[OWSLib-users] WCS Cookie Generation [SEC=UNCLASSIFIED]
Dominic Lowe D.Lowe at bom.gov.au
Thu May 16 16:26:16 PDT 2013
It's been a while since I've used this but try passing your cookie as a parameter to WebCoverageService:
i.e. myWCS=WebCoverageService(myurl, version='1.X.X', cookies='mysessiontoken=123abc')
(I think you just pass a string if I remember rightly)
As to where/how the cookie is generated that is application specific so can't really help much...
Cheers,
Dom
From: owslib-users-bounces at lists.osgeo.org [mailto:owslib-users-bounces at lists.osgeo.org] On Behalf Of Iñigo Hernáez Corres
Sent: Thursday, 16 May 2013 10:36 PM
To: owslib-users at lists.osgeo.org
Subject: [OWSLib-users] WCS Cookie Generation
Hello everybody,
My name is Iñigo Hernáez. In my job, we use OWSLib to retrieve geospatial data from a server. To download geotiff files we need to use the WebCoverageService function. However this needs a session cookie to work properly, but there is not enough information in the documentation on how to do this.
How is the cookie generated with the user credentials? How is it then used in the WCS function?
Thanks in advanced for your time!
email: ihernaez at adasasistemas.com<mailto:ihernaez at adasasistemas.com>
tlf: (+34) 945 064483
C/Portal de Foronda, 41
01010, Vitoria-Gasteiz
Maintenance & Logistics Services (M&LS)
José Agustín Goytisolo, 30-32
08908 L'Hospitalet de Llobregat - Barcelona
T. (+34) 93 264 06 02
F. (+34) 93 264 06 56
www.comsaemte.com<https://correo.adasasistemas.com/owa/UrlBlockedError.aspx>
No imprimir si no es necesario. Protejamos el Medio Ambiente.
Please consider the environment before printing this email.
Este mensaje, y en su caso cualquier fichero anexo al mismo, es sólo para el destinatario a quien va dirigido y puede contener información privilegiada, profesional o privada. Si lo ha recibido por error, por favor notifíquelo inmediatamente el remitente y elimine el original. Cualquier otro uso que haga de este mensaje está prohibido.
This message and its attachments, if any, is solely for the attention of the addressee and may contain privileged confidential information of a professional or other nature. If you have received this message by mistake, please notify the senderimmediately and delete the original. It is prohibited to use this message for any other purpose.
URL: <http://lists.osgeo.org/pipermail/owslib-users/attachments/20130517/4ffc2c41/attachment.html>
More information about the OWSLib-users mailing list
