[pdal-commits] Build failed in Jenkins: PDAL #83
Github
noreply at github.com
Mon Mar 12 19:49:22 EDT 2012
See <http://jenkins.pointcloud.org/job/PDAL/83/changes>
Changes:
[mpg] remove Qi parser, good riddance; fix some build issues for Mr Jenkins
Started by GitHub push by
Building in workspace <http://jenkins.pointcloud.org/job/PDAL/ws/>
Checkout:workspace / <http://jenkins.pointcloud.org/job/PDAL/ws/> - hudson.remoting.LocalChannel at 6c11e58
Using strategy: Default
Last Built Revision: Revision f60520751d4bffceb561e0e3469b13c1b3e3a2d6 (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from git://github.com/PDAL/PDAL.git
Commencing build of Revision e7a9ee1d463fd72c7cf0fa8f8fb64fc68b36de6f (origin/master)
Checking out Revision e7a9ee1d463fd72c7cf0fa8f8fb64fc68b36de6f (origin/master)
Cleaning workspace
[workspace] $ /bin/sh -xe /tmp/hudson1118179926483719342.sh
+ test/jenkins.sh
running: cmake -G "Unix Makefiles" -C test/BuildSetup.jenkins .
loading initial cache file test/BuildSetup.jenkins
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Setting PDAL build type - Release
-- Boost version: 1.48.0
-- Found the following Boost libraries:
-- program_options
-- thread
-- iostreams
-- filesystem
-- system
-- unit_test_framework
-- random
-- Searching for GDAL 1.9.0+ library
-- Found GDAL: /var/lib/jenkins/local/lib/libgdal.so (Required is at least version "1.9.0")
-- ...building with GDAL
-- Searching for GeoTIFF 1.2.5+ library
-- Found GeoTIFF version: 1.4.0
-- Found GeoTIFF: /var/lib/jenkins/local/lib/libgeotiff.so (Required is at least version "1.2.5")
-- Found TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so
-- Looking for iconv
-- Looking for iconv - found
-- Found iconv library:
-- Found LibXml2: /usr/lib/libxml2.so
-- Searching for Oracle + OCI client library
-- Found ORACLE: /u01/app/oracle/product/11.2.0/dbhome_1/lib/libclntsh.so;/u01/app/oracle/product/11.2.0/dbhome_1/lib/libocci.so;/u01/app/oracle/product/11.2.0/dbhome_1/lib/libnnz11.so
-- ...building with Oracle
-- Searching for LASzip 1.0.1+ library
-- Found LASzip version: 2.1.0
-- Found LASzip: /var/lib/jenkins/local/lib/liblaszip.so (Required is at least version "1.0.1")
-- Using boost lib: optimized;/var/lib/jenkins/local/lib/libboost_program_options.a;debug;/var/lib/jenkins/local/lib/libboost_program_options.a;optimized;/var/lib/jenkins/local/lib/libboost_thread.a;debug;/var/lib/jenkins/local/lib/libboost_thread.a;optimized;/var/lib/jenkins/local/lib/libboost_iostreams.a;debug;/var/lib/jenkins/local/lib/libboost_iostreams.a;optimized;/var/lib/jenkins/local/lib/libboost_filesystem.a;debug;/var/lib/jenkins/local/lib/libboost_filesystem.a;optimized;/var/lib/jenkins/local/lib/libboost_system.a;debug;/var/lib/jenkins/local/lib/libboost_system.a;optimized;/var/lib/jenkins/local/lib/libboost_unit_test_framework.a;debug;/var/lib/jenkins/local/lib/libboost_unit_test_framework.a;optimized;/var/lib/jenkins/local/lib/libboost_random.a;debug;/var/lib/jenkins/local/lib/libboost_random.a
-- Building with PDAL unit tests
-- Static boost for boost::unit_test, not setting BOOST_TEST_DYN_LINK
-- Configuring done
-- Generating done
-- Build files have been written to: <http://jenkins.pointcloud.org/job/PDAL/ws/>
Scanning dependencies of target pdal
[ 1%] Building CXX object src/CMakeFiles/pdal.dir/GDALUtils.cpp.o
[ 2%] Building CXX object src/CMakeFiles/pdal.dir/Bounds.cpp.o
[ 3%] Building CXX object src/CMakeFiles/pdal.dir/Dimension.cpp.o
/var/lib/jenkins/local/include/boost/uuid/seed_rng.hpp: In member function ‘void boost::uuids::detail::seed_rng::sha1_random_digest_()’:
/var/lib/jenkins/local/include/boost/uuid/seed_rng.hpp:152:53: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result
[ 4%] Building CXX object src/CMakeFiles/pdal.dir/FileUtils.cpp.o
[ 4%] Building CXX object src/CMakeFiles/pdal.dir/Filter.cpp.o
[ 5%] Building CXX object src/CMakeFiles/pdal.dir/FilterIterator.cpp.o
[ 6%] Building CXX object src/CMakeFiles/pdal.dir/Log.cpp.o
[ 7%] Building CXX object src/CMakeFiles/pdal.dir/MetadataRecord.cpp.o
[ 7%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilter.cpp.o
[ 8%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilterIterator.cpp.o
[ 9%] Building CXX object src/CMakeFiles/pdal.dir/Options.cpp.o
[ 10%] Building CXX object src/CMakeFiles/pdal.dir/PipelineManager.cpp.o
[ 10%] Building CXX object src/CMakeFiles/pdal.dir/PipelineReader.cpp.o
[ 11%] Building CXX object src/CMakeFiles/pdal.dir/PipelineWriter.cpp.o
[ 12%] Building CXX object src/CMakeFiles/pdal.dir/PointBuffer.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/PointBuffer.hpp>:40:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/PointBuffer.cpp>:35:
/var/lib/jenkins/local/include/boost/lexical_cast.hpp: In member function ‘bool boost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::shl_double(double, T*) [with T = char, CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’:
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1299:86: instantiated from ‘bool boost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::operator<<(double) [with CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1749:17: instantiated from ‘static Target boost::detail::lexical_cast_do_cast<Target, Source>::lexical_cast_impl(const Source&) [with Target = std::basic_string<char>, Source = double]’
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1916:50: instantiated from ‘Target boost::lexical_cast(const Source&) [with Target = std::basic_string<char>, Source = double]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/PointBuffer.cpp>:289:35: instantiated from here
/var/lib/jenkins/local/include/boost/lexical_cast.hpp:1184:17: warning: ISO C++ does not support the ‘%lg’ gnu_printf format
[ 13%] Building CXX object src/CMakeFiles/pdal.dir/Range.cpp.o
[ 14%] Building CXX object src/CMakeFiles/pdal.dir/Reader.cpp.o
[ 14%] Building CXX object src/CMakeFiles/pdal.dir/ReaderIterator.cpp.o
[ 15%] Building CXX object src/CMakeFiles/pdal.dir/Schema.cpp.o
[ 16%] Building CXX object src/CMakeFiles/pdal.dir/SpatialReference.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_srs_api.h:34:0,
from /var/lib/jenkins/local/include/ogr_spatialref.h:34,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/SpatialReference.cpp>:45:
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:58:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope3D::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:155:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:94: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
[ 17%] Building CXX object src/CMakeFiles/pdal.dir/Stage.cpp.o
[ 17%] Building CXX object src/CMakeFiles/pdal.dir/StageBase.cpp.o
[ 18%] Building CXX object src/CMakeFiles/pdal.dir/StageFactory.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>: In function ‘pdal::Filter* pdal::create_Predicate(pdal::Stage&, const pdal::Options&)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:147:5: error: expected type-specifier
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:147:5: error: cannot convert ‘int*’ to ‘pdal::Filter*’ in return
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:147:5: error: expected ‘;’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:147:5: error: ‘Predicate’ is not a member of ‘pdal::filters’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>: In function ‘pdal::Filter* pdal::create_Programmable(pdal::Stage&, const pdal::Options&)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:148:5: error: expected type-specifier
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:148:5: error: cannot convert ‘int*’ to ‘pdal::Filter*’ in return
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:148:5: error: expected ‘;’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:148:5: error: ‘Programmable’ is not a member of ‘pdal::filters’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>: In member function ‘void pdal::StageFactory::registerKnownFilters()’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:329:5: error: ‘pdal::filters::Predicate’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:330:5: error: ‘pdal::filters::Programmable’ has not been declared
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>: In member function ‘void pdal::StageFactory::loadPlugins()’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:460:32: warning: ISO C++ forbids casting between pointer-to-function and pointer-to-object
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:148:5: warning: control reaches end of non-void function
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:147:5: warning: control reaches end of non-void function
make[2]: *** [src/CMakeFiles/pdal.dir/StageFactory.cpp.o] Error 1
make[1]: *** [src/CMakeFiles/pdal.dir/all] Error 2
make: *** [all] Error 2
test/jenkins.sh: line 16: ./bin/pdal_test: No such file or directory
Build step 'Execute shell' marked build as failure
More information about the pdal-commits
