[pdal-commits] [PDAL/PDAL] d049be: oracle cleanup script tweak
GitHub noreply at github.com
Tue Aug 27 07:07:48 PDT 2013
  Branch: refs/heads/issues/124-p2g-intensity-interpolate
  Home:   https://github.com/PDAL/PDAL
  Commit: d049bee0b726cc123c7f2a72fcaf455c079a77af
      https://github.com/PDAL/PDAL/commit/d049bee0b726cc123c7f2a72fcaf455c079a77af
  Author: Howard Butler <howard at hobu.co>
  Date:   2013-07-25 (Thu, 25 Jul 2013)
  Changed paths:
    M test/data/oracle/cleanup.sql
  Log Message:
  Commit: 418d265566a293898f357bab52405f8d7d4cec21
      https://github.com/PDAL/PDAL/commit/418d265566a293898f357bab52405f8d7d4cec21
  Author: Howard Butler <hobu.inc at gmail.com>
  Changed paths:
    M src/filters/Cache.cpp
  Log Message:
  #ifdef the log output for filters.cache. This ends up being touched per-point and is expensive if you don't want it
  Commit: ef6991a01ae8ec8dd76ad13ac214db81ee11300b
      https://github.com/PDAL/PDAL/commit/ef6991a01ae8ec8dd76ad13ac214db81ee11300b
  Changed paths:
    M src/drivers/oci/Writer.cpp
  Log Message:
  use PointBuffer::calculateBounds instead of driver's version
  Commit: 2addad9a8a4deea98e3e94d92ce7e3f283103869
      https://github.com/PDAL/PDAL/commit/2addad9a8a4deea98e3e94d92ce7e3f283103869
  Changed paths:
    M src/PointBuffer.cpp
  Log Message:
  don't allocate a vector for every point added to the loop in calculateBounds
  Commit: e5aca6f297fcbc197e9cca9c3d555eca9887d229
      https://github.com/PDAL/PDAL/commit/e5aca6f297fcbc197e9cca9c3d555eca9887d229
  Date:   2013-07-27 (Sat, 27 Jul 2013)
  Changed paths:
    M include/pdal/drivers/oci/oci_wrapper.h
    M src/drivers/oci/oci_wrapper.cpp
  Log Message:
  add OpenBlob/CloseBlob methods
  Commit: a62ccd8734f84371d7a5b60059cfcda3fd271bbb
      https://github.com/PDAL/PDAL/commit/a62ccd8734f84371d7a5b60059cfcda3fd271bbb
  Changed paths:
    M src/drivers/oci/Reader.cpp
  Log Message:
  use OpenBlob/CloseBlob methods to reduce round-tripping to db
  Commit: 9dc8558bc59752fd7893afe188133697ef434a49
      https://github.com/PDAL/PDAL/commit/9dc8558bc59752fd7893afe188133697ef434a49
  Changed paths:
  Log Message:
  clean up binds
  Commit: 71808f12c77c482ebf3160c89faa4735102c48bc
      https://github.com/PDAL/PDAL/commit/71808f12c77c482ebf3160c89faa4735102c48bc
  Changed paths:
    M include/pdal/drivers/oci/Reader.hpp
    M include/pdal/drivers/oci/common.hpp
    M src/drivers/oci/common.cpp
  Log Message:
  revert to only supporting selecting the view and drop support for QUERY_SDO_PC query types
  Commit: 9f6fb527dc3808e79835a1155ff45516dc5e6f66
      https://github.com/PDAL/PDAL/commit/9f6fb527dc3808e79835a1155ff45516dc5e6f66
  Date:   2013-07-29 (Mon, 29 Jul 2013)
  Changed paths:
    M include/pdal/drivers/oci/Writer.hpp
  Log Message:
  add ability to control whether or not to create indices with 'create_index' option, allow user to turn on tracing with 'do_trace' option
  Commit: 120197bffdbb1113bd4fec38573bcbd99e27f08a
      https://github.com/PDAL/PDAL/commit/120197bffdbb1113bd4fec38573bcbd99e27f08a
  Changed paths:
  Log Message:
  write using OCILocator instead of data bind
  Commit: ea84a207703349e93d78fb7183b2fb5679901a4d
      https://github.com/PDAL/PDAL/commit/ea84a207703349e93d78fb7183b2fb5679901a4d
  Changed paths:
  Log Message:
  clean up lint
  Commit: dfb4febed1adda28cf2ba0ea08ca7ffbba4ced9c
      https://github.com/PDAL/PDAL/commit/dfb4febed1adda28cf2ba0ea08ca7ffbba4ced9c
  Changed paths:
  Log Message:
  start callback-based streaming method -- not yet implemented
  Commit: 8f8d08cec27dd656bf50935524fb982fd853a38e
      https://github.com/PDAL/PDAL/commit/8f8d08cec27dd656bf50935524fb982fd853a38e
  Date:   2013-07-30 (Tue, 30 Jul 2013)
  Changed paths:
    M apps/CMakeLists.txt
    A apps/oracle_array.cpp
  Log Message:
  add oracle_array test util
  Commit: 07e091b7b05d00138fd8ff16ecb9358f5aa52a93
      https://github.com/PDAL/PDAL/commit/07e091b7b05d00138fd8ff16ecb9358f5aa52a93
  Changed paths:
  Log Message:
  put back writing to ONE_PIECE method
  Commit: 7a2b43f892870b4e29c46681fac980483bb0e8ac
      https://github.com/PDAL/PDAL/commit/7a2b43f892870b4e29c46681fac980483bb0e8ac
  Date:   2013-07-31 (Wed, 31 Jul 2013)
  Changed paths:
    M apps/oracle_array.cpp
  Log Message:
  include stdlib.h for exit()
  Commit: 31b9444baac484eaabf71159e30fafff148240f8
      https://github.com/PDAL/PDAL/commit/31b9444baac484eaabf71159e30fafff148240f8
  Changed paths:
  Log Message:
  try streaming-based LOB writing
  Commit: 8f8a22a3d3416ba9fbf09206f354eaf5670f7b88
      https://github.com/PDAL/PDAL/commit/8f8a22a3d3416ba9fbf09206f354eaf5670f7b88
  Author: Chris Foster <chris.foster at roames.com.au>
  Changed paths:
    M CMakeLists.txt
    M boost/CMakeLists.txt
    M src/CMakeLists.txt
  Log Message:
  Build system option for static PDAL build
  Commit: 8f77618d2ffcdc60a4e76e610d6ac90683f83278
      https://github.com/PDAL/PDAL/commit/8f77618d2ffcdc60a4e76e610d6ac90683f83278
  Author: Chris Foster <chris42f at gmail.com>
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #168 from c42f/pdal-static-build
  Commit: 82a9e83a7337d55d6a56106cdc0ea34533da903f
      https://github.com/PDAL/PDAL/commit/82a9e83a7337d55d6a56106cdc0ea34533da903f
  Date:   2013-08-01 (Thu, 01 Aug 2013)
  Changed paths:
  Log Message:
  support chunk-based stream writing
  Commit: 747dbc1ce27615bfb6c00450df212ee06f66b4cf
      https://github.com/PDAL/PDAL/commit/747dbc1ce27615bfb6c00450df212ee06f66b4cf
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge branch 'master' into issues/167-fixups-for-chipper
  Commit: ae2446a1f12b962c22aa528ed25e00a28ac55cff
      https://github.com/PDAL/PDAL/commit/ae2446a1f12b962c22aa528ed25e00a28ac55cff
  Changed paths:
  Log Message:
  add blob_chunk_count option to drivers.oci.writer
  Commit: 0ac290ef9527a76096f18ba2f2b7c95ee0e0f502
      https://github.com/PDAL/PDAL/commit/0ac290ef9527a76096f18ba2f2b7c95ee0e0f502
  Date:   2013-08-05 (Mon, 05 Aug 2013)
  Changed paths:
  Log Message:
  switch off gzip/zlib iostreams for now -- we're not using it
  Commit: b8d7a23cefd4128cec57be40dab1d726d8ef0164
      https://github.com/PDAL/PDAL/commit/b8d7a23cefd4128cec57be40dab1d726d8ef0164
  Changed paths:
    M test/perf/CMakeLists.txt
  Log Message:
  don't do perf tests on windows, some includes not available yet it seems
  Commit: 1f27326e8fd430639b1719e727eb76fe8b365f7c
      https://github.com/PDAL/PDAL/commit/1f27326e8fd430639b1719e727eb76fe8b365f7c
  Changed paths:
    M hobu-windows.bat
  Log Message:
  use PGPOINTCLOUD=ON in my default configuration (based on OSGeo4W
  Commit: 94065459cbcb631e51101dd616145ab9d9d24b59
      https://github.com/PDAL/PDAL/commit/94065459cbcb631e51101dd616145ab9d9d24b59
  Changed paths:
    M include/pdal/drivers/pgpointcloud/common.hpp
  Log Message:
  don't do conninfo parse if we don't have it (old libpq's). Fixes #169
  Commit: 507f24b27b13bc39a802c4620f5dceb6ce85f597
      https://github.com/PDAL/PDAL/commit/507f24b27b13bc39a802c4620f5dceb6ce85f597
  Changed paths:
    M hobu-windows.bat
  Log Message:
  Commit: 0b7c1bc8b285ef55520a8c874fbe2635e381484e
      https://github.com/PDAL/PDAL/commit/0b7c1bc8b285ef55520a8c874fbe2635e381484e
  Date:   2013-08-07 (Wed, 07 Aug 2013)
  Changed paths:
    R apps/oracle_array.cpp
    A test/unit/drivers/oci/oracle_array.cpp
  Log Message:
  move oracle_array example into test/unit/drivers/oci for safe (unused) keeping
  Commit: ba38425d753c02a9e8675f08436da6a4fb82f0e4
      https://github.com/PDAL/PDAL/commit/ba38425d753c02a9e8675f08436da6a4fb82f0e4
  Changed paths:
  Log Message:
  remove cruft
  Commit: 413f657d7731967e69fb63a156f8d69f0f046bd0
      https://github.com/PDAL/PDAL/commit/413f657d7731967e69fb63a156f8d69f0f046bd0
  Changed paths:
  Log Message:
  optionally support chunk streaming -- inconclusive whether or not it is actually faster
  Commit: 10084959220f47b726ed697bf327134b8faf34da
      https://github.com/PDAL/PDAL/commit/10084959220f47b726ed697bf327134b8faf34da
  Date:   2013-08-09 (Fri, 09 Aug 2013)
  Changed paths:
  Log Message:
  cumulate the entire bounds as we go through for the whole SDO_PC
  Commit: 2d2cebc640e634bcbdfef47a0fa30bcf1aab5133
      https://github.com/PDAL/PDAL/commit/2d2cebc640e634bcbdfef47a0fa30bcf1aab5133
  Changed paths:
  Log Message:
  don't pollute stdout
  Commit: f7183a730af65c5b8ed523bb6271cd5d1d7158b2
      https://github.com/PDAL/PDAL/commit/f7183a730af65c5b8ed523bb6271cd5d1d7158b2
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Date:   2013-08-20 (Tue, 20 Aug 2013)
  Changed paths:
    M src/Dimension.cpp
    M src/FileUtils.cpp
    M src/Filter.cpp
    M src/FilterIterator.cpp
    M src/GDALUtils.cpp
    M src/GlobalEnvironment.cpp
    M src/Metadata.cpp
    M src/MultiFilter.cpp
    M src/Options.cpp
    M src/PipelineManager.cpp
    M src/PipelineWriter.cpp
    M src/Reader.cpp
    M src/Schema.cpp
    M src/SpatialReference.cpp
    M src/Stage.cpp
    M src/StageBase.cpp
    M src/StageFactory.cpp
    M src/StageInfo.cpp
    M src/StageIterator.cpp
    M src/StreamFactory.cpp
    M src/ThreadEnvironment.cpp
    M src/Utils.cpp
    M src/Writer.cpp
    M src/XMLSchema.cpp
    M src/drivers/buffer/Reader.cpp
    M src/drivers/caris/CloudIterator.cpp
    M src/drivers/caris/CloudReader.cpp
    M src/drivers/caris/Utils.cpp
    M src/drivers/caris/pdal_csar.cpp
    M src/drivers/faux/Reader.cpp
    M src/drivers/las/Header.cpp
    M src/drivers/las/Reader.cpp
    M src/drivers/las/Support.cpp
    M src/drivers/las/VariableLengthRecord.cpp
    M src/drivers/las/Writer.cpp
    M src/drivers/las/ZipPoint.cpp
    M src/drivers/mrsid/Reader.cpp
    M src/drivers/nitf/NitfFile.cpp
    M src/drivers/nitf/Writer.cpp
    M src/drivers/pgpointcloud/Reader.cpp
    M src/drivers/pgpointcloud/Writer.cpp
    M src/drivers/qfit/Reader.cpp
    M src/drivers/soci/Reader.cpp
    M src/drivers/soci/Writer.cpp
    M src/drivers/terrasolid/Reader.cpp
    M src/drivers/text/Writer.cpp
    M src/filters/Chipper.cpp
    M src/filters/Color.cpp
    M src/filters/Colorization.cpp
    M src/filters/Crop.cpp
    M src/filters/Decimation.cpp
    M src/filters/HexBin.cpp
    M src/filters/InPlaceReprojection.cpp
    M src/filters/Index.cpp
    M src/filters/Predicate.cpp
    M src/filters/Programmable.cpp
    M src/filters/Scaling.cpp
    M src/filters/Selector.cpp
    M src/filters/Stats.cpp
    M src/pdal_config.cpp
    M src/plang/Invocation.cpp
    M src/plang/PythonEnvironment.cpp
    M src/plang/Redirector.cpp
  Log Message:
  Run astyle on src/ and include/ files
  Commit: c4cd590be0cc25bb87f50edda4bca4ecea6b5e89
      https://github.com/PDAL/PDAL/commit/c4cd590be0cc25bb87f50edda4bca4ecea6b5e89
  Date:   2013-08-21 (Wed, 21 Aug 2013)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Update required boost version to 1.53
Update root CMakeLists to require boost 1.53, which is now required as
discussed in #170.
  Commit: 5dbf8fd1014957232172ab153680515c5a00bcd0
      https://github.com/PDAL/PDAL/commit/5dbf8fd1014957232172ab153680515c5a00bcd0
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #172 from gadomski/update-boost-version
  Commit: 075f5ed793c6ec0fbc0e6330ac17c5c87c865747
      https://github.com/PDAL/PDAL/commit/075f5ed793c6ec0fbc0e6330ac17c5c87c865747
  Changed paths:
    M src/Dimension.cpp
    M src/FileUtils.cpp
    M src/Filter.cpp
    M src/GDALUtils.cpp
    M src/Metadata.cpp
    M src/Options.cpp
    M src/Reader.cpp
    M src/Schema.cpp
    M src/Stage.cpp
    M src/StageBase.cpp
    M src/StageInfo.cpp
    M src/Utils.cpp
    M src/Writer.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge pull request #171 from gadomski/astyle
  Commit: b0b04614124422173e3a7b2f495c85958ddfd3a8
      https://github.com/PDAL/PDAL/commit/b0b04614124422173e3a7b2f495c85958ddfd3a8
  Date:   2013-08-22 (Thu, 22 Aug 2013)
  Changed paths:
    M include/pdal/filters/HexBin.hpp
  Log Message:
  put hex generation in destructor of iterator -- it has to happen after we've read all the points, and then it will update the metadata of the PointBuffer that was used to instantiate the interator
  Commit: b5d24b2ac4c864877024947fa8629862abc3ff73
      https://github.com/PDAL/PDAL/commit/b5d24b2ac4c864877024947fa8629862abc3ff73
  Changed paths:
    M CMakeLists.txt
    M src/Dimension.cpp
    M src/FileUtils.cpp
    M src/Filter.cpp
    M src/GDALUtils.cpp
    M src/Metadata.cpp
    M src/Options.cpp
    M src/Reader.cpp
    M src/Schema.cpp
    M src/Stage.cpp
    M src/StageBase.cpp
    M src/StageInfo.cpp
    M src/Utils.cpp
    M src/Writer.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
Conflicts:
  Commit: de0b6a7c3a80c9f513a9261e4d101aa7c5c136de
      https://github.com/PDAL/PDAL/commit/de0b6a7c3a80c9f513a9261e4d101aa7c5c136de
  Changed paths:
  Log Message:
  fix up bad merge
  Commit: 25c6b4e7126ee1a0048537d953cdf5fba2bfc633
      https://github.com/PDAL/PDAL/commit/25c6b4e7126ee1a0048537d953cdf5fba2bfc633
  Date:   2013-08-27 (Tue, 27 Aug 2013)
  Changed paths:
    M CMakeLists.txt
    M hobu-windows.bat
    M src/Dimension.cpp
    M src/FileUtils.cpp
    M src/Filter.cpp
    M src/GDALUtils.cpp
    M src/Metadata.cpp
    M src/Options.cpp
    M src/Reader.cpp
    M src/Schema.cpp
    M src/Stage.cpp
    M src/StageBase.cpp
    M src/StageInfo.cpp
    M src/Utils.cpp
    M src/Writer.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge branch 'master' into issues/124-p2g-intensity-interpolate
Compare: https://github.com/PDAL/PDAL/compare/c1b99ee4eb0f...25c6b4e7126e
More information about the pdal-commits mailing list
