[pdal-commits] [PDAL/PDAL] e8a80a: put uuid in ptree and always put scale, offset, ma...
noreply at github.com noreply at github.com
Wed Dec 21 10:39:02 EST 2011
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: e8a80aa4ba5e75c8998315aa43a317b44dae92c1
      https://github.com/PDAL/PDAL/commit/e8a80aa4ba5e75c8998315aa43a317b44dae92c1
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2011-12-19 (Mon, 19 Dec 2011)
  Changed paths:
    M src/Dimension.cpp
  Log Message:
  put uuid in ptree and always put scale, offset, max, and min in ptree
  Commit: 55ee11ca1b0ace173b35daa0b73a1ac39e1cf2a1
      https://github.com/PDAL/PDAL/commit/55ee11ca1b0ace173b35daa0b73a1ac39e1cf2a1
  Changed paths:
    M test/unit/DimensionTest.cpp
  Log Message:
  make DimensionTest more robust and reflective of how things are currently working
  Commit: d00e05b09587f9c433a3789366bbd4013b4078d0
      https://github.com/PDAL/PDAL/commit/d00e05b09587f9c433a3789366bbd4013b4078d0
  Date:   2011-12-20 (Tue, 20 Dec 2011)
  Changed paths:
    M include/pdal/Schema.hpp
  M src/Schema.cpp
  Log Message:
  update pdal::Schema to remove Dimension::Id and Dimension::DataType
  Commit: b89d9314ba2d4c6a41174c0bbfa2fb0a7d43319b
      https://github.com/PDAL/PDAL/commit/b89d9314ba2d4c6a41174c0bbfa2fb0a7d43319b
  Changed paths:
    M include/pdal/PointBuffer.hpp
  M src/PointBuffer.cpp
  Log Message:
  remove all getField/setField methods that do not take in a Dimension, update to remove Dimension::Id and Dimension::DataType
  Commit: 08ecc1de820c4391f83aee0e3e24f329239a7d40
      https://github.com/PDAL/PDAL/commit/08ecc1de820c4391f83aee0e3e24f329239a7d40
  Changed paths:
    M include/pdal/XMLSchema.hpp
  M src/XMLSchema.cpp
  Log Message:
  Commit: 5baad675baaca5acb94b30de5ba498b7c57203eb
      https://github.com/PDAL/PDAL/commit/5baad675baaca5acb94b30de5ba498b7c57203eb
  Changed paths:
    M include/pdal/filters/Color.hpp
  M src/filters/Color.cpp
  Log Message:
  update filters.color to use default dimensions approach and remove Dimension::Id and Dimension::DataType
  Commit: aac0b5eafa0f41667a4edf609749a0c2e397c9e3
      https://github.com/PDAL/PDAL/commit/aac0b5eafa0f41667a4edf609749a0c2e397c9e3
  Changed paths:
    M include/pdal/dimension/Dimension.hpp
  R include/pdal/dimension/Id.hpp
  R include/pdal/dimension/Type.hpp
  M src/CMakeLists.txt
  M src/Dimension.cpp
  Log Message:
  remove Dimension::Id and Dimension::DataType from Dimension
  Commit: 36cae547217c3859432953e3b626409e39b18909
      https://github.com/PDAL/PDAL/commit/36cae547217c3859432953e3b626409e39b18909
  Changed paths:
    M src/drivers/oci/Writer.cpp
  M src/drivers/p2g/Writer.cpp
  M src/filters/Crop.cpp
  M src/filters/InPlaceReprojection.cpp
  M src/filters/Predicate.cpp
  M src/filters/Programmable.cpp
  M src/filters/Reprojection.cpp
  Log Message:
  updates to remove Dimension::Id and Dimension::DataType
  Commit: 1462df98bdd551fdd54a4da10ac16b5bc508d60d
      https://github.com/PDAL/PDAL/commit/1462df98bdd551fdd54a4da10ac16b5bc508d60d
  Changed paths:
    R src/DimensionId.cpp
  Log Message:
  no longer need this
  Commit: 5e32be8f7942dcb4e625ba33eb1771889da0432d
      https://github.com/PDAL/PDAL/commit/5e32be8f7942dcb4e625ba33eb1771889da0432d
  Changed paths:
    M test/data/apps/pcinfo_schema.txt
  M test/data/apps/pcinfo_stats.txt
  M test/unit/ByteSwapFilterTest.cpp
  M test/unit/CacheFilterTest.cpp
  M test/unit/ChipperTest.cpp
  M test/unit/DecimationFilterTest.cpp
  M test/unit/FauxReaderTest.cpp
  M test/unit/InPlaceReprojectionFilterTest.cpp
  M test/unit/MosaicFilterTest.cpp
  M test/unit/OCITest.cpp
  M test/unit/PointBufferCacheTest.cpp
  M test/unit/PointBufferTest.cpp
  M test/unit/SchemaLayoutTest.cpp
  M test/unit/SchemaTest.cpp
  M test/unit/Support.cpp
  M test/unit/XMLSchemaTest.cpp
  Log Message:
  update tests for the last slug of commits related to Dimension rework to remove Dimension::Id and Dimension::DataType
  Commit: 19ffc484d456eb75256e3dd42a7b95ab923f2041
      https://github.com/PDAL/PDAL/commit/19ffc484d456eb75256e3dd42a7b95ab923f2041
  Log Message:
  Merge branches 'dimension_types' and 'master' of github.com:PDAL/PDAL into dimension_types
Compare: https://github.com/PDAL/PDAL/compare/38ff27c...19ffc48
More information about the pdal-commits mailing list
