[pdal-commits] Build failed in Jenkins: PDAL #14
Github noreply at github.com
Mon Feb 6 17:58:07 EST 2012
See <http://jenkins.pointcloud.org/job/PDAL/14/changes>
Changes:
[hobu.inc] tweak geotiff lib location
[...truncated 55 lines...]
-- Enable PDAL unit tests to build - done
-- Configuring done
-- Generating done
-- Build files have been written to: <http://jenkins.pointcloud.org/job/PDAL/ws/>
Scanning dependencies of target pdal
[  1%] Building CXX object src/CMakeFiles/pdal.dir/GDALUtils.cpp.o
[  2%] Building CXX object src/CMakeFiles/pdal.dir/Bounds.cpp.o
[  3%] Building CXX object src/CMakeFiles/pdal.dir/Dimension.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/external/boost/uuid/seed_rng.hpp>: In member function ‘void pdal::external::boost::uuids::detail::seed_rng::sha1_random_digest_()’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/external/boost/uuid/seed_rng.hpp>:154:53: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result
[  3%] Building CXX object src/CMakeFiles/pdal.dir/FileUtils.cpp.o
[  4%] Building CXX object src/CMakeFiles/pdal.dir/Filter.cpp.o
[  5%] Building CXX object src/CMakeFiles/pdal.dir/FilterIterator.cpp.o
[  6%] Building CXX object src/CMakeFiles/pdal.dir/Log.cpp.o
[  7%] Building CXX object src/CMakeFiles/pdal.dir/MetadataRecord.cpp.o
[  8%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilter.cpp.o
[  8%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilterIterator.cpp.o
[  9%] Building CXX object src/CMakeFiles/pdal.dir/Options.cpp.o
[ 10%] Building CXX object src/CMakeFiles/pdal.dir/PipelineManager.cpp.o
[ 11%] Building CXX object src/CMakeFiles/pdal.dir/PipelineReader.cpp.o
[ 12%] Building CXX object src/CMakeFiles/pdal.dir/PipelineWriter.cpp.o
[ 13%] Building CXX object src/CMakeFiles/pdal.dir/PointBuffer.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/PointBuffer.hpp>:40:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/PointBuffer.cpp>:35:
/var/lib/jenkins/local/include/boost/lexical_cast.hpp: In member function ‘bool boost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::shl_double(double, T*) [with T = char, CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’:
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1299:86:   instantiated from ‘bool boost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::operator<<(double) [with CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1749:17:   instantiated from ‘static Target boost::detail::lexical_cast_do_cast<Target, Source>::lexical_cast_impl(const Source&) [with Target = std::basic_string<char>, Source = double]’
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1916:50:   instantiated from ‘Target boost::lexical_cast(const Source&) [with Target = std::basic_string<char>, Source = double]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/PointBuffer.cpp>:186:35:   instantiated from here
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1184:17: warning: ISO C++ does not support the ‘%lg’ gnu_printf format
[ 14%] Building CXX object src/CMakeFiles/pdal.dir/Range.cpp.o
[ 14%] Building CXX object src/CMakeFiles/pdal.dir/Reader.cpp.o
[ 15%] Building CXX object src/CMakeFiles/pdal.dir/ReaderIterator.cpp.o
[ 16%] Building CXX object src/CMakeFiles/pdal.dir/Schema.cpp.o
[ 17%] Building CXX object src/CMakeFiles/pdal.dir/SpatialReference.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_srs_api.h:34:0,
                 from /var/lib/jenkins/local/include/ogr_spatialref.h:34,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/SpatialReference.cpp>:44:
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:58:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope3D::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:155:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:94: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
[ 18%] Building CXX object src/CMakeFiles/pdal.dir/Stage.cpp.o
[ 19%] Building CXX object src/CMakeFiles/pdal.dir/StageBase.cpp.o
[ 19%] Building CXX object src/CMakeFiles/pdal.dir/StageFactory.cpp.o
[ 20%] Building CXX object src/CMakeFiles/pdal.dir/StageIterator.cpp.o
[ 21%] Building CXX object src/CMakeFiles/pdal.dir/StreamManager.cpp.o
[ 22%] Building CXX object src/CMakeFiles/pdal.dir/UserCallback.cpp.o
[ 23%] Building CXX object src/CMakeFiles/pdal.dir/Utils.cpp.o
[ 24%] Building CXX object src/CMakeFiles/pdal.dir/Vector.cpp.o
[ 24%] Building CXX object src/CMakeFiles/pdal.dir/Writer.cpp.o
[ 25%] Building CXX object src/CMakeFiles/pdal.dir/XMLSchema.cpp.o
[ 26%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Reader.cpp.o
[ 27%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Writer.cpp.o
[ 28%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/GeotiffSupport.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/las/GeotiffSupport.cpp>:40:
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/ZipPoint.cpp.o
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Header.cpp.o
[ 30%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderReader.cpp.o
[ 31%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderWriter.cpp.o
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Reader.cpp.o
[ 33%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/SummaryData.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Support.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/VariableLengthRecord.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Writer.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/oci_wrapper.cpp.o
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/common.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Reader.cpp.o
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Writer.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_api.h:42:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/oci/Writer.cpp>:47:
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/drivers/pipeline/Reader.cpp.o
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/drivers/qfit/Reader.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Options.hpp>:42:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/StageBase.hpp>:42,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Stage.hpp>:40,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Reader.hpp>:38,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/drivers/qfit/Reader.hpp>:38,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/qfit/Reader.cpp>:170:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Options.hpp>:166:9:   instantiated from ‘void pdal::Option::setValue(const T&) [with T = double]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Options.hpp>:100:9:   instantiated from ‘pdal::Option::Option(const std::string&, const T&, const std::string&) [with T = double, std::string = std::basic_string<char>]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/qfit/Reader.cpp>:454:83:   instantiated from here
[ 41%] Building CXX object src/CMakeFiles/pdal.dir/drivers/terrasolid/Reader.cpp.o
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/filters/ByteSwap.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/ByteSwap.cpp>: In member function ‘virtual uint32_t pdal::filters::iterators::sequential::ByteSwap::readBufferImpl(pdal::PointBuffer&)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/ByteSwap.cpp>:176:31: warning: unused variable ‘numSrcPointsRead’
[ 43%] Building CXX object src/CMakeFiles/pdal.dir/filters/Cache.cpp.o
[ 44%] Building CXX object src/CMakeFiles/pdal.dir/filters/Chipper.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Chipper.cpp>: In member function ‘void pdal::filters::Chipper::Load(pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Chipper.cpp>:199:25: warning: unused variable ‘num_to_read’
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/filters/Color.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/filters/Colorization.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Colorization.cpp>:45:
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Filter.hpp>:40,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/filters/Colorization.hpp>:38,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Colorization.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Colorization.cpp>:108:68:   instantiated from here
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/filters/Crop.cpp.o
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/filters/Decimation.cpp.o
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/filters/InPlaceReprojection.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:43:
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/filters/InPlaceReprojection.hpp>:38,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:176:184:   instantiated from here
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/filters/Mosaic.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/filters/PointBufferCache.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/filters/Reprojection.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Reprojection.cpp>:44:
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/filters/Scaling.cpp.o
[ 52%] Building CXX object src/CMakeFiles/pdal.dir/filters/Stats.cpp.o
[ 53%] Building CXX object src/CMakeFiles/pdal.dir/pdal_config.cpp.o
Linking CXX shared library ../bin/libpdal.so
[ 53%] Built target pdal
Scanning dependencies of target pc2pc
[ 53%] Building CXX object apps/CMakeFiles/pc2pc.dir/pc2pc.cpp.o
[ 54%] Building CXX object apps/CMakeFiles/pc2pc.dir/Application.cpp.o
[ 55%] Building CXX object apps/CMakeFiles/pc2pc.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pc2pc
CMakeFiles/pc2pc.dir/pc2pc.cpp.o: In function `global constructors keyed to pc2pc.cpp':
pc2pc.cpp:(.text+0x314b): undefined reference to `boost::system::generic_category()'
pc2pc.cpp:(.text+0x3157): undefined reference to `boost::system::generic_category()'
pc2pc.cpp:(.text+0x3163): undefined reference to `boost::system::system_category()'
CMakeFiles/pc2pc.dir/AppSupport.cpp.o: In function `AppSupport::inferWriterDriver(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, pdal::Options&)':
AppSupport.cpp:(.text+0x1da): undefined reference to `boost::filesystem3::path::extension() const'
CMakeFiles/pc2pc.dir/AppSupport.cpp.o: In function `AppSupport::inferReaderDriver(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, pdal::Options&)':
AppSupport.cpp:(.text+0x19ba): undefined reference to `boost::filesystem3::path::extension() const'
CMakeFiles/pc2pc.dir/AppSupport.cpp.o: In function `global constructors keyed to AppSupport.cpp':
AppSupport.cpp:(.text+0x35cb): undefined reference to `boost::system::generic_category()'
AppSupport.cpp:(.text+0x35d7): undefined reference to `boost::system::generic_category()'
AppSupport.cpp:(.text+0x35e3): undefined reference to `boost::system::system_category()'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::path::operator/=(boost::filesystem3::path const&)'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::detail::remove(boost::filesystem3::path const&, boost::system::error_code*)'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::detail::status(boost::filesystem3::path const&, boost::system::error_code*)'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::detail::rename(boost::filesystem3::path const&, boost::filesystem3::path const&, boost::system::error_code*)'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::detail::current_path(boost::system::error_code*)'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::absolute(boost::filesystem3::path const&, boost::filesystem3::path const&)'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::detail::temp_directory_path(boost::system::error_code*)'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::detail::file_size(boost::filesystem3::path const&, boost::system::error_code*)'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::path::root_directory() const'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::path::parent_path() const'
../bin/libpdal.so.0: undefined reference to `boost::filesystem3::detail::unique_path(boost::filesystem3::path const&, boost::system::error_code*)'
collect2: ld returned 1 exit status
make[2]: *** [bin/pc2pc] Error 1
make[1]: *** [apps/CMakeFiles/pc2pc.dir/all] Error 2
make: *** [all] Error 2
test/jenkins.sh: 9: ./bin/pdal_test: not found
Build step 'Execute shell' marked build as failure
More information about the pdal-commits mailing list
