[pdal-commits] Build failed in Jenkins: PDAL #16
Github noreply at github.com
Mon Feb 6 18:17:23 EST 2012
See <http://jenkins.pointcloud.org/job/PDAL/16/changes>
Changes:
[hobu.inc] add missing test file
[...truncated 211 lines...]
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Options.hpp>:166:9:   instantiated from ‘void pdal::Option::setValue(const T&) [with T = double]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Options.hpp>:100:9:   instantiated from ‘pdal::Option::Option(const std::string&, const T&, const std::string&) [with T = double, std::string = std::basic_string<char>]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Colorization.cpp>:108:68:   instantiated from here
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1184:17: warning: ISO C++ does not support the ‘%lg’ gnu_printf format
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/filters/Crop.cpp.o
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/filters/Decimation.cpp.o
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/filters/InPlaceReprojection.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_srs_api.h:34:0,
                 from /var/lib/jenkins/local/include/ogr_spatialref.h:34,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:43:
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:58:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope3D::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:155:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:94: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Options.hpp>:42:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/StageBase.hpp>:42,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Stage.hpp>:40,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Filter.hpp>:40,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/filters/InPlaceReprojection.hpp>:38,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:35:
/var/lib/jenkins/local/include/boost/lexical_cast.hpp: In member function ‘bool boost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::shl_double(double, T*) [with T = char, CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’:
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1299:86:   instantiated from ‘bool boost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::operator<<(double) [with CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1749:17:   instantiated from ‘static Target boost::detail::lexical_cast_do_cast<Target, Source>::lexical_cast_impl(const Source&) [with Target = std::basic_string<char>, Source = double]’
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1916:50:   instantiated from ‘Target boost::lexical_cast(const Source&) [with Target = std::basic_string<char>, Source = double]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:176:184:   instantiated from here
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/filters/Mosaic.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/filters/PointBufferCache.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/filters/Reprojection.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Reprojection.cpp>:44:
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/filters/Scaling.cpp.o
[ 52%] Building CXX object src/CMakeFiles/pdal.dir/filters/Stats.cpp.o
[ 53%] Building CXX object src/CMakeFiles/pdal.dir/pdal_config.cpp.o
Linking CXX shared library ../bin/libpdal.so
[ 53%] Built target pdal
Scanning dependencies of target pc2pc
[ 53%] Building CXX object apps/CMakeFiles/pc2pc.dir/pc2pc.cpp.o
[ 54%] Building CXX object apps/CMakeFiles/pc2pc.dir/Application.cpp.o
[ 55%] Building CXX object apps/CMakeFiles/pc2pc.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pc2pc
[ 55%] Built target pc2pc
Scanning dependencies of target pcinfo
[ 56%] Building CXX object apps/CMakeFiles/pcinfo.dir/pcinfo.cpp.o
[ 57%] Building CXX object apps/CMakeFiles/pcinfo.dir/Application.cpp.o
[ 58%] Building CXX object apps/CMakeFiles/pcinfo.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pcinfo
[ 58%] Built target pcinfo
Scanning dependencies of target pcpipeline
[ 58%] Building CXX object apps/CMakeFiles/pcpipeline.dir/pcpipeline.cpp.o
[ 59%] Building CXX object apps/CMakeFiles/pcpipeline.dir/Application.cpp.o
[ 60%] Building CXX object apps/CMakeFiles/pcpipeline.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pcpipeline
[ 60%] Built target pcpipeline
Scanning dependencies of target pdal_test
[ 61%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/pc2pcTest.cpp.o
[ 62%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/pcinfoTest.cpp.o
[ 63%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/pcpipelineTest.cpp.o
[ 63%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/BoundsTest.cpp.o
[ 64%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ByteSwapFilterTest.cpp.o
[ 65%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/CacheFilterTest.cpp.o
[ 66%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ChipperTest.cpp.o
[ 67%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ColorFilterTest.cpp.o
[ 68%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ColorizationFilterTest.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/Options.hpp>:42:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/StageBase.hpp>:42,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/Stage.hpp>:40,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/Reader.hpp>:38,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/drivers/las/Reader.hpp>:38,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/ColorizationFilterTest.cpp>:38:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/Options.hpp>:166:9:   instantiated from ‘void pdal::Option::setValue(const T&) [with T = double]’
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/Options.hpp>:100:9:   instantiated from ‘pdal::Option::Option(const std::string&, const T&, const std::string&) [with T = double, std::string = std::basic_string<char>]’
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/ColorizationFilterTest.cpp>:63:72:   instantiated from here
[ 68%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ConfigTest.cpp.o
[ 69%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/CropFilterTest.cpp.o
[ 70%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/DecimationFilterTest.cpp.o
[ 71%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/DimensionLayoutTest.cpp.o
[ 72%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/DimensionTest.cpp.o
In file included from /var/lib/jenkins/local/include/boost/test/test_tools.hpp:21:0,
                 from /var/lib/jenkins/local/include/boost/test/unit_test.hpp:19,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/DimensionTest.cpp>:35:
/var/lib/jenkins/local/include/boost/test/floating_point_comparison.hpp: In function ‘FPT boost::test_tools::tt_detail::safe_fpt_division(FPT, FPT) [with FPT = double]’:
/var/lib/jenkins/local/include/boost/test/floating_point_comparison.hpp:188:84:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::close_at_tolerance<FPT>::operator()(FPT, FPT) const [with FPT = double]’
/var/lib/jenkins/local/include/boost/test/floating_point_comparison.hpp:233:34:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::check_is_close_t::operator()(FPT1, FPT2, boost::test_tools::percent_tolerance_t<ToleranceBaseType>, boost::test_tools::floating_point_comparison_type) const [with FPT1 = double, FPT2 = double, ToleranceBaseType = double]’
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:523:1:   instantiated from ‘bool boost::test_tools::tt_detail::check_frwd(Pred, const boost::unit_test::lazy_ostream&, boost::test_tools::const_string, size_t, boost::test_tools::tt_detail::tool_level, boost::test_tools::tt_detail::check_type, const Arg0&, const char*, const Arg1&, const char*, const Arg2&, const char*) [with Pred = boost::test_tools::check_is_close_t, Arg0 = double, Arg1 = double, Arg2 = boost::test_tools::percent_tolerance_t<double>, boost::test_tools::const_string = boost::unit_test::basic_cstring<const char>, size_t = long unsigned int]’
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/DimensionTest.cpp>:98:1:   instantiated from here
/var/lib/jenkins/local/include/boost/test/floating_point_comparison.hpp:92:5: warning: comparing floating point with == or != is unsafe
[ 73%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/FauxReaderTest.cpp.o
[ 73%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/FauxWriterTest.cpp.o
In file included from /var/lib/jenkins/local/include/boost/test/unit_test.hpp:19:0,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/FauxWriterTest.cpp>:35:
/var/lib/jenkins/local/include/boost/test/test_tools.hpp: In function ‘boost::test_tools::predicate_result boost::test_tools::tt_detail::equal_impl(const Left&, const Right&) [with Left = long unsigned int, Right = int]’:
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:560:40:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::tt_detail::equal_impl_frwd::call_impl(const Left&, const Right&, mpl_::false_) const [with Left = long unsigned int, Right = int, mpl_::false_ = mpl_::bool_<false>]’
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:575:56:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::tt_detail::equal_impl_frwd::operator()(const Left&, const Right&) const [with Left = long unsigned int, Right = int]’
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:523:1:   instantiated from ‘bool boost::test_tools::tt_detail::check_frwd(Pred, const boost::unit_test::lazy_ostream&, boost::test_tools::const_string, size_t, boost::test_tools::tt_detail::tool_level, boost::test_tools::tt_detail::check_type, const Arg0&, const char*, const Arg1&, const char*) [with Pred = boost::test_tools::tt_detail::equal_impl_frwd, Arg0 = long unsigned int, Arg1 = int, boost::test_tools::const_string = boost::unit_test::basic_cstring<const char>, size_t = long unsigned int]’
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/FauxWriterTest.cpp>:153:1:   instantiated from here
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:536:20: warning: comparison between signed and unsigned integer expressions
/var/lib/jenkins/local/include/boost/test/test_tools.hpp: In function ‘boost::test_tools::predicate_result boost::test_tools::tt_detail::equal_impl(const Left&, const Right&) [with Left = double, Right = int]’:
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:560:40:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::tt_detail::equal_impl_frwd::call_impl(const Left&, const Right&, mpl_::false_) const [with Left = double, Right = int, mpl_::false_ = mpl_::bool_<false>]’
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:575:56:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::tt_detail::equal_impl_frwd::operator()(const Left&, const Right&) const [with Left = double, Right = int]’
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:523:1:   instantiated from ‘bool boost::test_tools::tt_detail::check_frwd(Pred, const boost::unit_test::lazy_ostream&, boost::test_tools::const_string, size_t, boost::test_tools::tt_detail::tool_level, boost::test_tools::tt_detail::check_type, const Arg0&, const char*, const Arg1&, const char*) [with Pred = boost::test_tools::tt_detail::equal_impl_frwd, Arg0 = double, Arg1 = int, boost::test_tools::const_string = boost::unit_test::basic_cstring<const char>, size_t = long unsigned int]’
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/FauxWriterTest.cpp>:154:1:   instantiated from here
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:536:20: warning: comparing floating point with == or != is unsafe
[ 74%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/FileUtilsTest.cpp.o
[ 75%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/InPlaceReprojectionFilterTest.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/InPlaceReprojectionFilterTest.cpp>:35:
/var/lib/jenkins/local/include/boost/test/floating_point_comparison.hpp:233:34:   instantiated from ‘boost::test_tools::predicate_result boost::test_tools::check_is_close_t::operator()(FPT1, FPT2, boost::test_tools::percent_tolerance_t<ToleranceBaseType>, boost::test_tools::floating_point_comparison_type) const [with FPT1 = double, FPT2 = double, ToleranceBaseType = int]’
/var/lib/jenkins/local/include/boost/test/test_tools.hpp:523:1:   instantiated from ‘bool boost::test_tools::tt_detail::check_frwd(Pred, const boost::unit_test::lazy_ostream&, boost::test_tools::const_string, size_t, boost::test_tools::tt_detail::tool_level, boost::test_tools::tt_detail::check_type, const Arg0&, const char*, const Arg1&, const char*, const Arg2&, const char*) [with Pred = boost::test_tools::check_is_close_t, Arg0 = double, Arg1 = double, Arg2 = boost::test_tools::percent_tolerance_t<int>, boost::test_tools::const_string = boost::unit_test::basic_cstring<const char>, size_t = long unsigned int]’
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/InPlaceReprojectionFilterTest.cpp>:139:1:   instantiated from here
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/InPlaceReprojectionFilterTest.cpp>:38:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/InPlaceReprojectionFilterTest.cpp>:102:200:   instantiated from here
[ 76%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/LasReaderTest.cpp.o
[ 77%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/LasWriterTest.cpp.o
[ 78%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/MosaicFilterTest.cpp.o
[ 78%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/OptionsTest.cpp.o
[ 79%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PipelineManagerTest.cpp.o
[ 80%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PipelineReaderTest.cpp.o
[ 81%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PipelineWriterTest.cpp.o
[ 82%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PointBufferCacheTest.cpp.o
[ 83%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PointBufferTest.cpp.o
[ 84%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/QFITReaderTest.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/QFITReaderTest.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/QFITReaderTest.cpp>:179:1:   instantiated from here
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/QFITReaderTest.cpp>:39:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/QFITReaderTest.cpp>:103:60:   instantiated from here
[ 84%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/RangeTest.cpp.o
[ 85%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ReprojectionFilterTest.cpp.o
[ 86%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ScalingFilterTest.cpp.o
[ 87%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SchemaLayoutTest.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/SchemaLayoutTest.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/SchemaLayoutTest.cpp>:57:1:   instantiated from here
[ 88%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SchemaTest.cpp.o
[ 89%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SpatialReferenceTest.cpp.o
[ 89%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/StageFactoryTest.cpp.o
[ 90%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/StatsFilterTest.cpp.o
[ 91%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/StreamManagerTest.cpp.o
[ 92%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SupportTest.cpp.o
[ 93%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/TerraSolidTest.cpp.o
[ 94%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/UserCallbackTest.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/UserCallbackTest.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/UserCallbackTest.cpp>:115:1:   instantiated from here
[ 94%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/UtilsTest.cpp.o
[ 95%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/VectorTest.cpp.o
[ 96%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/XMLSchemaTest.cpp.o
[ 97%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/OCITest.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/OCITest.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/OCITest.cpp>:213:1:   instantiated from here
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/../../include/pdal/drivers/oci/Reader.hpp>:38,
                 from <http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/OCITest.cpp>:39:
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/OCITest.cpp>:113:44:   instantiated from here
[ 98%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/Support.cpp.o
[ 99%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/TestConfig.cpp.o
[100%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/main.cpp.o
Linking CXX executable ../../bin/pdal_test
[100%] Built target pdal_test
Running 146 test cases...
<http://jenkins.pointcloud.org/job/PDAL/ws/test/unit/pcinfoTest.cpp(166)>: error in "pcinfo_test_dumps": check were_equal failed
./bin/pcinfo --output=test/data/../temp/pcinfo_stats.txt --stats test/data/apps/simple.las
*** 1 failure detected in test suite "Main"
Build step 'Execute shell' marked build as failure
More information about the pdal-commits mailing list
