[pdal-commits] [PDAL/PDAL] a09597: move the bad pipeline test cases into their own di...
GitHub noreply at github.com
Fri Apr 6 13:24:13 EDT 2012
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: a0959711e10011dbd18dc3fd9f277bf971b96385
      https://github.com/PDAL/PDAL/commit/a0959711e10011dbd18dc3fd9f277bf971b96385
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2012-04-06 (Fri, 06 Apr 2012)
  Changed paths:
    A test/data/pipeline/bad/pipeline_bad01.xml
  A test/data/pipeline/bad/pipeline_bad02.xml
  A test/data/pipeline/bad/pipeline_bad03.xml
  A test/data/pipeline/bad/pipeline_bad04.xml
  A test/data/pipeline/bad/pipeline_bad05.xml
  A test/data/pipeline/bad/pipeline_bad06.xml
  A test/data/pipeline/bad/pipeline_bad07.xml
  A test/data/pipeline/bad/pipeline_bad08.xml
  A test/data/pipeline/bad/pipeline_bad09.xml
  A test/data/pipeline/bad/pipeline_bad10.xml
  R test/data/pipeline/pipeline_bad01.xml
  R test/data/pipeline/pipeline_bad02.xml
  R test/data/pipeline/pipeline_bad03.xml
  R test/data/pipeline/pipeline_bad04.xml
  R test/data/pipeline/pipeline_bad05.xml
  R test/data/pipeline/pipeline_bad06.xml
  R test/data/pipeline/pipeline_bad07.xml
  R test/data/pipeline/pipeline_bad08.xml
  R test/data/pipeline/pipeline_bad09.xml
  R test/data/pipeline/pipeline_bad10.xml
  M test/unit/drivers/pipeline/PipelineReaderTest.cpp
  Log Message:
  move the bad pipeline test cases into their own directory
More information about the pdal-commits mailing list
