[Pacific] Fwd:[postgis-devel] PostGIS 2.1.0 released
Edwin Liava'a liavaa.edwin at gmail.com
Mon Aug 19 12:15:24 PDT 2013
Hi All,
Forwarding here latest release of PostGIS 2.1.0 read on for more information.
cheers,
Edwin
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org [mailto:postgis-devel-
> bounces at lists.osgeo.org] On Behalf Of Paragon Corporation
> Sent: Saturday, August 17, 2013 9:46 PM
> To: 'PostGIS Development Discussion'; 'PostGIS Users Discussion'
> Subject: [postgis-devel] PostGIS 2.1.0 released
> The 2.1.0 release of PostGIS is now available.
> http://download.osgeo.org/postgis/source/postgis-2.1.0.tar.gz
> The PostGIS development team is proud to release PostGIS 2.1.0. As befits a
> minor release, the focus is on speed improvements, more features, and bug
> fixes.
> If you are currently using PostGIS 2.0+, you can go the soft upgrade path:
> ALTER EXTENSION postgis UPDATE TO "2.1.0";
> If you are running 2.1.0 of beta or an unreleased version (and the above
> step fails with error "extension postgis has no update path from version
> x.x.x to version 2.1.0") , you need to first copy the file in
> share\extensions\postgis-2.0.3-2.1.0.sql and change the 2.0.3 to the x.x.x
> noted in the error you are running. Then follow the above upgrade step
> again.
> Users of 1.5 and below will need to go the hard-upgrade path documented
> in
> manual:
> http://postgis.net/docs/manual-2.1/postgisinstallation.html#hardupgrade
> Best served with a bottle of GEOS 3.4.1 and PostgreSQL 9.3beta2 (planned
> 9.1.0 release is September).
> html doc: http://download.osgeo.org/postgis/docs/doc-html-2.1.0.tar.gz
> pdf doc: http://download.osgeo.org/postgis/docs/postgis-2.1.0.pdf
> epub doc: http://download.osgeo.org/postgis/docs/postgis-2.1.0.epub
> This release contains a ton of speed improvements, function additions, and
> super sexy new features. It has been over a year in the making.
> New functions itemized in
> 2.1/PostGIS_Special_Functions_Index.html#NewF
> unctions21
> Important / Breaking Changes
>     #1653, Removed srid parameter from ST_Resample(raster) and variants
> with
> reference raster no longer apply reference raster's SRID.
>     #1962 ST_Segmentize* As a result of the introduction of geography
> support, The construct: SELECT ST_Segmentize('LINESTRING(1 2, 3 4)',0.5);
> will result in ambiguous function error
>     #2026, ST_Union(raster) now unions all bands of all rasters
>     #2089, liblwgeom: lwgeomsethandlers replaces lwgeominitallocators.
>     #2150, regularblocking is no longer a constraint. column of same name in
> rastercolumns now checks for existance of spatiallyunique and coveragetile
> constraints
>     ST_Intersects(raster, geometry) behaves in the same manner as
> ST_Intersects(geometry, raster).
>     point variant of ST_SetValue(raster) previously did not check SRID of
> input geometry and raster.
>     ST_Hillshade parameters azimuth and altitude are now in degrees instead
> of radians.
>     ST_Slope and ST_Aspect return pixel values in degrees instead of
> radians.
> Deprecated signatures
>     #2104, ST_World2RasterCoord, ST_World2RasterCoordX and
> ST_World2RasterCoordY renamed to ST_WorldToRasterCoord,
> ST_WorldToRasterCoordX and ST_WorldToRasterCoordY.
> ST_Raster2WorldCoord,
> ST_Raster2WorldCoordX and ST_Raster2WorldCoordY renamed to
> ST_RasterToWorldCoord, ST_RasterToWorldCoordX and
> ST_RasterToWorldCoordY
>     ST_Estimated_Extent renamed to ST_EstimatedExtent
>     ST_LineInterpolatePoint renamed to ST_LineInterpolatePoint
>     ST_Line_Substring renamed to ST_LineSubstring
>     ST_LineLocatePoint renamed to ST_LineLocatePoint
>     ST_Force_XXX renamed to ST_ForceXXX
>     ST_MapAlgebraFctNgb and 1 and 2 raster variants of ST_MapAlgebraFct.
> Use
> ST_MapAlgebra instead
>     1 and 2 raster variants of ST_MapAlgebraExpr. Use expression variants of
> New Features
>         #310, ST_DumpPoints converted to a C function - much faster (Nathan
> Wagner)
>         #739, UpdateRasterSRID()
>         #945, improved join selectivity, N-D selectivity calculations, user
> accessible selectivity and stats reader functions for testing (Paul Ramsey /
> OpenGeo)
>         toTopoGeom with TopoGeometry sink (Sandro Santilli / Vizzuality)
>         clearTopoGeom (Sandro Santilli / Vizzuality)
>         ST_Segmentize(geography) (Paul Ramsey / OpenGeo)
>         ST_DelaunayTriangles (Sandro Santilli / Vizzuality)
>         ST_NearestValue, ST_Neighborhood (Bborie Park / UC Davis)
>         ST_PixelAsPoint, ST_PixelAsPoints (Bborie Park / UC Davis)
>         ST_PixelAsCentroid, ST_PixelAsCentroids (Bborie Park / UC Davis)
>         ST_Raster2WorldCoord, ST_World2RasterCoord (Bborie Park / UC
> Davis)
>         Additional raster/raster spatial relationship functions
> (ST_Contains, ST_ContainsProperly, ST_Covers, ST_CoveredBy, ST_Disjoint,
> ST_Overlaps, ST_Touches, ST_Within, ST_DWithin, ST_DFullyWithin) (Bborie
> Park / UC Davis)
>         Added array variants of ST_SetValues() to set many pixel values of a
> band in one call (Bborie Park / UC Davis)
>         #1293, ST_Resize(raster) to resize rasters based upon width/height
>         #1627, package tiger_geocoder as a PostgreSQL extension
>         #1643, #2076, Upgrade tiger geocoder to support loading tiger 2011
> and 2012 (Regina Obe / Paragon Corporation) Funded by Hunter Systems
> Group
>         GEOMETRYCOLLECTION support for ST_MakeValid (Sandro Santilli /
> Vizzuality)
>         #1709, ST_NotSameAlignmentReason(raster, raster)
>         #1818, ST_GeomFromGeoHash and friends (Jason Smith (darkpanda))
>         #1856, reverse geocoder rating setting for prefer numbered highway
> name
>         ST_PixelOfValue (Bborie Park / UC Davis)
>         Casts to/from PostgreSQL geotypes (point/path/polygon).
>         Added geomval array variant of ST_SetValues() to set many pixel
> values of a band using a set of geometries and corresponding values in one
>         ST_Tile(raster) to break up a raster into tiles (Bborie Park / UC
> Davis)
>         #1895, new r-tree node splitting algorithm (Alex Korotkov)
>         #2011, ST_DumpValues to output raster as array (Bborie Park / UC
> Davis)
>         #2018, ST_Distance support for CircularString, CurvePolygon,
> MultiCurve, MultiSurface, CompoundCurve
>         #2030, n-raster (and n-band) ST_MapAlgebra (Bborie Park / UC Davis)
>         #2193, Utilize PAGC parser as drop in replacement for tiger
> normalizer (Steve Woodbridge, Regina Obe)
>         #2210, ST_MinConvexHull(raster)
>         lwgeomfromgeojson in liblwgeom (Sandro Santilli / Vizzuality)
>         #1687, ST_Simplify for TopoGeometry (Sandro Santilli / Vizzuality)
>         #2228, TopoJSON output for TopoGeometry (Sandro Santilli /
> Vizzuality)
>         #2123, ST_FromGDALRaster
>         #613, ST_SetGeoReference with numerical parameters instead of text
>         #2276, ST_AddBand(raster) variant for out-db bands
>         #2280, ST_Summary(raster)
>         #2163, ST_TPI for raster (Nathaniel Clay)
>         #2164, ST_TRI for raster (Nathaniel Clay)
>         #2302, ST_Roughness for raster (Nathaniel Clay)
>         #2290, ST_ColorMap(raster) to generate RGBA bands
>         #2254, Add SFCGAL backend support. (Backend selection throught
> postgis.backend var) Functions available both throught GEOS or SFCGAL:
> ST_Intersects, ST_3DIntersects, ST_Intersection, ST_Area, ST_Distance,
> ST_3DDistance New functions available only with SFCGAL backend:
> ST_3DIntersection, ST_Tesselate, ST_3DArea, ST_Extrude, ST_ForceLHR
> ST_Orientation, ST_Minkowski, ST_StraightSkeleton postgissfcgalversion
> New
> function available in PostGIS: ST_ForceSFS (Olivier Courtin and Hugo
> Mercier
> / Oslandia)
> Enhancements
>     #823, tiger geocoder: Make loadergeneratescript download portion less
> greedy
>     #826, raster2pgsql no longer defaults to padding tiles. Flag -P can be
> used to pad tiles
>     #1363, ST_AddBand(raster, .) array version rewritten in C
>     #1364, ST_Union(raster, .) aggregate function rewritten in C
>     #1655, Additional default values for parameters of ST_Slope
>     #1661, Add aggregate variant of ST_SameAlignment
>     #1719, Add support for Point and GeometryCollection ST_MakeValid
> inputs
>     #1780, support ST_GeoHash for geography
>     #1796, Big performance boost for distance calculations in geography
>     #1802, improved function interruptibility.
>     #1823, add parameter in ST_AsGML to use id column for GML 3 output
> (become mandatory since GML 3.2.1)
>     #1856, tiger geocoder: reverse geocoder rating setting for prefer
> numbered highway name
>     #1938, Refactor basic ST_AddBand to add multiple new bands in one call
>     #1978, wrong answer when calculating length of a closed circular arc
> (circle)
>     #1989, Preprocess input geometry to just intersection with raster to be
> clipped
>     #2021, Added multi-band support to ST_Union(raster, .) aggregate
> function
>     #2006, better support of ST_Area(geography) over poles and dateline
>     #2065, ST_Clip(raster, .) now a C function
>     #2069, Added parameters to ST_Tile(raster) to control padding of tiles
>     #2078, New variants of ST_Slope, ST_Aspect and ST_HillShade to provide
> solution to handling tiles in a coverage
>     #2097, Added RANGE uniontype option for ST_Union(raster)
>     #2105, Added ST_Transform(raster) variant for aligning output to
> reference raster
>     #2119, Rasters passed to ST_Resample(), ST_Rescale(), ST_Reskew(), and
> ST_SnapToGrid() no longer require an SRID
>     #2141, More verbose output when constraints fail to be added to a
> raster
> column
>     #2143, Changed blocksize constraint of raster to allow multiple values
>     #2148, Addition of coverage_tile constraint for raster
>     #2149, Addition of spatially_unique constraint for raster
>     TopologySummary output now includes unregistered layers and a count
> of
> missing TopoGeometry objects from their natural layer.
>     ST_HillShade(), ST_Aspect() and ST_Slope() have one new optional
> parameter to interpolate NODATA pixels before running the operation.
>     Point variant of ST_SetValue(raster) is now a wrapper around geomval
> variant of ST_SetValues(rast).
>     Proper support for raster band's isnodata flag in core API and loader.
>     Additional default values for parameters of ST_Aspect and ST_HillShade
>     #2178, ST_Summary now advertises presence of known srid with an [S]
> flag
>     #2202, Make libjson-c optional (-without-json configure switch)
>     #2213, Add support libjson-c 0.10+
>     #2231, raster2pgsql supports user naming of filename column with -n
>     #2200, ST_Union(raster, uniontype) unions all bands of all rasters
>     #2264, postgis_restore.pl support for restoring into databases with
> postgis in a custom schema
>     #2244, emit warning when changing raster's georeference if raster has
> out-db bands
>     #2222, add parameter OutAsIn to flag whether ST_AsBinary should
> return
> out-db bands as in-db bands
> Fixes
>     #1839, handling of subdatasets in GeoTIFF in raster2pgsql.
>     #1840, fix logic of when to compute # of tiles in raster2pgsql.
>     #1870, align the docs and actual behavior of raster's ST_Intersects
>     #1872, fix ST_ApproxSummarystats to prevent division by zero
>     #1875, ST_SummaryStats returns NULL for all parameters except count
> when
> count is zero
>     #1932, fix raster2pgsql of syntax for index tablespaces
>     #1936, ST_GeomFromGML on CurvePolygon causes server crash
>     #1939, remove custom data types: summarystats, histogram, quantile,
> valuecount
>     #1951, remove crash on zero-length linestrings
>     #1957, ST_Distance to a one-point LineString returns NULL
>     #1976, Geography point-in-ring code overhauled for more reliability
>     #1981, cleanup of unused variables causing warnings with gcc 4.6+
>     #1996, support POINT EMPTY in GeoJSON output
>     #2062, improve performance of distance calculations
>     #2057, Fixed linking issue for raster2psql to libpq
>     #2077, Fixed incorrect values returning from ST_Hillshade()
>     #2019, ST_FlipCoordinates does not update bbox
>     #2100, ST_AsRaster may not return raster with specified pixel type
>     #2126, Better handling of empty rasters from ST_ConvexHull()
>     #2165, ST_NumPoints regression failure with CircularString
>     #2168, ST_Distance is not always commutative
>     #2182, Fix issue with outdb rasters with no SRID and ST_Resize
>     #2188, Fix function parameter value overflow that caused problems
> when
> copying data from a GDAL dataset
>     #2198, Fix incorrect dimensions used when generating bands of out-db
> rasters in ST_Tile()
>     #2201, ST_GeoHash wrong on boundaries
>     #2203, Changed how rasters with unknown SRID and default
> geotransform
> are handled when passing to GDAL Warp API
>     #2215, Fixed raster exclusion constraint for conflicting name of
> implicit index
>     #2251, Fix bad dimensions when rescaling rasters with default
> geotransform matrix
>     #2133, Fix performance regression in expression variant of
> ST_MapAlgebra
>     #2257, GBOX variables not initialized when testing with empty
> geometries
>     #2271, Prevent parallel make of raster
>     #2282, Fix call to undefined function ndstatsto_grid() in debug mode
>     #2307, ST_MakeValid outputs invalid geometries
>     #2309, Remove confusing INFO message when trying to get SRS info
>     #2336, FIPS 20 (KS) causes wildcard expansion to wget all files
>     #2348, Provide raster upgrade path for 2.0 to 2.1
>     #2351, ST_distance between geographies wrong
>     #2359, Fix handling of schema name when adding overview constraints
>     #2371, Support GEOS versions with more than 1 digit in micro
>     #2383, Remove unsafe use of ' from raster warning message
>     #2384, Incorrect variable datatypes for ST_Neighborhood
> Known Issues
>     #2111, Raster bands can only reference the first 256 bands of out-db
> rasters
> Happy querying,
> Team PostGIS
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
More information about the pacific-islands mailing list
