[OWSLib-users] easy_install OWSLib failed
Chiarello Ernest Ernest.Chiarello at univ-fcomte.fr
Thu Sep 15 06:11:40 PDT 2016
wonderful, it works !
# easy_install OWSLib
Searching for OWSLib
Best match: OWSLib 0.12.0
Adding OWSLib 0.12.0 to easy-install.pth file
thanks Kyle.
Ernest.
Le 15/09/2016 à 15:01, Kyle Wilcox a écrit :
> Hi Chiarello -
> Can you install the `python-dev` debian package and give it another shot?
> On Thu, Sep 15, 2016 at 6:51 AM Chiarello Ernest
> <Ernest.Chiarello at univ-fcomte.fr
> <mailto:Ernest.Chiarello at univ-fcomte.fr>> wrote:
>     Hello Tom,
>     many thanks for the new version of owslib !
>     however, installation fails with this message :
>     _proj.c:4:20: fatal error: Python.h: Aucun fichier ou dossier de
>     ce type
>       #include "Python.h"
>     compilation terminated.
>     all-CgORao/pyproj-1.9.5.1/nad2bin lib/pyproj/data/alaska <
>     datumgrid/alaska.llaexecuting
>     /tmp/easy_install-CgORao/pyproj-1.9.5.1/nad2bin lib/pyproj/data/FL <
>     datumgrid/FL.llaexecuting
>     /tmp/easy_install-CgORao/pyproj-1.9.5.1/nad2bin lib/pyproj/data/MD <
>     datumgrid/MD.llaerror: Setup script exited with error: command
>     'x86_64-linux-gnu-gcc' failed with exit status 1
>     my env :
>     # uname -ra
>     Linux georchestra-dev 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u1
>     (2016-09-03) x86_64 GNU/Linux
>     # dpkg --list | grep python
>     ii  libpython-stdlib:amd64 2.7.9-1                     amd64
>     interactive high-level object-oriented language (default python
>     version)
>     ii  libpython2.7-minimal:amd64 2.7.9-2  amd64
>     Minimal subset of the Python language (version 2.7)
>     ii  libpython2.7-stdlib:amd64 2.7.9-2  amd64
>     Interactive high-level object-oriented language (standard library,
>     version 2.7)
>     ii  python 2.7.9-1                     amd64 interactive
>     high-level object-oriented language (default version)
>     ii  python-apt 0.9.3.12                    amd64        Python
>     interface
>     to libapt-pkg
>     ii  python-apt-common 0.9.3.12                    all Python
>     interface to libapt-pkg (locales)
>     ii  python-cffi 0.8.6-1                     amd64 Foreign
>     Function Interface for Python calling C code
>     ii  python-chardet 2.3.0-1                     all universal
>     character encoding detector for Python2
>     ii  python-colorama 0.3.2-1                     all
>     Cross-platform colored terminal text in Python - Python 2.x
>     ii  python-cryptography 0.6.1-1                     amd64   Python
>     library exposing cryptographic recipes and primitives (Python 2)
>     ii  python-debian 0.1.27                      all Python
>     modules to work with Debian-related data formats
>     ii  python-debianbts 1.12                        all Python
>     interface to Debian's Bug Tracking System
>     ii  python-defusedxml 0.4.1-2                     all XML bomb
>     protection for Python stdlib modules (for Python 2)
>     ii  python-distlib 0.1.9-1                     all low-level
>     components of python distutils2/packaging
>     ii  python-docutils 0.12+dfsg-1                 all text
>     processing system for reStructuredText (implemented in Python 2)
>     ii  python-egenix-mxdatetime 3.2.8-1                     amd64
>     date and time handling routines for Python
>     ii  python-egenix-mxtools 3.2.8-1                     amd64
>     collection of additional builtins for Python
>     ii  python-html5lib 0.999-3                     all HTML
>     parser/tokenizer based on the WHATWG HTML5 specification (Python 2)
>     ii  python-ldap 2.4.10-1                    amd64        LDAP
>     interface
>     module for Python
>     ii  python-lxml 3.4.0-1                     amd64 pythonic
>     binding for the libxml2 and libxslt libraries
>     ii  python-minimal 2.7.9-1                     amd64 minimal
>     subset of the Python language (default version)
>     ii  python-ndg-httpsclient 0.3.2-1                     all
>     enhanced HTTPS support for httplib and urllib2 using PyOpenSSL
>     ii  python-openssl 0.14-1                      all Python 2
>     wrapper around the OpenSSL library
>     ii  python-pip 1.5.6-5                     all alternative
>     Python package installer
>     ii  python-pkg-resources 5.5.1-1                     all
>     Package Discovery and Resource Access using pkg_resources
>     ii  python-ply 3.4-5                       all          Lex and Yacc
>     implementation for Python2
>     ii  python-psycopg2 2.5.4+dfsg-1                amd64 Python
>     module for PostgreSQL
>     ii  python-pyasn1 0.1.7-1                     all ASN.1 library
>     for Python (Python 2 module)
>     ii  python-pycparser 2.10+dfsg-3                 all C parser
>     in Python
>     ii  python-reportbug 6.6.3                       all Python
>     modules for interacting with bug tracking systems
>     ii  python-requests 2.4.3-6                     all elegant and
>     simple HTTP library for Python2, built for human beings
>     ii  python-roman 2.0.0-1                     all module for
>     generating/analyzing Roman numerals for Python 2
>     ii  python-setuptools 5.5.1-1                     all Python
>     Distutils Enhancements
>     ii  python-six 1.8.0-1                     all          Python 2 and 3
>     compatibility library (Python 2 interface)
>     ii  python-soappy 0.12.22-1                   all SOAP Support
>     for Python
>     ii  python-support 1.0.15                      all automated
>     rebuilding support for Python modules
>     ii  python-urllib3 1.9.1-3                     all HTTP library
>     with thread-safe connection pooling for Python
>     ii  python-wheel 0.24.0-1                    all built-package
>     format for Python
>     ii  python-wstools 0.4.3-2                     all WSDL parsing
>     tools Python module
>     ii  python2.7 2.7.9-2                     amd64 Interactive
>     high-level object-oriented language (version 2.7)
>     ii  python2.7-minimal 2.7.9-2                     amd64 Minimal
>     what is missing ?
>     thanks in advance,
>     Ernest.
>     Ernest CHIARELLO  - Ernest.Chiarello at univ-fcomte.fr
>     UMR6049 ThéMA - Théoriser et Modéliser pour Aménager
>     CNRS / université de Bourgogne Franche-Comté
>     32 rue Mégevand 25030 BESANÇON Cedex
>     Tel : 03 81 66 54 80           Mob : 07 82 99 11 08
>     _______________________________________________
>     OWSLib-users mailing list
>     OWSLib-users at lists.osgeo.org <mailto:OWSLib-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/owslib-users
URL: <http://lists.osgeo.org/pipermail/owslib-users/attachments/20160915/b3960e6a/attachment-0001.html>
More information about the OWSLib-users mailing list
