[pdal-commits] [PDAL/PDAL] b37cee: add missing initializers
GitHub noreply at github.com
Thu May 10 14:00:07 EDT 2012
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: b37ceeb1a065c63baad19b0975c846fd8893184c
      https://github.com/PDAL/PDAL/commit/b37ceeb1a065c63baad19b0975c846fd8893184c
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2012-05-10 (Thu, 10 May 2012)
  Changed paths:
    M src/plang/Redirector.cpp
  Log Message:
  Commit: 04cb7b05df0b7eae4c5505fa7342c20ed1e8cc0e
      https://github.com/PDAL/PDAL/commit/04cb7b05df0b7eae4c5505fa7342c20ed1e8cc0e
  Changed paths:
    M boost/boost/bimap/bimap.hpp
    M boost/boost/bimap/detail/map_view_base.hpp
    M boost/boost/bimap/detail/map_view_iterator.hpp
    M boost/boost/bimap/detail/set_view_iterator.hpp
    M boost/boost/bimap/relation/mutant_relation.hpp
    M boost/boost/bimap/views/unconstrained_map_view.hpp
    M boost/boost/bimap/views/unconstrained_set_view.hpp
    M boost/boost/fusion/algorithm/query/detail/any.hpp
    M boost/boost/fusion/sequence/intrinsic/has_key.hpp
    M boost/boost/optional/optional.hpp
    M boost/boost/parameter/aux_/tagged_argument.hpp
    M boost/boost/property_tree/detail/json_parser_read.hpp
    M boost/boost/spirit/home/classic/core/composite/no_actions.hpp
    M boost/boost/spirit/home/classic/core/non_terminal/impl/grammar.ipp
    M boost/boost/spirit/home/classic/meta/impl/refactoring.ipp
    M boost/boost/spirit/home/classic/phoenix/tuples.hpp
    M boost/boost/spirit/home/classic/utility/impl/chset.ipp
    M boost/boost/spirit/home/phoenix/object/construct.hpp
    M boost/boost/test/floating_point_comparison.hpp
    M boost/boost/test/utils/iterator/token_iterator.hpp
    M boost/boost/test/utils/named_params.hpp
    M boost/boost/token_functions.hpp
    M boost/libs/filesystem/v3/src/operations.cpp
  Log Message:
  silence unused warnings
  Commit: f2d80096a11c1e54fe714e58c235e823e2fa79af
      https://github.com/PDAL/PDAL/commit/f2d80096a11c1e54fe714e58c235e823e2fa79af
  Changed paths:
    M include/pdal/drivers/oci/oci_wrapper.h
    M src/drivers/oci/oci_wrapper.cpp
  Log Message:
  clean up const warning
  Commit: 2ac39664a097fa59602aec3d380067d3a5840923
      https://github.com/PDAL/PDAL/commit/2ac39664a097fa59602aec3d380067d3a5840923
  Changed paths:
    M hobu-config.sh
  Log Message:
  default to clang for me
  Commit: 15cccee5f05507b5ab2d560bad725efd64c22079
      https://github.com/PDAL/PDAL/commit/15cccee5f05507b5ab2d560bad725efd64c22079
  Changed paths:
    M include/pdal/drivers/las/Reader.hpp
    M src/drivers/las/Reader.cpp
  Log Message:
  rename collectMetadata to not clash with StageBase::collectMetadata
  Commit: 376caa90c14917b15d8df1f3521971bccca76cdf
      https://github.com/PDAL/PDAL/commit/376caa90c14917b15d8df1f3521971bccca76cdf
  Changed paths:
    M src/Writer.cpp
  Log Message:
  increase default chunk size to 2^20 instead of 2^15
  Commit: 1120a3b824cb59f536afd1ea45fa7c38196ee486
      https://github.com/PDAL/PDAL/commit/1120a3b824cb59f536afd1ea45fa7c38196ee486
  Changed paths:
  Log Message:
  make sure to read the metadata
Compare: https://github.com/PDAL/PDAL/compare/8dc6332...1120a3b
More information about the pdal-commits mailing list
