[pdal-commits] [PDAL/PDAL] d4d913: Merge branch 'master' of github.com:PDAL/PDAL
GitHub noreply at github.com
Wed Mar 21 14:02:18 EDT 2012
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: d4d9132cb79f58154975b4556a970a0aef517d29
      https://github.com/PDAL/PDAL/commit/d4d9132cb79f58154975b4556a970a0aef517d29
  Author: Michael P. Gerlek <mpg at flaxen.com>
  Date:   2012-03-21 (Wed, 21 Mar 2012)
  Changed paths:
    M doc/api/cpp/dimension.txt
  M doc/api/cpp/index.txt
  A doc/api/cpp/option.txt
  A doc/api/cpp/options.txt
  M include/pdal/Dimension.hpp
  M include/pdal/Options.hpp
  M include/pdal/Schema.hpp
  M src/Dimension.cpp
  M src/Options.cpp
  M src/Schema.cpp
  Log Message:
  Commit: 0fe2cd9cec699fac7e522e51c19bd00ff016f9cd
      https://github.com/PDAL/PDAL/commit/0fe2cd9cec699fac7e522e51c19bd00ff016f9cd
  Changed paths:
    M LICENSE.txt
  Log Message:
  updated
  Commit: 94533e733d0e0cba22d2e50f132af33ea67add68
      https://github.com/PDAL/PDAL/commit/94533e733d0e0cba22d2e50f132af33ea67add68
  Changed paths:
    A include/pdal/Environment.hpp
  M include/pdal/plang/Environment.hpp
  M include/pdal/plang/Invocation.hpp
  M src/CMakeLists.txt
  A src/Environment.cpp
  M src/plang/Environment.cpp
  M src/plang/Invocation.cpp
  M test/unit/CMakeLists.txt
  A test/unit/EnvironmentTest.cpp
  M test/unit/main.cpp
  Log Message:
  added global environment class for startup/shutdown; could eventually be a 'register' mechanism, though
  Commit: 5e0d415f870538223aeef941c261f6fb744faf94
      https://github.com/PDAL/PDAL/commit/5e0d415f870538223aeef941c261f6fb744faf94
  Changed paths:
    M apps/pcinfo.cpp
  M apps/pcpipeline.cpp
  Log Message:
  untabify
  Commit: 7ace187c0915cffac0b9b7ece1688be3b58d247d
      https://github.com/PDAL/PDAL/commit/7ace187c0915cffac0b9b7ece1688be3b58d247d
  Changed paths:
    M apps/Application.cpp
  M apps/Application.hpp
  Log Message:
  added global startup/shutdown; refactored to improve status checking
Compare: https://github.com/PDAL/PDAL/compare/01e96b8...7ace187
More information about the pdal-commits mailing list
