[OWSLib-users] OWSlib - CSW metadata
Tom Kralidis tomkralidis at gmail.com
Fri Sep 9 12:04:46 PDT 2016
On Fri, 9 Sep 2016, Henrik Schuller wrote:
> Date: Fri, 9 Sep 2016 15:11:10 +0200
> From: Henrik Schuller <hgs716 at gmail.com>
> To: Tom Kralidis <tomkralidis at gmail.com>, owslib-users at lists.osgeo.org
> Subject: Re: [OWSLib-users] OWSlib - CSW metadata
> Thx alot Tom, now i got alot more information out of the CSW :)
> Maybe just me that is inexperienced, but how do i get information out of
> objects like the ones i get here:
> from owslib.csw import CatalogueServiceWeb
> csw = CatalogueServiceWeb('http://www.geonorge.no/geonetwork/srv/nor/csw-service?')
> csw.getrecords2(typenames='gmd:MD_Metadata', esn='full', resulttype="results",
>                outputschema="http://www.isotc211.org/2005/gmd", maxrecords=50)
> for rec in csw.records:
>    print((csw.records[rec].identification.contact))
Your best bet is to inspect OWSLib's ISO implementation [1] to see how we parse the XML
into Python objects.
[1] https://github.com/geopython/OWSLib/blob/master/owslib/iso.py
> From Henrik
> 2016-09-09 12:55 GMT+02:00 Tom Kralidis <tomkralidis at gmail.com>:
>> Date: Fri, 9 Sep 2016 12:57:24 +0200
>>> To: OWSLib-users at lists.osgeo.org
>>> Subject: [OWSLib-users] OWSlib - CSW metadata
>>> Hi,
>>> I am using OWSlib to GetRecords from a CSW
>>> (*http://www.geonorge.no/geonetwork/srv/nor/csw-service
>>> <http://www.geonorge.no/geonetwork/srv/nor/csw-service>*, but I would
>>> like
>>> to get more information about the records than what is given in dublin
>>> core. Is there any easy way that I could get information like
>>> gmd:individualName or srv:operatesOn for every record?
>>> I can see that this information is available in OWSlib - iso, but I don't
>>> see an easy way to implement it for the csw.records.
>> Try doing the getrecords2 request using ISO as the outputschema (Dublin
>> Core
>> is default):
>> nor/csw-service')
>> csw.getrecords2(outputschema='http://www.isotc211.org/2005/gmd')
>> The CSW will then return the ISO representation of matching metadata
>> records.
>> Hope this helps
>> ..Tom
>>> Henrik
More information about the OWSLib-users mailing list
