[pal-developer] scale
Vianney Dugrain Vianney.Dugrain at nateko.lu.se
Mon Jul 19 03:39:23 EDT 2010
Hi Maxence,
As regards the scale value, used as a parameter of the problem class: does it only aim to check if it belongs to the scale range of the layer?
That's the only meaning I found in the description of the agorithms, but I may be wrong.
Thanks!
Vianney
More information about the pal-developer mailing list
