[owslib-users] owslib and CSW authentication
Tom Kralidis tomkralidis at hotmail.com
Sat Feb 11 13:02:30 PST 2012
FYI this has been implemented in svn trunk.  Example http://owslib.sourceforge.net/#csw (see Authentication).
..Tom
> From: ricardo.garcia.silva at gmail.com
> Date: Fri, 10 Feb 2012 16:04:47 +0000
> To: owslib-users at lists.sourceforge.net
> Subject: Re: [owslib-users] owslib and CSW authentication
> OK, I'll look for another solution, but I'll keep an eye on the
> progress of this feature.
> Thank you
> On Fri, Feb 10, 2012 at 3:53 PM, Tom Kralidis <tomkralidis at hotmail.com> wrote:
> >> Date: Fri, 10 Feb 2012 15:50:03 +0000
> >> Subject: [owslib-users] owslib and CSW authentication
> >> Hello list
> >> I'm new to owslib and I'm also still finding my way through the CSW
> >> and XML metadata jungle, so please bear with me.
> >> I want to use owslib for inserting records to my csw server, but I
> >> can't seem to insert them unless I am authenticated.
> >> I've skimmed through the documentation available on [1] and tried to
> >> insert my data in the csw server with the following commands:
> >> csw = CatalogueServiceWeb('private server url')
> >> xmlFile = 'path_to_xml_file'
> >> csw.transaction(ttype='insert', typename='gmd:MD_Metadata',
> >> record=open(xmlFile).read())
> >> print(csw.response)
> >> <?xml version="1.0" encoding="UTF-8"?>
> >> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows"
> >> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0"
> >> xsi:schemaLocation="http://www.opengis.net/ows
> >> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd">
> >>   <ows:Exception exceptionCode="NoApplicableCode">
> >>     <ows:ExceptionText>Cannot process transaction: User not
> >> authenticated.</ows:ExceptionText>
> >>   </ows:Exception>
> >> </ows:ExceptionReport>
> >> So, how can I authenticate with the server?
> >> Thanks in advance
> >> [1] - http://owslib.sourceforge.net/#csw
> > FYI there is an open ticket on this issue (https://sourceforge.net/apps/trac/owslib/ticket/7), which I'm hoping to get to in the week or so.
> > ..Tom
> ___________________________ ___ __
> Ricardo Garcia Silva
> Virtualization & Cloud Management Using Capacity Planning
> Cloud computing makes use of virtualization - but cloud computing
> also focuses on allowing computing to be delivered as a service.
> http://www.accelacomm.com/jaw/sfnl/114/51521223/
> owslib-users mailing list
> https://lists.sourceforge.net/lists/listinfo/owslib-users
More information about the Owslib-users mailing list
