[pdal-commits] Build failed in Jenkins: PDAL #18
Github
noreply at github.com
Tue Feb 7 13:08:37 EST 2012
See <http://jenkins.pointcloud.org/job/PDAL/18/changes>
Changes:
[hobu.inc] logging of which dimensions we're sampling
[hobu.inc] add a seed option for the stats option
[hobu.inc] more logging for stats filter
[...truncated 40 lines...]
-- Found GDAL: /var/lib/jenkins/local/lib/libgdal.so (Required is at least version "1.6.0")
-- Searching for GeoTIFF 1.2.5+ library
-- Found GeoTIFF version: 1.4.0
-- Found GeoTIFF: /var/lib/jenkins/local/lib/libgeotiff.so (Required is at least version "1.2.5")
-- Found TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so
-- Looking for iconv
-- Looking for iconv - found
-- Found iconv library:
-- Found LibXml2: /usr/lib/libxml2.so
-- Searching for Oracle + OCI client library
-- Found ORACLE: /u01/app/oracle/product/11.2.0/dbhome_1/lib/libclntsh.so;/u01/app/oracle/product/11.2.0/dbhome_1/lib/libocci.so;/u01/app/oracle/product/11.2.0/dbhome_1/lib/libnnz11.so
-- Searching for LASzip 1.0.1+ library
-- Found LASzip version: 2.1.0
-- Found LASzip: /var/lib/jenkins/local/lib/liblaszip.so (Required is at least version "1.0.1")
-- Enable PDAL unit tests to build - done
-- Configuring done
-- Generating done
-- Build files have been written to: <http://jenkins.pointcloud.org/job/PDAL/ws/>
Scanning dependencies of target pdal
[ 1%] Building CXX object src/CMakeFiles/pdal.dir/GDALUtils.cpp.o
[ 2%] Building CXX object src/CMakeFiles/pdal.dir/Bounds.cpp.o
[ 3%] Building CXX object src/CMakeFiles/pdal.dir/Dimension.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/external/boost/uuid/seed_rng.hpp>: In member function ‘void pdal::external::boost::uuids::detail::seed_rng::sha1_random_digest_()’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/external/boost/uuid/seed_rng.hpp>:154:53: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result
[ 3%] Building CXX object src/CMakeFiles/pdal.dir/FileUtils.cpp.o
[ 4%] Building CXX object src/CMakeFiles/pdal.dir/Filter.cpp.o
[ 5%] Building CXX object src/CMakeFiles/pdal.dir/FilterIterator.cpp.o
[ 6%] Building CXX object src/CMakeFiles/pdal.dir/Log.cpp.o
[ 7%] Building CXX object src/CMakeFiles/pdal.dir/MetadataRecord.cpp.o
[ 8%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilter.cpp.o
[ 8%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilterIterator.cpp.o
[ 9%] Building CXX object src/CMakeFiles/pdal.dir/Options.cpp.o
[ 10%] Building CXX object src/CMakeFiles/pdal.dir/PipelineManager.cpp.o
[ 11%] Building CXX object src/CMakeFiles/pdal.dir/PipelineReader.cpp.o
[ 12%] Building CXX object src/CMakeFiles/pdal.dir/PipelineWriter.cpp.o
[ 13%] Building CXX object src/CMakeFiles/pdal.dir/PointBuffer.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/PointBuffer.hpp>:40:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/PointBuffer.cpp>:35:
/var/lib/jenkins/local/include/boost/lexical_cast.hpp: In member function ‘bool boost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::shl_double(double, T*) [with T = char, CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’:
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1299:86: instantiated from ‘bool boost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::operator<<(double) [with CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1749:17: instantiated from ‘static Target boost::detail::lexical_cast_do_cast<Target, Source>::lexical_cast_impl(const Source&) [with Target = std::basic_string<char>, Source = double]’
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1916:50: instantiated from ‘Target boost::lexical_cast(const Source&) [with Target = std::basic_string<char>, Source = double]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/PointBuffer.cpp>:186:35: instantiated from here
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1184:17: warning: ISO C++ does not support the ‘%lg’ gnu_printf format
[ 14%] Building CXX object src/CMakeFiles/pdal.dir/Range.cpp.o
[ 14%] Building CXX object src/CMakeFiles/pdal.dir/Reader.cpp.o
[ 15%] Building CXX object src/CMakeFiles/pdal.dir/ReaderIterator.cpp.o
[ 16%] Building CXX object src/CMakeFiles/pdal.dir/Schema.cpp.o
[ 17%] Building CXX object src/CMakeFiles/pdal.dir/SpatialReference.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_srs_api.h:34:0,
from /var/lib/jenkins/local/include/ogr_spatialref.h:34,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/SpatialReference.cpp>:44:
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:58:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope3D::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:155:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:94: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
[ 18%] Building CXX object src/CMakeFiles/pdal.dir/Stage.cpp.o
[ 19%] Building CXX object src/CMakeFiles/pdal.dir/StageBase.cpp.o
[ 19%] Building CXX object src/CMakeFiles/pdal.dir/StageFactory.cpp.o
[ 20%] Building CXX object src/CMakeFiles/pdal.dir/StageIterator.cpp.o
[ 21%] Building CXX object src/CMakeFiles/pdal.dir/StreamManager.cpp.o
[ 22%] Building CXX object src/CMakeFiles/pdal.dir/UserCallback.cpp.o
[ 23%] Building CXX object src/CMakeFiles/pdal.dir/Utils.cpp.o
[ 24%] Building CXX object src/CMakeFiles/pdal.dir/Vector.cpp.o
[ 24%] Building CXX object src/CMakeFiles/pdal.dir/Writer.cpp.o
[ 25%] Building CXX object src/CMakeFiles/pdal.dir/XMLSchema.cpp.o
[ 26%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Reader.cpp.o
[ 27%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Writer.cpp.o
[ 28%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/GeotiffSupport.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/las/GeotiffSupport.cpp>:40:
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/ZipPoint.cpp.o
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Header.cpp.o
[ 30%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderReader.cpp.o
[ 31%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderWriter.cpp.o
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Reader.cpp.o
[ 33%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/SummaryData.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Support.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/VariableLengthRecord.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Writer.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/oci_wrapper.cpp.o
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/common.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Reader.cpp.o
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Writer.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_api.h:42:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/oci/Writer.cpp>:47:
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/drivers/pipeline/Reader.cpp.o
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/drivers/qfit/Reader.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Options.hpp>:42:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/StageBase.hpp>:42,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Stage.hpp>:40,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Reader.hpp>:38,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/drivers/qfit/Reader.hpp>:38,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/qfit/Reader.cpp>:170:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Options.hpp>:166:9: instantiated from ‘void pdal::Option::setValue(const T&) [with T = double]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Options.hpp>:100:9: instantiated from ‘pdal::Option::Option(const std::string&, const T&, const std::string&) [with T = double, std::string = std::basic_string<char>]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/qfit/Reader.cpp>:454:83: instantiated from here
[ 41%] Building CXX object src/CMakeFiles/pdal.dir/drivers/terrasolid/Reader.cpp.o
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/filters/ByteSwap.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/ByteSwap.cpp>: In member function ‘virtual uint32_t pdal::filters::iterators::sequential::ByteSwap::readBufferImpl(pdal::PointBuffer&)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/ByteSwap.cpp>:176:31: warning: unused variable ‘numSrcPointsRead’
[ 43%] Building CXX object src/CMakeFiles/pdal.dir/filters/Cache.cpp.o
[ 44%] Building CXX object src/CMakeFiles/pdal.dir/filters/Chipper.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Chipper.cpp>: In member function ‘void pdal::filters::Chipper::Load(pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Chipper.cpp>:199:25: warning: unused variable ‘num_to_read’
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/filters/Color.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/filters/Colorization.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Colorization.cpp>:45:
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/Filter.hpp>:40,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/filters/Colorization.hpp>:38,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Colorization.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Colorization.cpp>:108:68: instantiated from here
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/filters/Crop.cpp.o
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/filters/Decimation.cpp.o
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/filters/InPlaceReprojection.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:43:
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/filters/InPlaceReprojection.hpp>:38,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:176:184: instantiated from here
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/filters/Mosaic.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/filters/PointBufferCache.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/filters/Reprojection.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Reprojection.cpp>:44:
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/filters/Scaling.cpp.o
[ 52%] Building CXX object src/CMakeFiles/pdal.dir/filters/Stats.cpp.o
[ 53%] Building CXX object src/CMakeFiles/pdal.dir/pdal_config.cpp.o
Linking CXX shared library ../bin/libpdal.so
[ 53%] Built target pdal
Scanning dependencies of target pc2pc
[ 53%] Building CXX object apps/CMakeFiles/pc2pc.dir/pc2pc.cpp.o
[ 54%] Building CXX object apps/CMakeFiles/pc2pc.dir/Application.cpp.o
[ 55%] Building CXX object apps/CMakeFiles/pc2pc.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pc2pc
[ 55%] Built target pc2pc
Scanning dependencies of target pcinfo
[ 56%] Building CXX object apps/CMakeFiles/pcinfo.dir/pcinfo.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/apps/pcinfo.cpp>: In member function ‘virtual int PcInfo::execute()’:
<http://jenkins.pointcloud.org/job/PDAL/ws/apps/pcinfo.cpp>:241:38: error: no match for ‘operator+’ in ‘((PcInfo*)this)->PcInfo::m_options + readerOptions’
/var/lib/jenkins/local/include/boost/system/error_code.hpp: At global scope:
/var/lib/jenkins/local/include/boost/system/error_code.hpp:214:36: warning: ‘boost::system::posix_category’ defined but not used
/var/lib/jenkins/local/include/boost/system/error_code.hpp:215:36: warning: ‘boost::system::errno_ecat’ defined but not used
/var/lib/jenkins/local/include/boost/system/error_code.hpp:216:36: warning: ‘boost::system::native_ecat’ defined but not used
make[2]: *** [apps/CMakeFiles/pcinfo.dir/pcinfo.cpp.o] Error 1
make[1]: *** [apps/CMakeFiles/pcinfo.dir/all] Error 2
make: *** [all] Error 2
test/jenkins.sh: 9: ./bin/pdal_test: not found
Build step 'Execute shell' marked build as failure
More information about the pdal-commits
