[pdal-commits] [PDAL/PDAL] 25e7d7: use Metadata instead of Entry for XML sub-elements
GitHub noreply at github.com
Thu May 31 12:34:47 PDT 2012
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 25e7d72b57c86992317db6c8f961b178d9b1775b
      https://github.com/PDAL/PDAL/commit/25e7d72b57c86992317db6c8f961b178d9b1775b
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2012-05-31 (Thu, 31 May 2012)
  Changed paths:
    M src/PipelineWriter.cpp
  Log Message:
  Commit: 8c5d7803f5fa6995692ba326855eace640ada0f3
      https://github.com/PDAL/PDAL/commit/8c5d7803f5fa6995692ba326855eace640ada0f3
  Changed paths:
    M src/drivers/las/Reader.cpp
  Log Message:
  add metadata descriptions from the LAS specification
  Commit: 0b8cfef90c287afcb9a3244429b6d48e644cdf07
      https://github.com/PDAL/PDAL/commit/0b8cfef90c287afcb9a3244429b6d48e644cdf07
  Changed paths:
    M doc/metadata.txt
  Log Message:
  metadata docs
  Commit: df1929cd2c766322cb6352173b75d6905669ee57
      https://github.com/PDAL/PDAL/commit/df1929cd2c766322cb6352173b75d6905669ee57
  Changed paths:
    M test/data/pipeline/pipeline_metadata.xml
    M test/unit/MetadataTest.cpp
  Log Message:
  update metadata tests to use interesting.las which has more vlrs and header values set
Compare: https://github.com/PDAL/PDAL/compare/69e663e...df1929c
More information about the pdal-commits mailing list
