[pdal-commits] [PDAL/PDAL] 843319: Merge branch 'master', remote-tracking branch 'ori...
GitHub noreply at github.com
Tue May 15 15:38:25 EDT 2012
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 843319231849ece7f9b4dcba006a8e67daed3eac
      https://github.com/PDAL/PDAL/commit/843319231849ece7f9b4dcba006a8e67daed3eac
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2012-05-11 (Fri, 11 May 2012)
  Log Message:
  Merge branch 'master', remote-tracking branch 'origin/master'
  Commit: 6e8cf5c61cd29a04bc59c09a2995cd5245833aca
      https://github.com/PDAL/PDAL/commit/6e8cf5c61cd29a04bc59c09a2995cd5245833aca
  Date:   2012-05-15 (Tue, 15 May 2012)
  Changed paths:
    M CMakeLists.txt
    M apps/pcinfo.cpp
    M boost/boost/bimap/bimap.hpp
    M boost/boost/bimap/detail/map_view_base.hpp
    M boost/boost/bimap/detail/map_view_iterator.hpp
    M boost/boost/bimap/detail/set_view_iterator.hpp
    M boost/boost/bimap/relation/mutant_relation.hpp
    M boost/boost/bimap/views/unconstrained_map_view.hpp
    M boost/boost/bimap/views/unconstrained_set_view.hpp
    M boost/boost/fusion/algorithm/query/detail/any.hpp
    M boost/boost/fusion/sequence/intrinsic/has_key.hpp
    M boost/boost/optional/optional.hpp
    M boost/boost/parameter/aux_/tagged_argument.hpp
    M boost/boost/property_tree/detail/json_parser_read.hpp
    M boost/boost/spirit/home/classic/core/composite/no_actions.hpp
    M boost/boost/spirit/home/classic/core/non_terminal/impl/grammar.ipp
    M boost/boost/spirit/home/classic/meta/impl/refactoring.ipp
    M boost/boost/spirit/home/classic/phoenix/tuples.hpp
    M boost/boost/spirit/home/classic/utility/impl/chset.ipp
    M boost/boost/spirit/home/phoenix/object/construct.hpp
    M boost/boost/test/floating_point_comparison.hpp
    M boost/boost/test/utils/iterator/token_iterator.hpp
    M boost/boost/test/utils/named_params.hpp
    M boost/boost/token_functions.hpp
    M boost/libs/filesystem/v3/src/operations.cpp
    M config.bat
    M include/pdal/Dimension.hpp
    M include/pdal/GlobalEnvironment.hpp
    M include/pdal/Metadata.hpp
    M include/pdal/ThreadEnvironment.hpp
    M include/pdal/drivers/las/Header.hpp
    M include/pdal/drivers/las/VariableLengthRecord.hpp
    M include/pdal/drivers/las/Writer.hpp
    M include/pdal/filters/Stats.hpp
    M include/pdal/plang/PythonEnvironment.hpp
    M src/Dimension.cpp
    M src/GlobalEnvironment.cpp
    M src/Metadata.cpp
    M src/ThreadEnvironment.cpp
    M src/drivers/las/Header.cpp
    M src/drivers/las/VariableLengthRecord.cpp
    M src/drivers/las/Writer.cpp
    M src/drivers/las/ZipPoint.cpp
    M src/filters/Predicate.cpp
    M src/filters/Programmable.cpp
    M src/filters/Stats.cpp
    M src/plang/Invocation.cpp
    M test/data/apps/pcinfo_stats.txt
    M test/unit/EnvironmentTest.cpp
    M test/unit/MetadataTest.cpp
  Log Message:
  Commit: fde6515b8e2fb70b375c7b41ac139d2133c3fe47
      https://github.com/PDAL/PDAL/commit/fde6515b8e2fb70b375c7b41ac139d2133c3fe47
  Changed paths:
  Log Message:
  python_env did not exist for those of us compiling without python
Compare: https://github.com/PDAL/PDAL/compare/c455aa1...fde6515
More information about the pdal-commits mailing list
