[pdal-commits] Build failed in Jenkins: PDAL-boost-embed #176
Github noreply at github.com
Fri Apr 20 12:38:27 EDT 2012
See <http://jenkins.pointcloud.org/job/PDAL-boost-embed/176/changes>
Changes:
[hobu.inc] remove -pedantic for now
[hobu.inc] ignore unused
[hobu.inc] add -Wextra
[hobu.inc] use std::string instead of char* to back up source, function, and module
[...truncated 39 lines...]
-- Searching for Oracle + OCI client library
-- Found ORACLE: /u01/app/oracle/product/11.2.0/dbhome_1/lib/libclntsh.so;/u01/app/oracle/product/11.2.0/dbhome_1/lib/libocci.so;/u01/app/oracle/product/11.2.0/dbhome_1/lib/libnnz11.so
-- ...building with Oracle
-- Searching for LASzip 1.0.1+ library
-- Found LASzip version: 2.1.0
-- Found LASzip: /var/lib/jenkins/local/lib/liblaszip.so (Required is at least version "1.0.1")
-- Found PythonLibs: /usr/lib/libpython2.7.so
-- Searching for NumPy library
-- Found PythonInterp: /usr/bin/python2.7
-- Found NumPy: 1.5.1
-- Found NumPy at /usr/lib/pymodules/python2.7/numpy/core/include
-- Found Python: /usr/lib/libpython2.7.so
-- Using boost lib: pdalboost
-- Building with PDAL unit tests
-- No non-embed static boost library found, setting BOOST_TEST_DYN_LINK
-- Configuring done
-- Generating done
-- Build files have been written to: <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/>
Scanning dependencies of target pdalboost
[  0%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/date_time/src/gregorian/date_generators.cpp.o
[  1%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/date_time/src/gregorian/greg_month.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/date_time/src/gregorian/greg_month.cpp>:111:3: warning: unused parameter ‘type’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/date_time/src/gregorian/greg_month.cpp>:124:36: warning: unused parameter ‘type’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/date_time/src/gregorian/greg_month.cpp>:142:3: warning: unused parameter ‘type’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/date_time/src/gregorian/greg_month.cpp>:155:36: warning: unused parameter ‘type’
[  1%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/date_time/src/gregorian/greg_weekday.cpp.o
[  2%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/exception/src/clone_current_exception_non_intrusive.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/exception/src/clone_current_exception_non_intrusive.cpp>:13:0:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/exception/detail/clone_current_exception.hpp>:34:9: warning: unused parameter ‘cloned’
[  2%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v2/src/v2_operations.cpp.o
[  3%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v2/src/v2_path.cpp.o
[  3%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v2/src/v2_portability.cpp.o
[  4%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/codecvt_error_category.cpp.o
[  4%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/operations.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/filesystem/v3/src/operations.cpp>:417:8: warning: unused parameter ‘errval’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/filesystem/v3/src/operations.cpp>:1662:8: warning: unused parameter ‘ec’
[  5%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/path.cpp.o
[  5%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/path_traits.cpp.o
[  6%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/portability.cpp.o
[  7%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/unique_path.cpp.o
[  7%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/utf8_codecvt_facet.cpp.o
[  8%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/windows_file_codecvt.cpp.o
[  8%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/iostreams/src/file_descriptor.cpp.o
[  9%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/iostreams/src/mapped_file.cpp.o
[  9%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/cmdline.cpp.o
[ 10%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/config_file.cpp.o
[ 10%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/convert.cpp.o
[ 11%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/options_description.cpp.o
[ 11%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/parsers.cpp.o
[ 12%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/positional_options.cpp.o
[ 12%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/split.cpp.o
[ 13%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/utf8_codecvt_facet.cpp.o
[ 13%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/value_semantic.cpp.o
[ 14%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/variables_map.cpp.o
[ 14%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/winmain.cpp.o
[ 15%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/system/src/error_code.cpp.o
[ 15%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/compiler_log_formatter.cpp.o
[ 16%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/cpp_main.cpp.o
[ 16%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/debug.cpp.o
[ 17%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/exception_safety.cpp.o
[ 17%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/execution_monitor.cpp.o
[ 18%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/framework.cpp.o
[ 18%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/interaction_based.cpp.o
[ 19%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/logged_expectations.cpp.o
[ 19%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/plain_report_formatter.cpp.o
[ 20%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/progress_monitor.cpp.o
[ 20%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/results_collector.cpp.o
[ 21%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/results_reporter.cpp.o
[ 21%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/test_main.cpp.o
[ 22%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/test_tools.cpp.o
[ 22%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_log.cpp.o
[ 23%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_main.cpp.o
[ 23%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_monitor.cpp.o
[ 24%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_parameters.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/utils/runtime/env/variable.hpp>:190:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/impl/unit_test_parameters.ipp>:39,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/test/src/unit_test_parameters.cpp>:16:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/utils/runtime/env/environment.hpp>:103:27: warning: redundant redeclaration of ‘pdalboost::runtime::environment::variable_base pdalboost::runtime::environment::var(pdalboost::runtime::cstring)’ in same scope
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/utils/runtime/env/fwd.hpp>:32:15: warning: previous declaration of ‘pdalboost::runtime::environment::variable_base pdalboost::runtime::environment::var(pdalboost::runtime::cstring)’
[ 24%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_suite.cpp.o
[ 25%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/xml_log_formatter.cpp.o
[ 25%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/xml_report_formatter.cpp.o
[ 26%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/thread/src/pthread/once.cpp.o
[ 27%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/thread/src/pthread/thread.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/condition_variable.hpp>:16:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/pthread/shared_mutex.hpp>:13,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/shared_mutex.hpp>:16,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/detail/thread_group.hpp>:9,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/thread.hpp>:24,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/thread/src/pthread/thread.cpp>:10:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/pthread/condition_variable.hpp>:18:51: warning: redundant redeclaration of ‘void pdalboost::this_thread::interruption_point()’ in same scope
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/detail/thread.hpp>:378:32: warning: previous declaration of ‘void pdalboost::this_thread::interruption_point()’
Linking CXX static library ../bin/libpdalboost.a
[ 27%] Built target pdalboost
[ 28%] Building CXX object src/CMakeFiles/pdal.dir/GDALUtils.cpp.o
[ 28%] Building CXX object src/CMakeFiles/pdal.dir/Bounds.cpp.o
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/Dimension.cpp.o
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/Environment.cpp.o
[ 30%] Building CXX object src/CMakeFiles/pdal.dir/FileUtils.cpp.o
[ 30%] Building CXX object src/CMakeFiles/pdal.dir/Filter.cpp.o
[ 31%] Building CXX object src/CMakeFiles/pdal.dir/FilterIterator.cpp.o
[ 31%] Building CXX object src/CMakeFiles/pdal.dir/Log.cpp.o
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/Metadata.cpp.o
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilter.cpp.o
[ 33%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilterIterator.cpp.o
[ 33%] Building CXX object src/CMakeFiles/pdal.dir/Object.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/Options.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/PipelineManager.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/PipelineReader.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/PipelineWriter.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/PointBuffer.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/Range.cpp.o
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/Reader.cpp.o
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/ReaderIterator.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/Schema.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/SpatialReference.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_srs_api.h:34:0,
                 from /var/lib/jenkins/local/include/ogr_spatialref.h:34,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/SpatialReference.cpp>:45:
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:58:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope3D::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:155:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:94: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/Stage.cpp.o
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/StageBase.cpp.o
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/StageFactory.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/../include/pdal/drivers/oci/common.hpp>:40:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/../include/pdal/drivers/oci/Reader.hpp>:42,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/StageFactory.cpp>:45:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/../include/pdal/drivers/oci/oci_wrapper.h>:64:61: warning: type qualifiers ignored on function return type
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/StageIterator.cpp.o
[ 41%] Building CXX object src/CMakeFiles/pdal.dir/StreamFactory.cpp.o
[ 41%] Building CXX object src/CMakeFiles/pdal.dir/UserCallback.cpp.o
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/Utils.cpp.o
[ 43%] Building CXX object src/CMakeFiles/pdal.dir/Vector.cpp.o
[ 43%] Building CXX object src/CMakeFiles/pdal.dir/Writer.cpp.o
[ 44%] Building CXX object src/CMakeFiles/pdal.dir/XMLSchema.cpp.o
[ 44%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Reader.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Writer.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/GeotiffSupport.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/las/GeotiffSupport.cpp>:40:
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/ZipPoint.cpp.o
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Header.cpp.o
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderReader.cpp.o
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderWriter.cpp.o
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Reader.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/las/Reader.cpp>:646:6: warning: unused parameter ‘data’
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/SummaryData.cpp.o
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Support.cpp.o
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/VariableLengthRecord.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Writer.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/oci_wrapper.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/oci/oci_wrapper.cpp>:31:0:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/oci/oci_wrapper.cpp>:2149:60: warning: type qualifiers ignored on function return type
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/common.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/oci/common.cpp>:36:
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Reader.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/oci/Reader.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/oci/Reader.cpp>:382:14: warning: unused parameter ‘statement’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/oci/Reader.cpp>:841:17: warning: unused parameter ‘count’
[ 52%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Writer.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/../include/pdal/drivers/oci/Writer.hpp>:44,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/oci/Writer.cpp>:41:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/oci/Writer.cpp>:860:6: warning: unused parameter ‘targetNumPointsToWrite’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/oci/Writer.cpp>:886:6: warning: unused parameter ‘actualNumPointsWritten’
[ 52%] Building CXX object src/CMakeFiles/pdal.dir/drivers/pipeline/Reader.cpp.o
[ 53%] Building CXX object src/CMakeFiles/pdal.dir/drivers/qfit/Reader.cpp.o
[ 53%] Building CXX object src/CMakeFiles/pdal.dir/drivers/terrasolid/Reader.cpp.o
[ 54%] Building CXX object src/CMakeFiles/pdal.dir/drivers/text/Writer.cpp.o
[ 54%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/NitfFile.cpp.o
[ 55%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/Reader.cpp.o
[ 55%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/Writer.cpp.o
[ 56%] Building CXX object src/CMakeFiles/pdal.dir/filters/ByteSwap.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/ByteSwap.cpp>: In member function ‘virtual uint32_t pdal::filters::iterators::sequential::ByteSwap::readBufferImpl(pdal::PointBuffer&)’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/ByteSwap.cpp>:176:31: warning: unused variable ‘numSrcPointsRead’
[ 56%] Building CXX object src/CMakeFiles/pdal.dir/filters/Cache.cpp.o
[ 57%] Building CXX object src/CMakeFiles/pdal.dir/filters/Chipper.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/Chipper.cpp>: In member function ‘void pdal::filters::Chipper::Load(pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&)’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/Chipper.cpp>:200:25: warning: unused variable ‘num_to_read’
[ 57%] Building CXX object src/CMakeFiles/pdal.dir/filters/Color.cpp.o
[ 58%] Building CXX object src/CMakeFiles/pdal.dir/filters/Colorization.cpp.o
[ 58%] Building CXX object src/CMakeFiles/pdal.dir/filters/Crop.cpp.o
[ 59%] Building CXX object src/CMakeFiles/pdal.dir/filters/Decimation.cpp.o
[ 59%] Building CXX object src/CMakeFiles/pdal.dir/filters/InPlaceReprojection.cpp.o
[ 60%] Building CXX object src/CMakeFiles/pdal.dir/filters/Mosaic.cpp.o
[ 60%] Building CXX object src/CMakeFiles/pdal.dir/filters/PointBufferCache.cpp.o
[ 61%] Building CXX object src/CMakeFiles/pdal.dir/filters/Predicate.cpp.o
[ 61%] Building CXX object src/CMakeFiles/pdal.dir/filters/Programmable.cpp.o
[ 62%] Building CXX object src/CMakeFiles/pdal.dir/filters/Reprojection.cpp.o
[ 63%] Building CXX object src/CMakeFiles/pdal.dir/filters/Scaling.cpp.o
[ 63%] Building CXX object src/CMakeFiles/pdal.dir/filters/Selector.cpp.o
[ 64%] Building CXX object src/CMakeFiles/pdal.dir/filters/Stats.cpp.o
[ 64%] Building CXX object src/CMakeFiles/pdal.dir/plang/BufferedInvocation.cpp.o
[ 65%] Building CXX object src/CMakeFiles/pdal.dir/plang/Environment.cpp.o
In file included from /usr/include/python2.7/Python.h:8:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Environment.cpp>:45:
/usr/include/python2.7/pyconfig.h:1155:0: warning: "_POSIX_C_SOURCE" redefined
/usr/include/features.h:163:0: note: this is the location of the previous definition
/usr/include/python2.7/pyconfig.h:1177:0: warning: "_XOPEN_SOURCE" redefined
/usr/include/features.h:165:0: note: this is the location of the previous definition
[ 65%] Building CXX object src/CMakeFiles/pdal.dir/plang/Invocation.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Invocation.cpp>:46:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Invocation.cpp>: In member function ‘void pdal::plang::Invocation::compile()’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Invocation.cpp>:97:69: error: invalid conversion from ‘const char*’ to ‘char*’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Invocation.cpp>:97:69: error:   initializing argument 1 of ‘PyObject* PyImport_ExecCodeModule(char*, PyObject*)’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Invocation.cpp>: In static member function ‘static int pdal::plang::Invocation::getPythonDataType(pdal::dimension::Interpretation, uint32_t)’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Invocation.cpp>:313:12: warning: enumeration value ‘Pointer’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Invocation.cpp>:313:12: warning: enumeration value ‘Undefined’ not handled in switch
make[2]: *** [src/CMakeFiles/pdal.dir/plang/Invocation.cpp.o] Error 1
make[1]: *** [src/CMakeFiles/pdal.dir/all] Error 2
make: *** [all] Error 2
test/jenkins.sh: line 16: ./bin/pdal_test: No such file or directory
Build step 'Execute shell' marked build as failure
More information about the pdal-commits mailing list
