[Pacific] Fwd: [postgis-users] PostGIS 2.1.4 release
Edwin Liava'a liavaa.edwin at gmail.com
Wed Sep 10 21:38:53 PDT 2014
Hi All,
Please find here latest release of PostGIS 2.1.4 a patch release, the
focus is on bugs, breakages, and performance issues
cheers,
Ed
---------- Forwarded message ----------
Date: Wed, 10 Sep 2014 23:33:08 -0400
Subject: [postgis-users] PostGIS 2.1.4 release
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>, PostGIS
Development Discussion <postgis-devel at lists.osgeo.org>
The 2.1.4 release of PostGIS is now available.
The PostGIS development team is happy to release patch for PostGIS 2.1, the
2.1.4 release. As befits a patch release, the focus is on bugs, breakages,
Download source code here:
http://download.osgeo.org/postgis/source/postgis-2.1.4.tar.gz
Html docs: http://download.osgeo.org/postgis/docs/doc-html-2.1.4.tar.gz  ,
PDF docs: http://download.osgeo.org/postgis/docs/postgis-2.1.4.pdf
Enhancements
    #2745, Speedup ST_Simplify calls against points
    #2747, Support for GDAL 2.0
    #2749, Make rtpostgisupgrade20_21.sql ACID
    #2811, Do not specify index names when loading shapefiles/rasters
    #2829, Shortcut ST_Clip(raster) if geometry fully contains the raster
and no NODATA specified
    #2895, Raise cost of ST_ConvexHull(raster) to 300 for better query plans
Bug Fixes
    #2605, armel: _ST_Covers() returns true for point in hole
    #2911, Fix output scale on ST_Rescale/ST_Resample/ST_Resize of rasters
with scale 1/-1 and offset 0/0.
        Fix crash in ST_Union(raster)
    #2704, ST_GeomFromGML() does not work properly with array of gml:pos
(Even Roualt)
    #2708, updategeometrysrid doesn't update srid check when schema not
specified. Patch from Marc Jansen
    #2720, lwpolyaddring should update maxrings after realloc
    #2759, Fix postgis_restore.pl handling of multiline object comments
embedding sql comments
    #2774, fix undefined behavior in ptarraycalculategbox_geodetic
        Fix potential memory fault in ST_MakeValid
    #2784, Fix handling of bogus argument to -with-sfcgal
    #2772, Premature memory free in RASTER_getBandPath (ST_BandPath)
    #2755, Fix regressions tests against all versions of SFCGAL
    #2775, lwlinefromlwmpoint leaks memory
    #2802, ST_MapAlgebra checks for valid callback function return value
    #2803, ST_MapAlgebra handles no userarg and STRICT callback function
    #2834, ST_Estimated_Extent and mixedCase table names (regression bug)
    #2845, Bad geometry created from ST_AddPoint
    #2870, Binary insert into geography column results geometry being
inserted
    #2872, make install builds documentation (Greg Troxell)
    #2819, find isfinite or replacement on Centos5 / Solaris
    #2899, geocode limit 1 not returning best answer (tiger geocoder)
    #2903, Unable to compile on FreeBSD
    #2927 reverse_geocode not filling in direction prefix (tiger geocoder)
get rid of deprecated ST_Line_Locate_Point called
For more details refer to:
http://trac.osgeo.org/postgis/query?status=closed&groupdesc=1&group=priority
&milestone=PostGIS+2.1.4&order=priority
Happy PostGISsing,
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
More information about the pacific-islands mailing list
