[pdal-commits] Build failed in Jenkins: PDAL-boost-embed #74
Github noreply at github.com
Wed Mar 14 17:34:47 EDT 2012
See <http://jenkins.pointcloud.org/job/PDAL-boost-embed/74/changes>
Changes:
[hobu.inc] scaffolding for pdal::Metadata
Started by GitHub push by
Building in workspace <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/>
Checkout:workspace / <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/> - hudson.remoting.LocalChannel at 1d0daff6
Using strategy: Default
Last Built Revision: Revision 6b032c15d0c3b0db7ffb1cfa97a7236a300b02fc (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from git://github.com/PDAL/PDAL.git
Commencing build of Revision 0196c1a3097470c9d79a8c5ad2725fe22e7dfa25 (origin/master)
Checking out Revision 0196c1a3097470c9d79a8c5ad2725fe22e7dfa25 (origin/master)
Cleaning workspace
[workspace] $ /bin/sh -xe /tmp/hudson6595666174032571573.sh
+ test/jenkins.sh PDAL-embed-boost
running: cmake -G "Unix Makefiles" -C test/BuildSetup-embed.jenkins .
loading initial cache file test/BuildSetup-embed.jenkins
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Setting PDAL build type - Release
-- Boost version: 1.48.0
-- Using embedded boost tree
-- Searching for GDAL 1.9.0+ library
-- Found GDAL: /var/lib/jenkins/local/lib/libgdal.so (Required is at least version "1.9.0")
-- ...building with GDAL
-- Searching for GeoTIFF 1.2.5+ library
-- Found GeoTIFF version: 1.4.0
-- Found GeoTIFF: /var/lib/jenkins/local/lib/libgeotiff.so (Required is at least version "1.2.5")
-- Found TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so
-- Looking for iconv
-- Looking for iconv - found
-- Found iconv library:
-- Found LibXml2: /usr/lib/libxml2.so
-- Searching for Oracle + OCI client library
-- Found ORACLE: /u01/app/oracle/product/11.2.0/dbhome_1/lib/libclntsh.so;/u01/app/oracle/product/11.2.0/dbhome_1/lib/libocci.so;/u01/app/oracle/product/11.2.0/dbhome_1/lib/libnnz11.so
-- ...building with Oracle
-- Searching for LASzip 1.0.1+ library
-- Found LASzip version: 2.1.0
-- Found LASzip: /var/lib/jenkins/local/lib/liblaszip.so (Required is at least version "1.0.1")
-- Found PythonLibs: /usr/lib/libpython2.7.so
-- Searching for NumPy library
-- Found PythonInterp: /usr/bin/python2.7
-- Found NumPy: 1.5.1
-- Found NumPy at /usr/lib/pymodules/python2.7/numpy/core/include
-- Found Python: /usr/lib/libpython2.7.so
-- Using boost lib: pdalboost
-- Building with PDAL unit tests
-- No non-embed static boost library found, setting BOOST_TEST_DYN_LINK
-- Configuring done
-- Generating done
-- Build files have been written to: <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/>
Scanning dependencies of target pdalboost
[  0%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/date_time/src/gregorian/date_generators.cpp.o
[  1%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/date_time/src/gregorian/greg_month.cpp.o
[  1%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/date_time/src/gregorian/greg_weekday.cpp.o
[  2%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/exception/src/clone_current_exception_non_intrusive.cpp.o
[  2%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v2/src/v2_operations.cpp.o
[  3%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v2/src/v2_path.cpp.o
[  3%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v2/src/v2_portability.cpp.o
[  4%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/codecvt_error_category.cpp.o
[  4%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/operations.cpp.o
[  5%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/path.cpp.o
[  5%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/path_traits.cpp.o
[  6%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/portability.cpp.o
[  7%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/unique_path.cpp.o
[  7%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/utf8_codecvt_facet.cpp.o
[  8%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/filesystem/v3/src/windows_file_codecvt.cpp.o
[  8%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/iostreams/src/file_descriptor.cpp.o
[  9%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/iostreams/src/mapped_file.cpp.o
[  9%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/cmdline.cpp.o
[ 10%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/config_file.cpp.o
[ 10%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/convert.cpp.o
[ 11%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/options_description.cpp.o
[ 11%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/parsers.cpp.o
[ 12%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/positional_options.cpp.o
[ 12%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/split.cpp.o
[ 13%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/utf8_codecvt_facet.cpp.o
[ 14%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/value_semantic.cpp.o
[ 14%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/variables_map.cpp.o
[ 15%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/program_options/src/winmain.cpp.o
[ 15%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/system/src/error_code.cpp.o
[ 16%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/compiler_log_formatter.cpp.o
[ 16%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/cpp_main.cpp.o
[ 17%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/debug.cpp.o
[ 17%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/exception_safety.cpp.o
[ 18%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/execution_monitor.cpp.o
[ 18%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/framework.cpp.o
[ 19%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/interaction_based.cpp.o
[ 19%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/logged_expectations.cpp.o
[ 20%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/plain_report_formatter.cpp.o
[ 21%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/progress_monitor.cpp.o
[ 21%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/results_collector.cpp.o
[ 22%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/results_reporter.cpp.o
[ 22%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/test_main.cpp.o
[ 23%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/test_tools.cpp.o
[ 23%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_log.cpp.o
[ 24%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_main.cpp.o
[ 24%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_monitor.cpp.o
[ 25%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_parameters.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/utils/runtime/env/variable.hpp>:190:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/impl/unit_test_parameters.ipp>:39,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/test/src/unit_test_parameters.cpp>:16:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/utils/runtime/env/environment.hpp>:103:27: warning: redundant redeclaration of ‘pdalboost::runtime::environment::variable_base pdalboost::runtime::environment::var(pdalboost::runtime::cstring)’ in same scope
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/test/utils/runtime/env/fwd.hpp>:32:15: warning: previous declaration of ‘pdalboost::runtime::environment::variable_base pdalboost::runtime::environment::var(pdalboost::runtime::cstring)’
[ 25%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/unit_test_suite.cpp.o
[ 26%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/xml_log_formatter.cpp.o
[ 26%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/test/src/xml_report_formatter.cpp.o
[ 27%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/thread/src/pthread/once.cpp.o
[ 28%] Building CXX object boost/CMakeFiles/pdalboost.dir/libs/thread/src/pthread/thread.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/condition_variable.hpp>:16:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/pthread/shared_mutex.hpp>:13,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/shared_mutex.hpp>:16,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/detail/thread_group.hpp>:9,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/thread.hpp>:24,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/libs/thread/src/pthread/thread.cpp>:10:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/pthread/condition_variable.hpp>:18:51: warning: redundant redeclaration of ‘void pdalboost::this_thread::interruption_point()’ in same scope
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/thread/detail/thread.hpp>:378:32: warning: previous declaration of ‘void pdalboost::this_thread::interruption_point()’
Linking CXX static library ../bin/libpdalboost.a
[ 28%] Built target pdalboost
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/GDALUtils.cpp.o
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/Bounds.cpp.o
[ 30%] Building CXX object src/CMakeFiles/pdal.dir/Dimension.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/uuid/seed_rng.hpp>: In member function ‘void pdalboost::uuids::detail::seed_rng::sha1_random_digest_()’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/uuid/seed_rng.hpp>:152:53: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result
[ 30%] Building CXX object src/CMakeFiles/pdal.dir/FileUtils.cpp.o
[ 31%] Building CXX object src/CMakeFiles/pdal.dir/Filter.cpp.o
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/FilterIterator.cpp.o
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/Log.cpp.o
[ 33%] Building CXX object src/CMakeFiles/pdal.dir/MetadataRecord.cpp.o
[ 33%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilter.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilterIterator.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/Options.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/PipelineManager.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/PipelineReader.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/PipelineWriter.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/PointBuffer.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/../include/pdal/PointBuffer.hpp>:40:0,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/PointBuffer.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/lexical_cast.hpp>: In member function ‘bool pdalboost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::shl_double(double, T*) [with T = char, CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/lexical_cast.hpp>:1298:86:   instantiated from ‘bool pdalboost::detail::lexical_stream_limited_src<CharT, Traits, RequiresStringbuffer>::operator<<(double) [with CharT = char, Traits = std::char_traits<char>, bool RequiresStringbuffer = false]’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/lexical_cast.hpp>:1748:17:   instantiated from ‘static Target pdalboost::detail::lexical_cast_do_cast<Target, Source>::lexical_cast_impl(const Source&) [with Target = std::basic_string<char>, Source = double]’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/lexical_cast.hpp>:1915:50:   instantiated from ‘Target pdalboost::lexical_cast(const Source&) [with Target = std::basic_string<char>, Source = double]’
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/PointBuffer.cpp>:289:35:   instantiated from here
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/boost/boost/lexical_cast.hpp>:1183:17: warning: ISO C++ does not support the ‘%lg’ gnu_printf format
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/Range.cpp.o
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/Reader.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/ReaderIterator.cpp.o
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/Schema.cpp.o
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/SpatialReference.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_srs_api.h:34:0,
                 from /var/lib/jenkins/local/include/ogr_spatialref.h:34,
                 from <http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/SpatialReference.cpp>:45:
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:58:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope3D::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:155:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:94: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/Stage.cpp.o
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/Stage.cpp>: In member function ‘virtual std::vector<pdal::Metadata> pdal::Stage::getMetadata() const’:
<http://jenkins.pointcloud.org/job/PDAL-boost-embed/ws/src/Stage.cpp>:149:48: error: no matching function for call to ‘ignore_unused_variable_warning(<unresolved overloaded function type>)’
make[2]: *** [src/CMakeFiles/pdal.dir/Stage.cpp.o] Error 1
make[1]: *** [src/CMakeFiles/pdal.dir/all] Error 2
make: *** [all] Error 2
test/jenkins.sh: line 16: ./bin/pdal_test: No such file or directory
Build step 'Execute shell' marked build as failure
More information about the pdal-commits mailing list
