[pdal-commits] Build failed in Jenkins: PDAL-boost-embed #7
Github noreply at github.com
Fri Feb 10 18:35:20 EST 2012
See <http://jenkins.pointcloud.org/job/PDAL-boost-embed/7/changes>
Changes:
[hobu.inc] if we are embedding boost, we do not add dyn_link definition
[hobu.inc] we are going to use bjam in a command to staticly build boost instead of cmake. pick up the .a files it creates as Boost_LIBRARIES
[hobu.inc] remove current embed in favor of one that is based explicitly on bjam
[hobu.inc] add boost embeded with bjam support
[...truncated 253 lines...]
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/filters/Scaling.cpp.o
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/filters/Selector.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/Selector.cpp>: In member function ‘void pdal::filters::Selector::checkImpedance()’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/Selector.cpp>:68:14: warning: unused variable ‘options’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/Selector.cpp>: In member function ‘virtual uint32_t pdal::filters::iterators::sequential::Selector::readBufferImpl(pdal::PointBuffer&)’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/Selector.cpp>:262:19: warning: unused variable ‘schema’
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/filters/Stats.cpp.o
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/plang/AstNode.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>: In member function ‘virtual pdal::plang::AstNode* pdal::plang::AstTempVector::simplify(pdal::plang::SymbolTable&)’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:236:18: warning: unused variable ‘child’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>: In member function ‘pdal::plang::AstNode* pdal::plang::AstTempVector::fixOp1(pdal::plang::AstNode*, pdal::plang::AstNode*)’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_VariableUse’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_VariableDef’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Program’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Add’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Subtract’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Multiply’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Divide’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Greater’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_GreaterEq’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Less’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_LessEq’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Equal’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_NotEqual’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_ArithXor’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_ArithAnd’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_ArithOr’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_LogicalAnd’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_LogicalOr’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Constant’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Negate’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Convert’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_Variable’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:319:12: warning: enumeration value ‘NodeType_NopV’ not handled in switch
In file included from /var/lib/jenkins/local/include/boost/variant.hpp:17:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/../include/pdal/plang/Parser.hpp>:41,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/../include/pdal/plang/SymbolTable.hpp>:40,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/../include/pdal/plang/AstNode.hpp>:40,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:35:
/var/lib/jenkins/local/include/boost/variant/variant.hpp: In member function ‘bool boost::detail::variant::equal_comp::operator()(const T&, const T&) const [with T = float]’:
/var/lib/jenkins/local/include/boost/variant/variant.hpp:789:47:   instantiated from ‘bool boost::detail::variant::comparer<Variant, Comp>::operator()(const T&) const [with T = float, Variant = boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, Comp = boost::detail::variant::equal_comp]’
/var/lib/jenkins/local/include/boost/variant/variant.hpp:858:32:   instantiated from ‘boost::detail::variant::invoke_visitor<Visitor>::result_type boost::detail::variant::invoke_visitor<Visitor>::internal_visit(T&, int) [with T = const float, Visitor = boost::detail::variant::comparer<boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, boost::detail::variant::equal_comp>, boost::detail::variant::invoke_visitor<Visitor>::result_type = bool]’
/var/lib/jenkins/local/include/boost/variant/detail/visitation_impl.hpp:130:9:   instantiated from ‘typename Visitor::result_type boost::detail::variant::visitation_impl_invoke_impl(int, Visitor&, VoidPtrCV, T*, mpl_::true_) [with Visitor = boost::detail::variant::invoke_visitor<boost::detail::variant::comparer<boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, boost::detail::variant::equal_comp> >, VoidPtrCV = const void*, T = float, typename Visitor::result_type = bool, mpl_::true_ = mpl_::bool_<true>]’
/var/lib/jenkins/local/include/boost/variant/detail/visitation_impl.hpp:173:9:   instantiated from ‘typename Visitor::result_type boost::detail::variant::visitation_impl_invoke(int, Visitor&, VoidPtrCV, T*, NoBackupFlag, int) [with Visitor = boost::detail::variant::invoke_visitor<boost::detail::variant::comparer<boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, boost::detail::variant::equal_comp> >, VoidPtrCV = const void*, T = float, NoBackupFlag = boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>::has_fallback_type_, typename Visitor::result_type = bool]’
/var/lib/jenkins/local/include/boost/variant/detail/visitation_impl.hpp:260:1:   instantiated from ‘typename Visitor::result_type boost::detail::variant::visitation_impl(int, int, Visitor&, VoidPtrCV, mpl_::false_, NoBackupFlag, Which*, step0*) [with Which = mpl_::int_<0>, step0 = boost::detail::variant::visitation_impl_step<boost::mpl::l_iter<boost::mpl::l_item<mpl_::long_<11l>, unsigned char, boost::mpl::l_item<mpl_::long_<10l>, short unsigned int, boost::mpl::l_item<mpl_::long_<9l>, unsigned int, boost::mpl::l_item<mpl_::long_<8l>, long unsigned int, boost::mpl::l_item<mpl_::long_<7l>, signed char, boost::mpl::l_item<mpl_::long_<6l>, short int, boost::mpl::l_item<mpl_::long_<5l>, int, boost::mpl::l_item<mpl_::long_<4l>, long int, boost::mpl::l_item<mpl_::long_<3l>, float, boost::mpl::l_item<mpl_::long_<2l>, double, boost::mpl::l_item<mpl_::long_<1l>, bool, boost::mpl::l_end> > > > > > > > > > > >, boost::mpl::l_iter<boost::mpl::l_end> >, Visitor = boost::detail::variant::invoke_visitor<boost::detail::variant::comparer<boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, boost::detail::variant::equal_comp> >, VoidPtrCV = const void*, NoBackupFlag = boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>::has_fallback_type_, typename Visitor::result_type = bool, mpl_::false_ = mpl_::bool_<false>]’
/var/lib/jenkins/local/include/boost/variant/variant.hpp:1802:13:   instantiated from ‘static typename Visitor::result_type boost::variant<T0, T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T11, T12, T13, T14, T15, T16, T17, T18, T19>::internal_apply_visitor_impl(int, int, Visitor&, VoidPtrCV) [with Visitor = boost::detail::variant::invoke_visitor<boost::detail::variant::comparer<boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, boost::detail::variant::equal_comp> >, VoidPtrCV = const void*, T0_ = unsigned char, T1 = short unsigned int, T2 = unsigned int, T3 = long unsigned int, T4 = signed char, T5 = short int, T6 = int, T7 = long int, T8 = float, T9 = double, T10 = bool, T11 = boost::detail::variant::void_, T12 = boost::detail::variant::void_, T13 = boost::detail::variant::void_, T14 = boost::detail::variant::void_, T15 = boost::detail::variant::void_, T16 = boost::detail::variant::void_, T17 = boost::detail::variant::void_, T18 = boost::detail::variant::void_, T19 = boost::detail::variant::void_, typename Visitor::result_type = bool]’
/var/lib/jenkins/local/include/boost/variant/variant.hpp:1824:13:   instantiated from ‘typename Visitor::result_type boost::variant<T0, T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T11, T12, T13, T14, T15, T16, T17, T18, T19>::internal_apply_visitor(Visitor&) const [with Visitor = boost::detail::variant::invoke_visitor<boost::detail::variant::comparer<boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, boost::detail::variant::equal_comp> >, T0_ = unsigned char, T1 = short unsigned int, T2 = unsigned int, T3 = long unsigned int, T4 = signed char, T5 = short int, T6 = int, T7 = long int, T8 = float, T9 = double, T10 = bool, T11 = boost::detail::variant::void_, T12 = boost::detail::variant::void_, T13 = boost::detail::variant::void_, T14 = boost::detail::variant::void_, T15 = boost::detail::variant::void_, T16 = boost::detail::variant::void_, T17 = boost::detail::variant::void_, T18 = boost::detail::variant::void_, T19 = boost::detail::variant::void_, typename Visitor::result_type = bool]’
/var/lib/jenkins/local/include/boost/variant/variant.hpp:1846:52:   instantiated from ‘typename Visitor::result_type boost::variant<T0, T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T11, T12, T13, T14, T15, T16, T17, T18, T19>::apply_visitor(Visitor&) const [with Visitor = boost::detail::variant::comparer<boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, boost::detail::variant::equal_comp>, T0_ = unsigned char, T1 = short unsigned int, T2 = unsigned int, T3 = long unsigned int, T4 = signed char, T5 = short int, T6 = int, T7 = long int, T8 = float, T9 = double, T10 = bool, T11 = boost::detail::variant::void_, T12 = boost::detail::variant::void_, T13 = boost::detail::variant::void_, T14 = boost::detail::variant::void_, T15 = boost::detail::variant::void_, T16 = boost::detail::variant::void_, T17 = boost::detail::variant::void_, T18 = boost::detail::variant::void_, T19 = boost::detail::variant::void_, typename Visitor::result_type = bool]’
/var/lib/jenkins/local/include/boost/variant/variant.hpp:1745:41:   instantiated from ‘bool boost::variant<T0, T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T11, T12, T13, T14, T15, T16, T17, T18, T19>::operator==(const boost::variant<T0, T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T11, T12, T13, T14, T15, T16, T17, T18, T19>&) const [with T0_ = unsigned char, T1 = short unsigned int, T2 = unsigned int, T3 = long unsigned int, T4 = signed char, T5 = short int, T6 = int, T7 = long int, T8 = float, T9 = double, T10 = bool, T11 = boost::detail::variant::void_, T12 = boost::detail::variant::void_, T13 = boost::detail::variant::void_, T14 = boost::detail::variant::void_, T15 = boost::detail::variant::void_, T16 = boost::detail::variant::void_, T17 = boost::detail::variant::void_, T18 = boost::detail::variant::void_, T19 = boost::detail::variant::void_, boost::variant<T0, T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T11, T12, T13, T14, T15, T16, T17, T18, T19> = boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>]’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstNode.cpp>:772:57:   instantiated from here
/var/lib/jenkins/local/include/boost/variant/variant.hpp:807:23: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/boost/variant/variant.hpp: In member function ‘bool boost::detail::variant::equal_comp::operator()(const T&, const T&) const [with T = double]’:
/var/lib/jenkins/local/include/boost/variant/variant.hpp:789:47:   instantiated from ‘bool boost::detail::variant::comparer<Variant, Comp>::operator()(const T&) const [with T = double, Variant = boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, Comp = boost::detail::variant::equal_comp]’
/var/lib/jenkins/local/include/boost/variant/variant.hpp:858:32:   instantiated from ‘boost::detail::variant::invoke_visitor<Visitor>::result_type boost::detail::variant::invoke_visitor<Visitor>::internal_visit(T&, int) [with T = const double, Visitor = boost::detail::variant::comparer<boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, boost::detail::variant::equal_comp>, boost::detail::variant::invoke_visitor<Visitor>::result_type = bool]’
/var/lib/jenkins/local/include/boost/variant/detail/visitation_impl.hpp:130:9:   instantiated from ‘typename Visitor::result_type boost::detail::variant::visitation_impl_invoke_impl(int, Visitor&, VoidPtrCV, T*, mpl_::true_) [with Visitor = boost::detail::variant::invoke_visitor<boost::detail::variant::comparer<boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, boost::detail::variant::equal_comp> >, VoidPtrCV = const void*, T = double, typename Visitor::result_type = bool, mpl_::true_ = mpl_::bool_<true>]’
/var/lib/jenkins/local/include/boost/variant/detail/visitation_impl.hpp:173:9:   instantiated from ‘typename Visitor::result_type boost::detail::variant::visitation_impl_invoke(int, Visitor&, VoidPtrCV, T*, NoBackupFlag, int) [with Visitor = boost::detail::variant::invoke_visitor<boost::detail::variant::comparer<boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>, boost::detail::variant::equal_comp> >, VoidPtrCV = const void*, T = double, NoBackupFlag = boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>::has_fallback_type_, typename Visitor::result_type = bool]’
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/plang/AstUtils.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstUtils.cpp>: In static member function ‘static std::string pdal::plang::AstUtils::getName(pdal::plang::NodeType)’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstUtils.cpp>:368:12: warning: enumeration value ‘NodeType_VariableUse’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstUtils.cpp>:368:12: warning: enumeration value ‘NodeType_VariableDef’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstUtils.cpp>:368:12: warning: enumeration value ‘NodeType_Program’ not handled in switch
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstUtils.cpp>: In function ‘void pdal::plang::do_equality(pdal::plang::variant_t, pdal::plang::variant_t, pdal::plang::variant_t&, pdal::plang::NodeType) [with T = float, pdal::plang::variant_t = boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>]’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstUtils.cpp>:271:92:   instantiated from here
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstUtils.cpp>:164:30: warning: comparing floating point with == or != is unsafe
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstUtils.cpp>:165:30: warning: comparing floating point with == or != is unsafe
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstUtils.cpp>: In function ‘void pdal::plang::do_equality(pdal::plang::variant_t, pdal::plang::variant_t, pdal::plang::variant_t&, pdal::plang::NodeType) [with T = double, pdal::plang::variant_t = boost::variant<unsigned char, short unsigned int, unsigned int, long unsigned int, signed char, short int, int, long int, float, double, bool>]’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/AstUtils.cpp>:272:93:   instantiated from here
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/plang/Parser.cpp.o
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/plang/Parser_qi.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:65:24: error: ‘pdalboostphoenix’ is not a namespace-name
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:65:40: error: expected namespace-name before ‘;’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>: In constructor ‘pdal::plang::PlangParser::PlangParser()’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:113:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:113:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:114:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:114:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:115:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:115:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:116:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:116:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:118:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:118:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:119:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:119:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:120:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:120:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:122:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:122:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:123:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:123:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:124:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:124:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:125:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:125:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:130:97: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:130:97: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:130:97: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:133:42: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:133:42: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:133:42: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:134:42: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:134:42: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:134:42: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:135:42: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:135:42: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:135:42: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:136:42: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:136:42: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:136:42: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:137:42: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:137:42: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:137:42: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:138:42: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:138:42: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:138:42: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:139:42: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:139:42: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:139:42: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:140:42: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:140:42: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:140:42: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:144:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:144:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:147:52: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:147:52: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:147:52: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:150:36: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:150:36: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:150:36: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:151:36: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:151:36: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:151:36: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:152:36: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:152:36: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:152:36: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:153:36: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:153:36: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:153:36: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:154:36: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:154:36: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:154:36: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:158:40: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:158:40: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:161:42: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:161:42: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:161:42: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:164:38: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:164:38: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:164:38: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:165:38: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:165:38: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:165:38: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:169:40: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:169:40: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:172:44: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:172:44: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:172:44: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:176:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:176:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:176:49: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:177:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:177:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:177:49: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:178:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:178:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:178:49: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:179:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:179:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:179:49: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:180:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:180:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:180:49: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:181:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:181:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:181:49: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:182:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:182:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:182:49: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:183:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:183:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:183:49: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:184:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:184:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:184:49: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:185:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:185:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:185:49: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:186:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:186:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:188:49: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:188:49: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:196:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:196:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:196:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:199:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:199:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:199:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:200:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:200:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:200:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:201:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:201:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:201:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:202:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:202:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:202:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:203:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:203:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:203:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:204:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:204:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:204:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:205:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:205:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:205:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:206:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:206:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:206:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:207:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:207:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:207:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:208:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:208:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:208:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:209:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:209:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:209:50: warning: left-hand operand of comma has no effect
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:213:50: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:213:50: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:216:48: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:216:48: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:219:51: error: ‘pho’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:219:51: error: expected primary-expression before ‘>’ token
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/plang/Parser_qi.cpp>:219:51: warning: left-hand operand of comma has no effect
make[2]: *** [src/CMakeFiles/pdal.dir/plang/Parser_qi.cpp.o] Error 1
make[1]: *** [src/CMakeFiles/pdal.dir/all] Error 2
make: *** [all] Error 2
test/jenkins.sh: line 14: ./bin/pdal_test: No such file or directory
Build step 'Execute shell' marked build as failure
More information about the pdal-commits mailing list
