: thanks for the info. Yes indeed please issue a PR I think
>> >>> > this is
>> >>> > a valuable addition!
>> >> Thanks -- I can't see the PR on GitHub, can you send a pull request?
>> > Best Regards,
>> > Christian Ledermann
>> > Nairobi - Kenya
>> > Mobile : +254 702978914
>> > If you save the living environment, the biodiversity that we have left,
>> > you will also automatically save the physical environment, too. But If
>> > you only save the physical environment, you will ultimately lose both.
>> > 1) Don’t drive species to extinction
>> > 2) Don’t destroy a habitat that species rely on.
>> > 3) Don’t change the climate in ways that will result in the above.
>> Best Regards,
>> Christian Ledermann
>> Nairobi - Kenya
Best Regards,
Christian Ledermann
Nairobi - Kenya
More information about the OWSLib-devel mailing list
