[pdal-commits] [PDAL/PDAL] 3d7d1e: add setMetadata method, which overwrites an existi...
GitHub noreply at github.com
Wed Oct 17 09:55:08 PDT 2012
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 3d7d1e827131687a40884ea491dda359051613f6
      https://github.com/PDAL/PDAL/commit/3d7d1e827131687a40884ea491dda359051613f6
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2012-10-17 (Wed, 17 Oct 2012)
  Changed paths:
    M include/pdal/Metadata.hpp
  Log Message:
  add setMetadata method, which overwrites an existing one with the same properties using deleteMetadata and addMetadata
  Commit: 78ce8289fdbf8f2fa7843f58f3ff989d3c1b0dfb
      https://github.com/PDAL/PDAL/commit/78ce8289fdbf8f2fa7843f58f3ff989d3c1b0dfb
  Changed paths:
    M include/pdal/Writer.hpp
    M src/Writer.cpp
  Log Message:
  make the PointBuffer that the pdal::Writer uses heap-allocated and owned by the pdal::Writer instance. Add a public method to fetch it so that others may get the properties of the writer's PointBuffer
  Commit: ecbd306130288415edd48d22fb24da7a952a8385
      https://github.com/PDAL/PDAL/commit/ecbd306130288415edd48d22fb24da7a952a8385
  Changed paths:
    M include/pdal/PipelineWriter.hpp
    M src/PipelineWriter.cpp
  Log Message:
  support writing information from a PointBuffer (like pdal::Metadata) into the PipelineXML
  Commit: 1a281021539deda011433cc3fe0655329787c5d2
      https://github.com/PDAL/PDAL/commit/1a281021539deda011433cc3fe0655329787c5d2
  Changed paths:
    M include/pdal/filters/Stats.hpp
    M src/filters/Stats.cpp
  Log Message:
  toMetadata() method, to support making pdal::Metadata instances out of stats
  Commit: 5b2c9a56fe36b2f98dba0e0746eeb0b3ac83be01
      https://github.com/PDAL/PDAL/commit/5b2c9a56fe36b2f98dba0e0746eeb0b3ac83be01
  Changed paths:
    M test/data/apps/pcinfo_stats.txt
  Log Message:
  update with new output
  Commit: 96d0eb260088b6e1f53454c8c1ecda7216b50f1c
      https://github.com/PDAL/PDAL/commit/96d0eb260088b6e1f53454c8c1ecda7216b50f1c
  Changed paths:
    M apps/pcpipeline.cpp
  Log Message:
  support writing PointBuffer Metadata for pipeline-serialization
  Commit: 1dfbc54d286d65abb4107d0f7632712e67fd41b7
      https://github.com/PDAL/PDAL/commit/1dfbc54d286d65abb4107d0f7632712e67fd41b7
  Changed paths:
    M apps/pcinfo.cpp
  Log Message:
  write JSON Metadata instead of custom format for stas
Compare: https://github.com/PDAL/PDAL/compare/b800e26e0e85...1dfbc54d286d
More information about the pdal-commits mailing list
