[pdal-commits] [PDAL/PDAL] f1383e: a ton of housekeeping for the tests directory
GitHub noreply at github.com
Thu Apr 5 13:41:38 EDT 2012
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: f1383e5af4236508aca5d50c9ca00fc787909bb6
      https://github.com/PDAL/PDAL/commit/f1383e5af4236508aca5d50c9ca00fc787909bb6
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2012-04-05 (Thu, 05 Apr 2012)
  Changed paths:
    A test/data/autzen-dd.las
  R test/data/cleanup-oracle.hobu.biz.sql
  A test/data/nitf/conversion.xml
  A test/data/nitf/reader.xml
  A test/data/oracle/big-read.xml
  A test/data/oracle/big-write.xml
  A test/data/oracle/cleanup.sql
  A test/data/oracle/qfit-read.xml
  A test/data/oracle/qfit-write.xml
  A test/data/oracle/read.xml
  A test/data/oracle/view-read.xml
  A test/data/oracle/write.xml
  R test/data/pipeline/oracle-pipeline-read.xml
  R test/data/pipeline/oracle-pipeline-write.xml
  R test/data/pipeline/qfit-read.xml
  R test/data/pipeline/qfit-to-las.xml
  A test/data/qfit/conversion.xml
  A test/data/qfit/little-endian-conversion.xml
  A test/data/qfit/reader.xml
  R test/unit/BPFTest.cpp
  R test/unit/ByteSwapFilterTest.cpp
  M test/unit/CMakeLists.txt
  R test/unit/CacheFilterTest.cpp
  R test/unit/ChipperTest.cpp
  R test/unit/ColorFilterTest.cpp
  R test/unit/ColorizationFilterTest.cpp
  R test/unit/CropFilterTest.cpp
  R test/unit/DecimationFilterTest.cpp
  R test/unit/FauxReaderTest.cpp
  R test/unit/FauxWriterTest.cpp
  R test/unit/InPlaceReprojectionFilterTest.cpp
  R test/unit/LasReaderTest.cpp
  R test/unit/LasWriterTest.cpp
  R test/unit/MosaicFilterTest.cpp
  R test/unit/NitfReaderTest.cpp
  R test/unit/NitfWriterTest.cpp
  R test/unit/OCITest.cpp
  R test/unit/PLangTest.cpp
  R test/unit/PipelineReaderTest.cpp
  R test/unit/PipelineWriterTest.cpp
  R test/unit/PredicateFilterTest.cpp
  R test/unit/ProgrammableFilterTest.cpp
  R test/unit/QFITReaderTest.cpp
  R test/unit/ReprojectionFilterTest.cpp
  R test/unit/ScalingFilterTest.cpp
  R test/unit/SelectorFilterTest.cpp
  R test/unit/StatsFilterTest.cpp
  R test/unit/TerraSolidTest.cpp
  R test/unit/TextWriterTest.cpp
  A test/unit/apps/pc2pcTest.cpp
  A test/unit/apps/pcinfoTest.cpp
  A test/unit/apps/pcpipelineTest.cpp
  A test/unit/drivers/bpf/BPFTest.cpp
  A test/unit/drivers/faux/FauxReaderTest.cpp
  A test/unit/drivers/faux/FauxWriterTest.cpp
  A test/unit/drivers/las/LasReaderTest.cpp
  A test/unit/drivers/las/LasWriterTest.cpp
  A test/unit/drivers/nitf/NitfReaderTest.cpp
  A test/unit/drivers/nitf/NitfWriterTest.cpp
  A test/unit/drivers/oci/OCITest.cpp
  A test/unit/drivers/pipeline/PipelineReaderTest.cpp
  A test/unit/drivers/pipeline/PipelineWriterTest.cpp
  A test/unit/drivers/qfit/QFITReaderTest.cpp
  A test/unit/drivers/terrasolid/TerraSolidTest.cpp
  A test/unit/drivers/text/TextWriterTest.cpp
  A test/unit/filters/ByteSwapFilterTest.cpp
  A test/unit/filters/CacheFilterTest.cpp
  A test/unit/filters/ChipperTest.cpp
  A test/unit/filters/ColorFilterTest.cpp
  A test/unit/filters/ColorizationFilterTest.cpp
  A test/unit/filters/CropFilterTest.cpp
  A test/unit/filters/DecimationFilterTest.cpp
  A test/unit/filters/InPlaceReprojectionFilterTest.cpp
  A test/unit/filters/MosaicFilterTest.cpp
  A test/unit/filters/ReprojectionFilterTest.cpp
  A test/unit/filters/ScalingFilterTest.cpp
  A test/unit/filters/SelectorFilterTest.cpp
  A test/unit/filters/StatsFilterTest.cpp
  R test/unit/pc2pcTest.cpp
  R test/unit/pcinfoTest.cpp
  R test/unit/pcpipelineTest.cpp
  A test/unit/plang/PLangTest.cpp
  A test/unit/plang/PredicateFilterTest.cpp
  A test/unit/plang/ProgrammableFilterTest.cpp
  Log Message:
More information about the pdal-commits mailing list
