[pal-developer] scale
Maxence Laurent maxence.laurent at heig-vd.ch
Mon Aug 16 02:19:02 EDT 2010
The scale is used in two way.
The scale is used to define the "availability" of each layer.
Otherwise, the scale is used to transform label sizes into real
geographical units.
Bye
(sorry for the long delay, I was not in office for the last month...)
On 19/07/10 09:39, Vianney Dugrain wrote:
> Hi Maxence,
> As regards the scale value, used as a parameter of the problem class: does it only aim to check if it belongs to the scale range of the layer?
> That's the only meaning I found in the description of the agorithms, but I may be wrong.
> Thanks!
> Vianney_______________________________________________
> pal-developer mailing list
> pal-developer at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pal-developer
More information about the pal-developer mailing list
