[pdal-commits] Build failed in Jenkins: PDAL-boost-embed #56
Github noreply at github.com
Tue Mar 13 12:17:13 EDT 2012
See <http://jenkins.pointcloud.org/job/PDAL-boost-embed/56/changes>
Changes:
[hobu.inc] fix up casts and use <numpy/arrayobject.h> include statement
[hobu.inc] FindNumPy added and used
[...truncated 68 lines...]
[  9%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/iostreams/src/file_descriptor.cpp.o
[  9%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/iostreams/src/mapped_file.cpp.o
[ 10%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/cmdline.cpp.o
[ 10%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/config_file.cpp.o
[ 11%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/convert.cpp.o
[ 11%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/options_description.cpp.o
[ 12%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/parsers.cpp.o
[ 13%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/positional_options.cpp.o
[ 13%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/split.cpp.o
[ 14%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/utf8_codecvt_facet.cpp.o
[ 14%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/value_semantic.cpp.o
[ 15%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/variables_map.cpp.o
[ 15%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/winmain.cpp.o
[ 16%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/system/src/error_code.cpp.o
[ 16%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/compiler_log_formatter.cpp.o
[ 17%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/cpp_main.cpp.o
[ 18%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/debug.cpp.o
[ 18%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/exception_safety.cpp.o
[ 19%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/execution_monitor.cpp.o
[ 19%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/framework.cpp.o
[ 20%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/interaction_based.cpp.o
[ 20%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/logged_expectations.cpp.o
[ 21%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/plain_report_formatter.cpp.o
[ 21%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/progress_monitor.cpp.o
[ 22%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/results_collector.cpp.o
[ 22%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/results_reporter.cpp.o
[ 23%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/test_main.cpp.o
[ 24%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/test_tools.cpp.o
[ 24%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_log.cpp.o
[ 25%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_main.cpp.o
[ 25%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_monitor.cpp.o
[ 26%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_parameters.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/utils/runtime/env/variable.hpp>:190:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/impl/unit_test_parameters.ipp>:39,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/test/src/unit_test_parameters.cpp>:16:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/utils/runtime/env/environment.hpp>:103:27: warning: redundant redeclaration of ‘pdalboost::runtime::environment::variable_base pdalboost::runtime::environment::var(pdalboost::runtime::cstring)’ in same scope
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/utils/runtime/env/fwd.hpp>:32:15: warning: previous declaration of ‘pdalboost::runtime::environment::variable_base pdalboost::runtime::environment::var(pdalboost::runtime::cstring)’
[ 26%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_suite.cpp.o
[ 27%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/xml_log_formatter.cpp.o
[ 27%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/xml_report_formatter.cpp.o
[ 28%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/thread/src/pthread/once.cpp.o
[ 29%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/thread/src/pthread/thread.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/condition_variable.hpp>:16:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/pthread/shared_mutex.hpp>:13,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/shared_mutex.hpp>:16,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/detail/thread_group.hpp>:9,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/thread.hpp>:24,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/thread/src/pthread/thread.cpp>:10:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/pthread/condition_variable.hpp>:18:51: warning: redundant redeclaration of ‘void pdalboost::this_thread::interruption_point()’ in same scope
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/detail/thread.hpp>:378:32: warning: previous declaration of ‘void pdalboost::this_thread::interruption_point()’
Linking CXX static library ../bin/libpdalboost.a
[ 29%] Built target pdalboost
Scanning dependencies of target pdal
[ 30%] Building CXX object src/CMakeFiles/pdal.dir/GDALUtils.cpp.o
[ 31%] Building CXX object src/CMakeFiles/pdal.dir/Bounds.cpp.o
[ 31%] Building CXX object src/CMakeFiles/pdal.dir/Dimension.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/uuid/seed_rng.hpp>: In member function ‘void pdalboost::uuids::detail::seed_rng::sha1_random_digest_()’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/uuid/seed_rng.hpp>:152:53: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/FileUtils.cpp.o
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/Filter.cpp.o
[ 33%] Building CXX object src/CMakeFiles/pdal.dir/FilterIterator.cpp.o
[ 33%] Building CXX object src/CMakeFiles/pdal.dir/Log.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/MetadataRecord.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilter.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilterIterator.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/Options.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/PipelineManager.cpp.o
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/PipelineReader.cpp.o
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/PipelineWriter.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/PointBuffer.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/../include/pdal/PointBuffer.hpp>:40:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/PointBuffer.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/lexical_cast.hpp>: In member function ‘bool pdalboost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::shl_double(double, T*) [with T = char, CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/lexical_cast.hpp>:1298:86:   instantiated from ‘bool pdalboost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::operator<<(double) [with CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/lexical_cast.hpp>:1748:17:   instantiated from ‘static Target pdalboost::detail::lexical_cast_do_cast<Target, Source>::lexical_cast_impl(const Source&) [with Target = std::basic_string<char>, Source = double]’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/lexical_cast.hpp>:1915:50:   instantiated from ‘Target pdalboost::lexical_cast(const Source&) [with Target = std::basic_string<char>, Source = double]’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/PointBuffer.cpp>:289:35:   instantiated from here
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/lexical_cast.hpp>:1183:17: warning: ISO C++ does not support the ‘%lg’ gnu_printf format
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/Range.cpp.o
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/Reader.cpp.o
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/ReaderIterator.cpp.o
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/Schema.cpp.o
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/SpatialReference.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_srs_api.h:34:0,
                 from /var/lib/jenkins/local/include/ogr_spatialref.h:34,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/SpatialReference.cpp>:45:
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:58:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope3D::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:155:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:94: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
[ 41%] Building CXX object src/CMakeFiles/pdal.dir/Stage.cpp.o
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/StageBase.cpp.o
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/StageFactory.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/StageFactory.cpp>: In member function ‘void pdal::StageFactory::loadPlugins()’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/StageFactory.cpp>:466:32: warning: ISO C++ forbids casting between pointer-to-function and pointer-to-object
[ 43%] Building CXX object src/CMakeFiles/pdal.dir/StageIterator.cpp.o
[ 43%] Building CXX object src/CMakeFiles/pdal.dir/StreamManager.cpp.o
[ 44%] Building CXX object src/CMakeFiles/pdal.dir/UserCallback.cpp.o
[ 44%] Building CXX object src/CMakeFiles/pdal.dir/Utils.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/Vector.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/Writer.cpp.o
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/XMLSchema.cpp.o
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Reader.cpp.o
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Writer.cpp.o
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/GeotiffSupport.cpp.o
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/drivers/las/GeotiffSupport.cpp>:40:
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/ZipPoint.cpp.o
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Header.cpp.o
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderReader.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderWriter.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Reader.cpp.o
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/SummaryData.cpp.o
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Support.cpp.o
[ 52%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/VariableLengthRecord.cpp.o
[ 53%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Writer.cpp.o
[ 53%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/oci_wrapper.cpp.o
[ 54%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/common.cpp.o
[ 54%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Reader.cpp.o
[ 55%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Writer.cpp.o
[ 55%] Building CXX object src/CMakeFiles/pdal.dir/drivers/pipeline/Reader.cpp.o
[ 56%] Building CXX object src/CMakeFiles/pdal.dir/drivers/qfit/Reader.cpp.o
[ 56%] Building CXX object src/CMakeFiles/pdal.dir/drivers/terrasolid/Reader.cpp.o
[ 57%] Building CXX object src/CMakeFiles/pdal.dir/drivers/text/Writer.cpp.o
[ 57%] Building CXX object src/CMakeFiles/pdal.dir/filters/ByteSwap.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/ByteSwap.cpp>: In member function ‘virtual uint32_t pdal::filters::iterators::sequential::ByteSwap::readBufferImpl(pdal::PointBuffer&)’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/ByteSwap.cpp>:176:31: warning: unused variable ‘numSrcPointsRead’
[ 58%] Building CXX object src/CMakeFiles/pdal.dir/filters/Cache.cpp.o
[ 59%] Building CXX object src/CMakeFiles/pdal.dir/filters/Chipper.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/Chipper.cpp>: In member function ‘void pdal::filters::Chipper::Load(pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&)’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/filters/Chipper.cpp>:200:25: warning: unused variable ‘num_to_read’
[ 59%] Building CXX object src/CMakeFiles/pdal.dir/filters/Color.cpp.o
[ 60%] Building CXX object src/CMakeFiles/pdal.dir/filters/Colorization.cpp.o
[ 60%] Building CXX object src/CMakeFiles/pdal.dir/filters/Crop.cpp.o
[ 61%] Building CXX object src/CMakeFiles/pdal.dir/filters/Decimation.cpp.o
[ 61%] Building CXX object src/CMakeFiles/pdal.dir/filters/InPlaceReprojection.cpp.o
[ 62%] Building CXX object src/CMakeFiles/pdal.dir/filters/Mosaic.cpp.o
[ 62%] Building CXX object src/CMakeFiles/pdal.dir/filters/PointBufferCache.cpp.o
[ 63%] Building CXX object src/CMakeFiles/pdal.dir/filters/Predicate.cpp.o
[ 64%] Building CXX object src/CMakeFiles/pdal.dir/filters/Programmable.cpp.o
[ 64%] Building CXX object src/CMakeFiles/pdal.dir/filters/Reprojection.cpp.o
[ 65%] Building CXX object src/CMakeFiles/pdal.dir/filters/Scaling.cpp.o
[ 65%] Building CXX object src/CMakeFiles/pdal.dir/filters/Selector.cpp.o
[ 66%] Building CXX object src/CMakeFiles/pdal.dir/filters/Stats.cpp.o
[ 66%] Building CXX object src/CMakeFiles/pdal.dir/plang/PythonSupport.cpp.o
[ 67%] Building CXX object src/CMakeFiles/pdal.dir/pdal_config.cpp.o
Linking CXX shared library ../bin/libpdal.so
[ 67%] Built target pdal
Scanning dependencies of target pc2pc
[ 67%] Building CXX object apps/CMakeFiles/pc2pc.dir/pc2pc.cpp.o
[ 68%] Building CXX object apps/CMakeFiles/pc2pc.dir/Application.cpp.o
[ 68%] Building CXX object apps/CMakeFiles/pc2pc.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pc2pc
[ 68%] Built target pc2pc
Scanning dependencies of target pcinfo
[ 69%] Building CXX object apps/CMakeFiles/pcinfo.dir/pcinfo.cpp.o
[ 69%] Building CXX object apps/CMakeFiles/pcinfo.dir/Application.cpp.o
[ 70%] Building CXX object apps/CMakeFiles/pcinfo.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pcinfo
[ 70%] Built target pcinfo
Scanning dependencies of target pcpipeline
[ 70%] Building CXX object apps/CMakeFiles/pcpipeline.dir/pcpipeline.cpp.o
[ 71%] Building CXX object apps/CMakeFiles/pcpipeline.dir/Application.cpp.o
[ 71%] Building CXX object apps/CMakeFiles/pcpipeline.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pcpipeline
[ 71%] Built target pcpipeline
Scanning dependencies of target pdal_test
[ 71%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/pc2pcTest.cpp.o
[ 72%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/pcinfoTest.cpp.o
[ 72%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/pcpipelineTest.cpp.o
[ 73%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/BoundsTest.cpp.o
[ 74%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/BPFTest.cpp.o
[ 74%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ByteSwapFilterTest.cpp.o
[ 75%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/CacheFilterTest.cpp.o
[ 75%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ChipperTest.cpp.o
[ 76%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ColorFilterTest.cpp.o
[ 76%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ColorizationFilterTest.cpp.o
[ 77%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ConfigTest.cpp.o
[ 77%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/CropFilterTest.cpp.o
[ 78%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/DecimationFilterTest.cpp.o
[ 79%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/DimensionLayoutTest.cpp.o
[ 79%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/DimensionTest.cpp.o
[ 80%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/FauxReaderTest.cpp.o
[ 80%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/FauxWriterTest.cpp.o
[ 81%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/FileUtilsTest.cpp.o
[ 81%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/InPlaceReprojectionFilterTest.cpp.o
[ 82%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/LasReaderTest.cpp.o
[ 82%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/LasWriterTest.cpp.o
[ 83%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/MosaicFilterTest.cpp.o
[ 83%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/OptionsTest.cpp.o
[ 84%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PipelineManagerTest.cpp.o
[ 85%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PipelineReaderTest.cpp.o
[ 85%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PipelineWriterTest.cpp.o
[ 86%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PointBufferCacheTest.cpp.o
[ 86%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PointBufferTest.cpp.o
[ 87%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/QFITReaderTest.cpp.o
[ 87%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/RangeTest.cpp.o
[ 88%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ReprojectionFilterTest.cpp.o
[ 88%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ScalingFilterTest.cpp.o
[ 89%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SelectorFilterTest.cpp.o
[ 89%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SchemaLayoutTest.cpp.o
[ 90%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SchemaTest.cpp.o
[ 91%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SpatialReferenceTest.cpp.o
[ 91%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/StageFactoryTest.cpp.o
[ 92%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/StatsFilterTest.cpp.o
[ 92%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/StreamManagerTest.cpp.o
[ 93%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/SupportTest.cpp.o
[ 93%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/TerraSolidTest.cpp.o
[ 94%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/TextWriterTest.cpp.o
[ 94%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/UserCallbackTest.cpp.o
[ 95%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/UtilsTest.cpp.o
[ 96%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/VectorTest.cpp.o
[ 96%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/XMLSchemaTest.cpp.o
[ 97%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/OCITest.cpp.o
[ 97%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PythonInternalTest.cpp.o
[ 98%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/PredicateFilterTest.cpp.o
[ 98%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/ProgrammableFilterTest.cpp.o
[ 99%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/Support.cpp.o
[ 99%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/TestConfig.cpp.o
[100%] Building CXX object test/unit/CMakeFiles/pdal_test.dir/main.cpp.o
Linking CXX executable ../../bin/pdal_test
[100%] Built target pdal_test
Running 151 test cases...
unknown location(0): fatal error in "ScalingFilterFloat_test": std::runtime_error: Dimension data type unable to be scaled because it is Undefined
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/test/unit/ScalingFilterTest.cpp(93)>: last checkpoint
*** 1 failure detected in test suite "Main"
Build step 'Execute shell' marked build as failure
More information about the pdal-commits mailing list
