[pdal-commits] [PDAL/PDAL] c1b99e: allow specifying the 'Z' dimension name with an op...
GitHub noreply at github.com
Tue Aug 27 07:32:50 PDT 2013
  Branch: refs/heads/issues/167-fixups-for-chipper
  Home:   https://github.com/PDAL/PDAL
  Commit: c1b99ee4eb0fe5d78f9f6c600e545a1c2ae620b4
      https://github.com/PDAL/PDAL/commit/c1b99ee4eb0fe5d78f9f6c600e545a1c2ae620b4
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2013-07-25 (Thu, 25 Jul 2013)
  Changed paths:
    M src/drivers/p2g/Writer.cpp
  Log Message:
  allow specifying the 'Z' dimension name with an option for interpolation #124
  Commit: f7183a730af65c5b8ed523bb6271cd5d1d7158b2
      https://github.com/PDAL/PDAL/commit/f7183a730af65c5b8ed523bb6271cd5d1d7158b2
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Date:   2013-08-20 (Tue, 20 Aug 2013)
  Changed paths:
    M src/Dimension.cpp
    M src/FileUtils.cpp
    M src/Filter.cpp
    M src/FilterIterator.cpp
    M src/GDALUtils.cpp
    M src/GlobalEnvironment.cpp
    M src/Metadata.cpp
    M src/MultiFilter.cpp
    M src/Options.cpp
    M src/PipelineManager.cpp
    M src/PipelineWriter.cpp
    M src/PointBuffer.cpp
    M src/Reader.cpp
    M src/Schema.cpp
    M src/SpatialReference.cpp
    M src/Stage.cpp
    M src/StageBase.cpp
    M src/StageFactory.cpp
    M src/StageInfo.cpp
    M src/StageIterator.cpp
    M src/StreamFactory.cpp
    M src/ThreadEnvironment.cpp
    M src/Utils.cpp
    M src/Writer.cpp
    M src/XMLSchema.cpp
    M src/drivers/buffer/Reader.cpp
    M src/drivers/caris/CloudIterator.cpp
    M src/drivers/caris/CloudReader.cpp
    M src/drivers/caris/Utils.cpp
    M src/drivers/caris/pdal_csar.cpp
    M src/drivers/faux/Reader.cpp
    M src/drivers/las/Header.cpp
    M src/drivers/las/Reader.cpp
    M src/drivers/las/Support.cpp
    M src/drivers/las/VariableLengthRecord.cpp
    M src/drivers/las/Writer.cpp
    M src/drivers/las/ZipPoint.cpp
    M src/drivers/mrsid/Reader.cpp
    M src/drivers/nitf/NitfFile.cpp
    M src/drivers/nitf/Writer.cpp
    M src/drivers/oci/Reader.cpp
    M src/drivers/oci/Writer.cpp
    M src/drivers/oci/oci_wrapper.cpp
    M src/drivers/pgpointcloud/Reader.cpp
    M src/drivers/pgpointcloud/Writer.cpp
    M src/drivers/qfit/Reader.cpp
    M src/drivers/soci/Reader.cpp
    M src/drivers/soci/Writer.cpp
    M src/drivers/terrasolid/Reader.cpp
    M src/drivers/text/Writer.cpp
    M src/filters/Cache.cpp
    M src/filters/Chipper.cpp
    M src/filters/Color.cpp
    M src/filters/Colorization.cpp
    M src/filters/Crop.cpp
    M src/filters/Decimation.cpp
    M src/filters/HexBin.cpp
    M src/filters/InPlaceReprojection.cpp
    M src/filters/Index.cpp
    M src/filters/Predicate.cpp
    M src/filters/Programmable.cpp
    M src/filters/Scaling.cpp
    M src/filters/Selector.cpp
    M src/filters/Stats.cpp
    M src/pdal_config.cpp
    M src/plang/Invocation.cpp
    M src/plang/PythonEnvironment.cpp
    M src/plang/Redirector.cpp
  Log Message:
  Run astyle on src/ and include/ files
  Commit: c4cd590be0cc25bb87f50edda4bca4ecea6b5e89
      https://github.com/PDAL/PDAL/commit/c4cd590be0cc25bb87f50edda4bca4ecea6b5e89
  Date:   2013-08-21 (Wed, 21 Aug 2013)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Update required boost version to 1.53
Update root CMakeLists to require boost 1.53, which is now required as
discussed in #170.
  Commit: 5dbf8fd1014957232172ab153680515c5a00bcd0
      https://github.com/PDAL/PDAL/commit/5dbf8fd1014957232172ab153680515c5a00bcd0
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #172 from gadomski/update-boost-version
  Commit: 075f5ed793c6ec0fbc0e6330ac17c5c87c865747
      https://github.com/PDAL/PDAL/commit/075f5ed793c6ec0fbc0e6330ac17c5c87c865747
  Changed paths:
    M src/Dimension.cpp
    M src/FileUtils.cpp
    M src/Filter.cpp
    M src/GDALUtils.cpp
    M src/Metadata.cpp
    M src/Options.cpp
    M src/Reader.cpp
    M src/Schema.cpp
    M src/Stage.cpp
    M src/StageBase.cpp
    M src/StageInfo.cpp
    M src/Utils.cpp
    M src/Writer.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge pull request #171 from gadomski/astyle
  Commit: b0b04614124422173e3a7b2f495c85958ddfd3a8
      https://github.com/PDAL/PDAL/commit/b0b04614124422173e3a7b2f495c85958ddfd3a8
  Date:   2013-08-22 (Thu, 22 Aug 2013)
  Changed paths:
    M include/pdal/filters/HexBin.hpp
  Log Message:
  put hex generation in destructor of iterator -- it has to happen after we've read all the points, and then it will update the metadata of the PointBuffer that was used to instantiate the interator
  Commit: b5d24b2ac4c864877024947fa8629862abc3ff73
      https://github.com/PDAL/PDAL/commit/b5d24b2ac4c864877024947fa8629862abc3ff73
  Changed paths:
    M CMakeLists.txt
    M src/Dimension.cpp
    M src/FileUtils.cpp
    M src/Filter.cpp
    M src/GDALUtils.cpp
    M src/Metadata.cpp
    M src/Options.cpp
    M src/Reader.cpp
    M src/Schema.cpp
    M src/Stage.cpp
    M src/StageBase.cpp
    M src/StageInfo.cpp
    M src/Utils.cpp
    M src/Writer.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
Conflicts:
  Commit: de0b6a7c3a80c9f513a9261e4d101aa7c5c136de
      https://github.com/PDAL/PDAL/commit/de0b6a7c3a80c9f513a9261e4d101aa7c5c136de
  Changed paths:
  Log Message:
  fix up bad merge
  Commit: 84e44c412d776d5c1cc12ac71b27bf7b241aad9a
      https://github.com/PDAL/PDAL/commit/84e44c412d776d5c1cc12ac71b27bf7b241aad9a
  Date:   2013-08-26 (Mon, 26 Aug 2013)
  Changed paths:
    M include/pdal/Schema.hpp
    A include/pdal/third/string_ref.hpp
    A include/pdal/third/string_ref_fwd.hpp
    M src/CMakeLists.txt
    M src/Schema.cpp
  Log Message:
  Use a pdal-namespaced string_ref instead of the one from system boost which is in flux right now #173
  Commit: 011cbbe414de869b8eedcd5ae8a27a9d82c1c079
      https://github.com/PDAL/PDAL/commit/011cbbe414de869b8eedcd5ae8a27a9d82c1c079
  Changed paths:
    M src/Schema.cpp
  Log Message:
  Merge pull request #173 from PDAL/issues/173-embed-string_ref
string_ref and external boost 1.53 is no good
  Commit: 25c6b4e7126ee1a0048537d953cdf5fba2bfc633
      https://github.com/PDAL/PDAL/commit/25c6b4e7126ee1a0048537d953cdf5fba2bfc633
  Date:   2013-08-27 (Tue, 27 Aug 2013)
  Changed paths:
    M CMakeLists.txt
    M boost/CMakeLists.txt
    M hobu-windows.bat
    M include/pdal/drivers/oci/Reader.hpp
    M include/pdal/drivers/oci/Writer.hpp
    M include/pdal/drivers/oci/common.hpp
    M include/pdal/drivers/oci/oci_wrapper.h
    M include/pdal/drivers/pgpointcloud/common.hpp
    M src/Dimension.cpp
    M src/FileUtils.cpp
    M src/Filter.cpp
    M src/GDALUtils.cpp
    M src/Metadata.cpp
    M src/Options.cpp
    M src/Reader.cpp
    M src/Schema.cpp
    M src/Stage.cpp
    M src/StageBase.cpp
    M src/StageInfo.cpp
    M src/Utils.cpp
    M src/Writer.cpp
    M src/XMLSchema.cpp
    M src/drivers/oci/common.cpp
    M test/data/oracle/cleanup.sql
    M test/perf/CMakeLists.txt
    A test/unit/drivers/oci/oracle_array.cpp
  Log Message:
  Merge branch 'master' into issues/124-p2g-intensity-interpolate
  Commit: 4a00f1b54578223de518f22d2dee404eb5c1659c
      https://github.com/PDAL/PDAL/commit/4a00f1b54578223de518f22d2dee404eb5c1659c
  Changed paths:
    M src/Schema.cpp
  Log Message:
Compare: https://github.com/PDAL/PDAL/compare/2d2cebc640e6...4a00f1b54578
More information about the pdal-commits mailing list
