[pdal-commits] Build failed in Jenkins: PDAL #217
Github noreply at github.com
Mon Apr 30 22:29:28 EDT 2012
See <http://jenkins.pointcloud.org/job/PDAL/217/changes>
Changes:
[hobu.inc] prevent an overflow that was causing the character padding to be multi-gb in size -- there's a boost string algo to do this somewhere
[hobu.inc] fix up filters.inplacereprojection to do its operations on the PointBuffer, not the Stage
[...truncated 216 lines...]
/var/lib/jenkins/local/include/ogr_core.h:155:94: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/drivers/pipeline/Reader.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/drivers/qfit/Reader.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/drivers/terrasolid/Reader.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/drivers/text/Writer.cpp.o
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/NitfFile.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/Reader.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/Writer.cpp.o
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/filters/ByteSwap.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/ByteSwap.cpp>: In member function ‘virtual uint32_t pdal::filters::iterators::sequential::ByteSwap::readBufferImpl(pdal::PointBuffer&)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/ByteSwap.cpp>:185:31: warning: unused variable ‘numSrcPointsRead’
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/filters/Cache.cpp.o
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/filters/Chipper.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Chipper.cpp>: In member function ‘void pdal::filters::Chipper::Load(pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Chipper.cpp>:203:25: warning: unused variable ‘num_to_read’
[ 41%] Building CXX object src/CMakeFiles/pdal.dir/filters/Color.cpp.o
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/filters/Colorization.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_srs_api.h:34:0,
                 from /var/lib/jenkins/local/include/ogr_spatialref.h:34,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Colorization.cpp>:45:
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:58:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope3D::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:155:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:81: warning: comparing floating point with == or != is unsafe
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/filters/Crop.cpp.o
[ 43%] Building CXX object src/CMakeFiles/pdal.dir/filters/Decimation.cpp.o
[ 44%] Building CXX object src/CMakeFiles/pdal.dir/filters/InPlaceReprojection.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:43:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>: At global scope:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:387:6: warning: unused parameter ‘data’
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/filters/Mosaic.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/filters/PointBufferCache.cpp.o
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/filters/Predicate.cpp.o
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/filters/Programmable.cpp.o
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/filters/Reprojection.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Reprojection.cpp>:44:
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/filters/Scaling.cpp.o
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/filters/Selector.cpp.o
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/filters/Stats.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/plang/BufferedInvocation.cpp.o
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/plang/Environment.cpp.o
In file included from /usr/include/python2.7/Python.h:8:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Environment.cpp>:45:
/usr/include/python2.7/pyconfig.h:1155:0: warning: "_POSIX_C_SOURCE" redefined
/usr/include/features.h:163:0: note: this is the location of the previous definition
/usr/include/python2.7/pyconfig.h:1177:0: warning: "_XOPEN_SOURCE" redefined
/usr/include/features.h:165:0: note: this is the location of the previous definition
[ 52%] Building CXX object src/CMakeFiles/pdal.dir/plang/Invocation.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Invocation.cpp>:46:
[ 52%] Building CXX object src/CMakeFiles/pdal.dir/plang/Script.cpp.o
[ 53%] Building CXX object src/CMakeFiles/pdal.dir/pdal_config.cpp.o
Linking CXX shared library ../bin/libpdal.so
[ 53%] Built target pdal
Scanning dependencies of target pc2pc
[ 53%] Building CXX object apps/CMakeFiles/pc2pc.dir/pc2pc.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/apps/../include/pdal/drivers/oci/common.hpp>:40:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/apps/../include/pdal/drivers/oci/Writer.hpp>:44,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/apps/pc2pc.cpp>:40:
<http://jenkins.pointcloud.org/job/PDAL/ws/apps/../include/pdal/drivers/oci/oci_wrapper.h>:64:61: warning: type qualifiers ignored on function return type
[ 54%] Building CXX object apps/CMakeFiles/pc2pc.dir/Application.cpp.o
[ 55%] Building CXX object apps/CMakeFiles/pc2pc.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pc2pc
[ 55%] Built target pc2pc
Scanning dependencies of target pcinfo
[ 55%] Building CXX object apps/CMakeFiles/pcinfo.dir/pcinfo.cpp.o
In file included from /var/lib/jenkins/local/include/boost/property_tree/json_parser.hpp:15:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/apps/pcinfo.cpp>:47:
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp: In function ‘std::basic_string<_CharT> boost::property_tree::json_parser::create_escapes(const std::basic_string<_CharT>&) [with Ch = char]’:
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:78:67:   instantiated from ‘void boost::property_tree::json_parser::write_json_helper(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, int, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char]’
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:162:9:   instantiated from ‘void boost::property_tree::json_parser::write_json_internal(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, const std::string&, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char, std::string = std::basic_string<char>]’
/var/lib/jenkins/local/include/boost/property_tree/json_parser.hpp:98:9:   instantiated from ‘void boost::property_tree::json_parser::write_json(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char]’
<http://jenkins.pointcloud.org/job/PDAL/ws/apps/pcinfo.cpp>:180:45:   instantiated from here
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:35:13: warning: comparison is always true due to limited range of data type
[ 56%] Building CXX object apps/CMakeFiles/pcinfo.dir/Application.cpp.o
[ 57%] Building CXX object apps/CMakeFiles/pcinfo.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pcinfo
[ 57%] Built target pcinfo
Scanning dependencies of target pcpipeline
[ 57%] Building CXX object apps/CMakeFiles/pcpipeline.dir/pcpipeline.cpp.o
[ 58%] Building CXX object apps/CMakeFiles/pcpipeline.dir/Application.cpp.o
[ 59%] Building CXX object apps/CMakeFiles/pcpipeline.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pcpipeline
[ 59%] Built target pcpipeline
Scanning dependencies of target pdal_test
[ 60%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/apps/pc2pcTest.cpp.o
[ 60%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/apps/pcinfoTest.cpp.o
[ 61%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/apps/pcpipelineTest.cpp.o
[ 62%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/BoundsTest.cpp.o
[ 62%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/bpf/BPFTest.cpp.o
[ 63%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/ByteSwapFilterTest.cpp.o
[ 64%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/CacheFilterTest.cpp.o
[ 65%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/ChipperTest.cpp.o
[ 65%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/ColorFilterTest.cpp.o
[ 66%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/ColorizationFilterTest.cpp.o
[ 67%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ConfigTest.cpp.o
[ 67%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/CropFilterTest.cpp.o
[ 68%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/DecimationFilterTest.cpp.o
[ 69%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/DimensionLayoutTest.cpp.o
[ 69%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/DimensionTest.cpp.o
In file included from /var/lib/jenkins/local/include/boost/test/test_tools.hpp:21:0,
                 from /var/lib/jenkins/local/include/boost/test/unit_test.hpp:19,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/DimensionTest.cpp>:35:
/var/lib/jenkins/local/include/boost/test/floating_point_comparison.hpp: In function ‘FPT boost::test_tools::tt_detail::safe_fpt_division(FPT, FPT) [with FPT = double]’:
/var/lib/jenkins/local/include/boost/test/floating_point_comparison.hpp:188:84:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::close_at_tolerance<FPT>::operator()(FPT, FPT) const [with FPT = double]’
/var/lib/jenkins/local/include/boost/test/floating_point_comparison.hpp:233:34:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::check_is_close_t::operator()(FPT1, FPT2, boost::test_tools::percent_tolerance_t<ToleranceBaseType>, boost::test_tools::floating_point_comparison_type) const [with FPT1 = double, FPT2 = float, ToleranceBaseType = float]’
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:523:1:   instantiated from ‘bool boost::test_tools::tt_detail::check_frwd(Pred, const boost::unit_test::lazy_ostream&, boost::test_tools::const_string, size_t, boost::test_tools::tt_detail::tool_level, boost::test_tools::tt_detail::check_type, const Arg0&, const char*, const Arg1&, const char*, const Arg2&, const char*) [with Pred = boost::test_tools::check_is_close_t, Arg0 = double, Arg1 = float, Arg2 = boost::test_tools::percent_tolerance_t<float>, boost::test_tools::const_string = boost::unit_test::basic_cstring<const char>, size_t = long unsigned int]’
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/DimensionTest.cpp>:135:1:   instantiated from here
/var/lib/jenkins/local/include/boost/test/floating_point_comparison.hpp:92:5: warning: comparing floating point with == or != is unsafe
[ 70%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/EnvironmentTest.cpp.o
[ 71%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/faux/FauxReaderTest.cpp.o
[ 72%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/faux/FauxWriterTest.cpp.o
In file included from /var/lib/jenkins/local/include/boost/test/unit_test.hpp:19:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/drivers/faux/FauxWriterTest.cpp>:35:
/var/lib/jenkins/local/include/boost/test/test_tools.hpp: In function ‘boost::test_tools::predicate_result boost::test_tools::tt_detail::equal_impl(const Left&, const Right&) [with Left = double, Right = int]’:
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:560:40:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::tt_detail::equal_impl_frwd::call_impl(const Left&, const Right&, mpl_::false_) const [with Left = double, Right = int, mpl_::false_ = mpl_::bool_<false>]’
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:575:56:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::tt_detail::equal_impl_frwd::operator()(const Left&, const Right&) const [with Left = double, Right = int]’
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:523:1:   instantiated from ‘bool boost::test_tools::tt_detail::check_frwd(Pred, const boost::unit_test::lazy_ostream&, boost::test_tools::const_string, size_t, boost::test_tools::tt_detail::tool_level, boost::test_tools::tt_detail::check_type, const Arg0&, const char*, const Arg1&, const char*) [with Pred = boost::test_tools::tt_detail::equal_impl_frwd, Arg0 = double, Arg1 = int, boost::test_tools::const_string = boost::unit_test::basic_cstring<const char>, size_t = long unsigned int]’
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/drivers/faux/FauxWriterTest.cpp>:154:1:   instantiated from here
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:536:20: warning: comparing floating point with == or != is unsafe
[ 72%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/FileUtilsTest.cpp.o
[ 73%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/InPlaceReprojectionFilterTest.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/filters/InPlaceReprojectionFilterTest.cpp>:35:
/var/lib/jenkins/local/include/boost/test/floating_point_comparison.hpp:233:34:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::check_is_close_t::operator()(FPT1, FPT2, boost::test_tools::percent_tolerance_t<ToleranceBaseType>, boost::test_tools::floating_point_comparison_type) const [with FPT1 = double, FPT2 = double, ToleranceBaseType = double]’
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:523:1:   instantiated from ‘bool boost::test_tools::tt_detail::check_frwd(Pred, const boost::unit_test::lazy_ostream&, boost::test_tools::const_string, size_t, boost::test_tools::tt_detail::tool_level, boost::test_tools::tt_detail::check_type, const Arg0&, const char*, const Arg1&, const char*, const Arg2&, const char*) [with Pred = boost::test_tools::check_is_close_t, Arg0 = double, Arg1 = double, Arg2 = boost::test_tools::percent_tolerance_t<double>, boost::test_tools::const_string = boost::unit_test::basic_cstring<const char>, size_t = long unsigned int]’
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/filters/InPlaceReprojectionFilterTest.cpp>:145:1:   instantiated from here
[ 74%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/las/LasReaderTest.cpp.o
[ 74%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/las/LasWriterTest.cpp.o
[ 75%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/MetadataTest.cpp.o
[ 76%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/MosaicFilterTest.cpp.o
[ 76%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/OptionsTest.cpp.o
[ 77%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PipelineManagerTest.cpp.o
[ 78%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/pipeline/PipelineReaderTest.cpp.o
[ 79%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/pipeline/PipelineWriterTest.cpp.o
[ 79%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PointBufferCacheTest.cpp.o
[ 80%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PointBufferTest.cpp.o
[ 81%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/qfit/QFITReaderTest.cpp.o
[ 81%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/RangeTest.cpp.o
[ 82%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/ReprojectionFilterTest.cpp.o
[ 83%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/ScalingFilterTest.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/filters/ScalingFilterTest.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/filters/ScalingFilterTest.cpp>:180:1:   instantiated from here
[ 83%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/SelectorFilterTest.cpp.o
[ 84%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SchemaLayoutTest.cpp.o
[ 85%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SchemaTest.cpp.o
[ 86%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SpatialReferenceTest.cpp.o
[ 86%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/StageFactoryTest.cpp.o
[ 87%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/filters/StatsFilterTest.cpp.o
[ 88%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/StreamFactoryTest.cpp.o
[ 88%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SupportTest.cpp.o
[ 89%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/terrasolid/TerraSolidTest.cpp.o
[ 90%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/text/TextWriterTest.cpp.o
[ 90%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/UserCallbackTest.cpp.o
[ 91%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/UtilsTest.cpp.o
[ 92%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/VectorTest.cpp.o
[ 93%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/XMLSchemaTest.cpp.o
[ 93%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/oci/OCITest.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/drivers/oci/common.hpp>:40:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/drivers/oci/Reader.hpp>:42,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/drivers/oci/OCITest.cpp>:39:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/drivers/oci/oci_wrapper.h>:64:61: warning: type qualifiers ignored on function return type
[ 94%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/GDALUtilsTest.cpp.o
[ 95%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/nitf/NitfReaderTest.cpp.o
[ 95%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/drivers/nitf/NitfWriterTest.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/drivers/nitf/NitfWriterTest.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/drivers/nitf/NitfWriterTest.cpp>:111:1:   instantiated from here
[ 96%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/plang/PLangTest.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/plang/PLangTest.cpp>:38:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/plang/PLangTest.cpp>:237:1:   instantiated from here
[ 97%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/plang/PredicateFilterTest.cpp.o
[ 97%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/plang/ProgrammableFilterTest.cpp.o
[ 98%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/Support.cpp.o
[ 99%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/TestConfig.cpp.o
[100%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/main.cpp.o
Linking CXX executable ../../bin/pdal_test
[100%] Built target pdal_test
Running 187 test cases...
unknown location(0): fatal error in "test1": std::runtime_error: Dimension with name 'Z' not found, unable to Schema::getDimension
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/SchemaLayoutTest.cpp(61)>: last checkpoint
*** 1 failure detected in test suite "Main"
Build step 'Execute shell' marked build as failure
More information about the pdal-commits mailing list
